    HSN Code 8414: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    May 29, 2026
    30 second summary | HSN Code 8414 covers air pumps, vacuum pumps, compressors, fans, blowers and ventilation equipment under GST. Learn product classifications, latest GST rates after the 56th GST Council meeting, compliance tips, documentation requirements and filing best practices for businesses dealing in machinery and industrial equipment.
    HSN (Harmonised System of Nomenclature) is an internationally standardised product classification system maintained by the World Customs Organisation (WCO). India adopted it for GST purposes to ensure uniform product identification across supply chains.
    HSN Code 8414 falls under Chapter 84 of the GST HSN schedule, which covers nuclear reactors, boilers, machinery and mechanical appliances.
    In practical terms, this heading covers every piece of equipment whose primary function is to move, compress or expel air or gas, from a simple bicycle pump to a multi-stage industrial gas compressor used in a refinery.
    Which products fall under 8414 HSN Code?
    The HSN system uses different digit levels for detailed classification. Here is the breakdown of 8414:
    Description
    HSN Code
    Air or vacuum pumps, gas compressors, fans, and ventilating or recycling hoods with built-in fan and filters
    8414
    Vacuum pumps
    84141000
    Hand or foot-operated air pumps
    841420
    Bicycle air pumps
    84142010
    Other hand-operated air pumps
    84142020
    Other hand or foot-operated air pumps
    84142090
    Compressors used in refrigerating equipment
    84143000
    Air compressors mounted on wheeled chassis for towing
    841440
    Reciprocating air compressors mounted on wheeled chassis
    84144010
    Centrifugal air compressors mounted on wheeled chassis
    84144020
    Screw air compressors mounted on wheeled chassis
    84144030
    Other air compressors mounted on wheeled chassis
    84144090
    Table, floor, wall, window, ceiling, or roof fans with self-contained electric motor up to 125 W
    841451
    Table fans
    84145110
    Floor fans
    84145120
    Window fans
    84145130
    Ceiling or roof fans
    84145140
    Wall fans
    84145150
    Other domestic fans with a motor up to 125 W
    84145190
    Other fans and blowers
    841459
    Air circulators
    84145910
    Portable blowers
    84145920
    Industrial fans and blowers
    84145930
    84145990
    Ventilating or recycling hoods with horizontal sides not exceeding 120 cm
    84146000
    Other air or gas compressors and related equipment
    841480
    Gas compressors used in air-conditioning equipment
    84148011
    Other gas compressors
    84148019
    Free piston generators for gas turbines
    84148020
    Turbochargers
    84148030
    Other compressors and related equipment
    84148090
    Parts of pumps, compressors, fans, and hoods
    841490
    Parts of gas compressors used in refrigerating and air-conditioning equipment
    84149011
    Parts of bicycle pumps
    84149012
    Other parts of air or vacuum pumps and compressors
    84149019
    Parts of free piston generators
    84149020
    Parts of electric fans
    84149030
    Parts of industrial fans and blowers
    84149040
    Other parts
    84149090
    What GST rate applies to products classified under HSN Code 8507?
    Under the GST framework revised after the 56th GST Council meeting held in September 2025, most goods classified under 8414 HSN Code continue to attract 18% GST from 22 September 2025 onwards, as machinery and industrial equipment were largely retained under the standard GST slab after the removal of the earlier 12% and 28% slabs.
    Difference between HSN 8414 and similar codes
    Businesses often confuse HSN 8414 with related machinery categories.
    HSN Code
    Product Category
    8413
    Liquid pumps
    8414
    Air pumps, compressors and fans
    8415
    Air conditioning machines
    8418
    Refrigerators and freezers
    8501
    Electric motors
    Tips for businesses using HSN Code 8414
    If you operate a business dealing in products that fall under the 8414 HSN Code, here are some tips you may follow:
    • Create a product master sheet with accurate HSN codes for every Stock Keeping Unit (SKU).
    • Ensure suppliers are using the same HSN classification to avoid Input Tax Credit (ITC) mismatches.
    • Use GST software with updated HSN databases to reduce filing errors.
    • Product classifications may change based on tariff amendments or GST notifications. It is important to review classification regularly.
    • Keep technical specifications ready. For industrial compressors and specialised machinery, technical documents help support classification during audits.
    What documents should businesses maintain?
    Businesses dealing with HSN 8414 products should keep:
    GST invoices
    Businesses must maintain all tax invoices issued for the sale of HSN 8414 products. These invoices should clearly mention:
    • Correct HSN code
    • Product description
    • GST rate charged
    • Quantity and value of goods
    • Supplier and buyer GSTIN
    Purchase bills
    Purchase invoices from suppliers should be carefully preserved, as they serve as proof of inward supply transactions. These bills are important for:
    • Claiming ITC
    • Matching GSTR-2B records
    • Verifying supplier compliance
    • Maintaining stock and accounting records
    Read more on HSN Code Verification and Validation Explained for Businesses
    Technical catalogues
    Technical catalogues, brochures and manufacturer manuals help establish the exact nature and functionality of the product. These documents are useful when authorities question a product's classification under GST or customs law.
    For example, catalogues may help differentiate:
    • Industrial blowers from standard fans
    • Air compressors from refrigeration machinery
    • Ventilation systems from air-conditioning equipment
    Product specification sheets
    Specification sheets containing technical details such as capacity, power rating, pressure range, industrial application and product model number should be maintained properly. These records help businesses justify the selected HSN code during audits or classification disputes.
    Vendor agreements
    Businesses should preserve agreements signed with manufacturers, distributors, importers or suppliers. These agreements often contain:
    • Product descriptions
    • Pricing terms
    • Supply conditions
    • Tax responsibilities
    • Delivery obligations
    Vendor agreements help establish transaction authenticity during departmental verification.
    E-way bills
    E-way bills generated for the transportation of goods should be stored properly along with invoices and transport documents. Mismatch in e-way bill details, invoice data and GST returns may lead to notices or penalties.
    Import and export documents
    Importers and exporters dealing in compressors, fans or industrial air systems under HSN 8414 should maintain:
    • Bill of Entry
    • Shipping bills
    • Customs invoices
    • Packing lists
    • Import licences, where applicable
    • Freight and insurance documents
    These records are important for customs clearance, duty calculation and export benefit claims.
    Conclusion
    Managing HSN Code 8414 correctly is not just about GST compliance but also about improving operational accuracy across procurement, billing and inventory management. Businesses should periodically review product mapping, train accounting teams on classification updates and automate compliance workflows wherever possible.
    Using business management software like TallyPrime can help streamline HSN-wise invoicing, reconciliation and return filing while reducing manual errors and improving overall reporting efficiency for growing businesses.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes, spare parts and accessories are often classified separately from the main equipment. For example, parts of fans, compressors or pumps may fall under dedicated “parts” classifications within the 841490 series rather than the code used for the complete machine.
    Yes, classification may change depending on the product’s design, technical specifications and intended use. For instance, a compressor used exclusively in refrigeration equipment may be classified differently from a general industrial air compressor.
    No, HSN codes apply to goods. Repair, installation or maintenance services related to compressors, pumps or ventilation systems are generally classified under the SAC (Services Accounting Code) rather than the HSN.
    Yes, imported compressors, vacuum pumps, fans and related equipment are also classified under HSN 8414 for customs and GST purposes. The same classification is generally used across import documentation, GST invoices and accounting records.
    Businesses can check the customs tariff schedule, GST rate notifications and product technical specifications before finalising classification.
    Published on May 29, 2026
