No more typing the same invoice twice.
80% of the time spent on manual data entry — saved.
Docs by Ira is TallyIra's first offering that intelligently reads business documents, understands relevant information, and prepares accounting entries for review before posting into TallyPrime. Simply scan or upload your documents to auto-create invoices in TallyPrime. The result is less manual effort, faster processing, and greater consistency across accounting workflows. You review. You approve. You stay in control.
Scan and import invoices directly from the TallyIra app or TallyPrime
Auto-create transactions in TallyPrime in draft mode
Review, verify and approve with a single click
You can find your serial number in TallyPrime under F1 (Help) → About. OTP will be sent to the registered email id.
The add-on will be automatically enabled for your TallyPrime serial number.
Import documents directly from TallyPrime on your desktop, or download the app to upload on the go, choose whichever suits you.
Five capabilities doing the heavy lifting, so you don't have to
Scan or import invoices from your mobile app or system directly into TallyPrime.
Automatically extract key invoice details such as party name, invoice number, date, amounts, GST, and line items.
Identify mismatches or missing details instantly, so you can review and correct them quickly.
Process multiple invoices at once and create draft vouchers in minutes.
Automatically map parties and items to existing masters, create new masters when needed, and detect duplicate invoices to avoid errors. Correct a mapping once, and Docs by Ira remembers it for next time.
AI can help businesses work faster. But for businesses, speed alone is never enough. The technology must be reliable, protect business data, and deliver outcomes that users can trust. That's why TallyIra is thoughtfully built around three principles.
Your documents and data are used only to get the job done. Never shared. Never used to train models for anyone else's benefit.
Entries are drafted to match how your business actually works, with exceptions flagged before they ever reach you.
Nothing posts to TallyPrime without your review and approval. Always.
Docs by Ira is available for eligible TallyPrime serial numbers, based on activation criteria and phased rollout.
No. Docs by Ira creates draft vouchers that you review and approve before anything is posted. AI assists — you stay in control.
Common invoice and bill formats, including PDF, JPEG, JPG and ZIP.
Yes. Your documents are used only to process your work — never shared, never used to train models for others. Docs by Ira is governed by Tally's privacy policy.
We check your serial number for eligibility. If available, Docs by Ira is enabled and you'll get a confirmation email — otherwise you're added to the waitlist.
