    HSN Code 8302: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    May 29, 2026
    30 second summary | Learn everything about HSN Code 8302, including product classification, 18% GST rate, ITC eligibility rules, e-way bill requirements, import-export treatment and GST filing practices for hardware fittings, hinges, brackets, castors and other base metal mounting products used in buildings, furniture and vehicles.
    HSN stands for Harmonised System of Nomenclature, an internationally accepted coding system used for classifying goods in trade. In India, HSN codes are used under GST for taxation and reporting purposes.
    HSN Code 8302 falls under Chapter 83, which covers miscellaneous articles of base metal, including a wide range of base-metal mountings, fittings, and similar hardware used in furniture, doors, windows, staircases, vehicles, trunks and other fixtures.
    Businesses involved in manufacturing, importing, exporting, wholesaling, or trading hardware products must use the correct HSN classification to ensure proper GST compliance, accurate invoicing and smooth return filing.
    What items are classified under HSN Code 8302?
    The HSN classification system uses different digit combinations to identify products in detail. Below is the breakdown of HSN Code 8302:
    Description
    HSN Code
    Base metal mountings, fittings, brackets, castors, hat-racks, hat-pegs and similar fixtures for furniture, doors, windows, staircases, trunks, caskets, saddlery and coachwork
    8302
    Hinges of base metal
    830210
    Base metal hinges and mounting fittings for furniture, doors, windows and similar applications
    83021010
    Base metal hinges and fittings for staircases, blinds, trunks, caskets and related uses
    83021020
    Other base metal hinges and similar mounting fittings
    83021090
    Castors with mounting of base metal
    83022000
    Mountings, fittings and similar articles suitable for motor vehicles
    830230
    Base metal fittings and mounting hardware used in motor vehicles
    83023010
    Other mountings and fittings suitable for motor vehicles
    83023090
    Base metal mountings and fittings suitable for buildings
    830241
    Door fittings, brackets and similar base metal fixtures for buildings
    83024110
    Window and staircase fittings of base metal for buildings
    83024120
    Other base metal fittings and mountings suitable for buildings
    83024190
    Base metal mountings, fittings and similar articles suitable for furniture
    83024200
    Other base metal mountings, fittings and similar articles
    83024900
    Hat-racks, hat-pegs, brackets and similar base metal fixtures
    83025000
    Automatic door closers of base metal
    83026000
    Read more to understand HSN Code: Full Form, List & GST Rates
    What GST rate is applicable to products under HSN Code 8302?
    Under the GST framework, goods falling under HSN 8302 are generally taxed at the standard GST rate of 18%, split into 9% CGST and 9% SGST for intra-state supplies, or 18% IGST for inter-state transactions and imports.
    After the GST rate restructuring introduced at the 56th GST Council Meeting in September 2025, the government streamlined the indirect tax system by retaining the 5% and 18% GST slabs for most goods.
    HSN 8302 products continue to fall within the standard 18% GST category because these hardware fittings are treated as industrial and construction-related manufactured goods rather than essential items eligible for the concessional 5% slab.
    What conditions must be met to avail Input Tax Credit (ITC) on HSN 8302 products?
    Here are the key rules for claiming ITC on HSN 8302 products:
    • Businesses dealing in these goods can claim Input Tax Credit (ITC) only if the conditions under Section 16 of the CGST Act are fulfilled.
    • The buyer must possess a valid tax invoice, debit note or prescribed GST document issued by the supplier. The invoice should clearly mention the GSTIN, HSN Code 8302, the tax amount and the invoice details.
    • ITC can be claimed only after the purchaser actually receives the goods. If the hardware items are received in lots or instalments, credit is available only after the final lot is received.
    • The supplier must deposit the GST collected on the transaction with the Government, and the buyer must ensure the invoice is reflected correctly in GSTR-2B. Restricted or mismatched invoices may lead to the denial of ITC.
    • The recipient must file GST returns under Section 39 within the prescribed time to avail ITC legally.
    • Payment to the supplier must generally be made within 180 days from the invoice date. If payment is not made, the claimed ITC must be reversed along with applicable interest.
    • ITC is allowed only when HSN 8302 goods are used for business purposes or taxable supplies. Credit relating to exempt supplies or personal use must be reversed proportionately under Section 17.
    • ITC cannot be claimed on goods lost, stolen, destroyed, written off or distributed as free samples or gifts.
    • ITC must be claimed within the time limit prescribed under Section 16(4), generally before filing the annual return or the specified return due date for the following financial year.
    Business filing guide for HSN 8302 products
    If you are dealing in products under HSN 8302, follow the proper GST filing and documentation practices outlined below.
    • Every Stock Keeping Unit (SKU) or inventory item should be linked to the correct HSN code in accounting or Enterprise Resource Planning (ERP) software.
    • Ensure the applicable GST rate is correctly configured in billing systems to avoid tax mismatches.
    • Suppliers must report outward supplies with proper HSN classification while filing GSTR-1.
    • Buyers should reconcile supplier invoices with GSTR-2B to ensure ITC eligibility.
    • Maintain catalogues, product brochures, and technical specifications to justify classification during audits.
    Conclusion
    For businesses dealing in hardware fittings and base-metal fixtures, staying organised is important. A small mismatch in classification, invoice details or GST reporting can disrupt vendor payments, delay ITC claims and create unnecessary compliance pressure during audits.
    Businesses should also conduct periodic internal reviews of product catalogues and tax configurations to minimise future disputes.
    Using accounting and compliance solutions like TallyPrime can help businesses streamline inventory mapping, GST invoicing, reconciliation, and return filing while improving operational accuracy.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes, imported hinges, brackets, castors, door fittings, and similar base-metal hardware are generally classified under HSN 8302 during customs clearance. Importers must declare the correct classification in the Bill of Entry to calculate customs duty, IGST, and other applicable charges
    Yes, businesses can revise an incorrect HSN Code 8302 reported in GST returns by amending details in subsequent GSTR-1 filings, subject to timelines under Section 37 of the CGST Act, 2017. Corrections must generally be made by 30th November following the relevant financial year or before filing the annual return, whichever is earlier.
    Yes. Exports of products classified under HSN Code 8302 are treated as “zero-rated supplies” under Section 16 of the IGST Act, 2017. Exporters can supply goods either without payment of IGST under Letter of Undertaking (LUT)/Bond and claim refund of unutilised ITC, or export on payment of IGST and later claim refund under Section 54 of the CGST Act.
    Yes. An e-way bill is generally required for goods classified under HSN Code 8302 when the consignment value exceeds ₹50,000, and the goods are moved for supply, stock transfer or other business purposes. This requirement arises under Rule 138 of the CGST Rules, 2017 and Section 68 of the CGST Act. However, exemptions may apply for certain intra-state movements depending on state-specific notifications.
    GST rules, exemption notifications and classification clarifications may change over time through government circulars or GST Council decisions. Businesses should regularly monitor updates to avoid using outdated tax rates, incorrect classifications or obsolete compliance procedures.
    Published on May 29, 2026
