    HSN Code 3917: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    May 29, 2026
    30 second summary | HSN Code 3917 covers plastic pipes, tubes, hoses and fittings under GST. Learn the latest 18% GST rate, product classifications, ITC eligibility rules, e-way bill requirements, filing mistakes to avoid and compliance tips for manufacturers, traders, importers and contractors dealing in plastic piping products.
    HSN Code 3917 is the internationally standardised product classification code for “Tubes, pipes and hoses, and fittings.” It falls under Chapter 39 of the Harmonised System of Nomenclature (HSN), which covers plastics and articles thereof.
    Under India’s GST regime, this heading also includes artificial gut (sausage casings) made from hardened protein or cellulosic materials, a less commonly known but officially listed product category under the same heading.
    For manufacturers, traders, contractors, importers and exporters dealing with plastic piping systems, whether for plumbing, agriculture, construction or industrial use, the accurate use of HSN 3917 on invoices and GST returns is a legal compliance requirement, not optional.
    Which products fall under the 3917 HSN Code?
    The HSN system follows different digit levels for product classification. Here’s how 3917 is divided:
    Description
    HSN
    Artificial sausage casings made from hardened protein or cellulosic materials
    3917
    Artificial sausage casings made of hardened protein
    39171010
    Artificial sausage casings made of cellulosic materials
    39171020
    Rigid plastic tubes, pipes and hoses made from polymers of ethylene
    391721
    Polyethylene tubes
    39172110
    Other rigid tubes, pipes and hoses of polymers of ethylene
    39172190
    Rigid tubes, pipes and hoses made from polymers of propylene
    39172200
    Rigid plastic tubes, pipes and hoses made from polymers of vinyl chloride
    391723
    Seamless tubes of polymers of vinyl chloride
    39172310
    Other tubes and pipes of polymers of vinyl chloride
    39172390
    Rigid tubes, pipes and hoses made from other plastics
    391729
    Seamless tubes of vinyl acetate and vinyl chloride copolymers
    39172910
    Seamless tubes of polystyrene polymers and copolymers
    39172920
    Tubes made from cellulose nitrate or celluloid, plasticised or non-plasticised
    39172930
    Tubes made from cellulose acetate or acetate butyrate
    39172940
    Tubes made from vinyl plastics
    39172950
    Other rigid tubes, pipes and hoses of plastics
    39172990
    Flexible plastic tubes, pipes and hoses with a minimum burst pressure of 27.6 MPa
    39173100
    Non-reinforced tubes and pipes without fittings made from condensation or rearrangement polymerisation products
    39173210
    Non-reinforced tubes and pipes without fittings made from addition polymerisation products
    39173220
    Other non-reinforced plastic tubes and pipes without fittings
    39173290
    Non-reinforced plastic tubes and pipes supplied with fittings
    39173300
    Other plastic tubes, pipes and hoses
    391739
    Tubes and pipes made from condensation or rearrangement polymerisation products, chemically modified or not
    39173910
    Tubes and pipes made from addition polymerisation products
    39173920
    Other plastic tubes, pipes and hoses not elsewhere specified
    39173990
    Plastic fittings for tubes, pipes and hoses, such as joints, elbows and flanges
    39174000
    What is the GST rate for products covered under HSN Code 3917?
    Following the GST rate rationalisation approved during the 56th GST Council meeting held on 3 September 2025, goods falling under HSN 3917 continue to attract GST at the standard rate of 18%, effective from 22 September 2025. The rationalised GST structure largely moved towards a simplified two-slab system consisting of a 5% merit rate and an 18% standard rate for most goods and services.
    Plastic piping products classified under Chapter 39, including HSN 3917 items, fall within the standard 18% category because they are treated as industrial and infrastructure-related products rather than essential merit goods.
    Here are different GST rates for HSN codes.
    What are the Input Tax Credit (ITC) eligibility rules for HSN 3917 products?
    To claim ITC for products classified under HSN 3917, know the following rules:
    • The buyer must be a GST-registered person to claim ITC on goods falling under HSN 3917.
    • A valid tax invoice, debit note, or prescribed GST document is mandatory for claiming credit.
    • The buyer must receive the plastic pipes, tubes, hoses or fittings before ITC can be availed.
    • ITC is allowed only when the goods are used for business purposes or furtherance of business. Personal use is not eligible.
    • The supplier must upload the invoice details in GSTR-1, and the same should reflect in the buyer’s GSTR-2B.
    • The tax charged by the supplier must actually be paid to the government.
    • The buyer must file GST returns within the prescribed due dates to claim ITC.
    • Payment to the supplier must generally be made within 180 days from the invoice date; otherwise, ITC reversal may apply.
    • ITC cannot be claimed on blocked credits under Section 17(5), such as goods used for personal consumption or exempt supplies.
    • ITC must be claimed within the prescribed time limit, generally by 30 November following the end of the financial year or before filing the annual return, whichever is earlier.
    Common filing mistakes businesses should avoid
    Here are some common mistakes businesses make when filing GST returns for the HSN Code 3917:
    • Many businesses confuse the classification of rubber hoses, metal pipes and plastic pipes. Each belongs to a different HSN chapter.
    • Charging the wrong GST rate can create tax demand notices during audits.
    • If you fail to mention HSN codes, the authorities may levy penalties under the GST law.
    • If there is a mismatch between the supplier’s and the buyer’s filings, the ITC may be blocked.
    • Generic descriptions like “pipe material” should be avoided. Businesses should mention specific product details such as “UPVC plumbing pipe” or “HDPE irrigation pipe”.
    Read HSN Code Verification and Validation Explained for Businesses to avoid mistakes.
    Conclusion
    Correct reporting of HSN Code 3917 directly impacts vendor credibility, faster ITC reconciliation and smoother movement of goods across supply chains. Businesses dealing in plastic piping products should regularly review product masters, invoice formats and GST mappings to reduce future compliance risks.
    Maintaining digital records and automating HSN-wise reporting through accounting solutions such as TallyPrime can help businesses minimise manual errors, improve return accuracy and stay prepared for departmental scrutiny and GST audits.
    Verify GSTIN details online
    cta banner image
    FAQs
    Businesses may need tax invoices, purchase records, e-way bills, GSTR filings, stock registers, transport documents and ITC records during GST assessments or audits.
    No. Businesses should use the most accurate product-specific HSN classification available because different plastic materials and product structures may fall under separate sub-categories within HSN 3917.
    Yes. For goods covered under HSN Code 3917, an e-way bill is generally mandatory when the consignment value exceeds ₹50,000. This requirement arises under Section 68 of the CGST Act, read with Rule 138 of the CGST Rules, 2017, especially for inter-state movement. Intra-state applicability may vary depending on state-specific notifications and threshold limits
    Yes. Businesses can revise an incorrect HSN code reported in GST returns by amending details in subsequent returns, subject to the time limit under Section 39(9) of the CGST Act. Corrections are generally allowed up to 30 November following the end of the relevant financial year or before filing the annual return, whichever is earlier. Deliberate misreporting may attract penalties under Sections 122 and 125 of the CGST Act.
    Yes. Plastic electrical conduit pipes used for wiring protection in residential, commercial and industrial buildings generally fall under HSN 3917. Their classification depends on the product composition, rigidity and intended electrical installation use.
    Published on May 29, 2026
