    HSN Code 2517 “Product Classification, GST Rate & Business Filing Guide”
    Tallysolutions
    Tally Solutions
    May 21, 2026
    30 second summary | The 2517 HSN Code includes pebbles, gravel, crushed stone and construction aggregates used in roads, concrete and railway ballast. Falling under Chapter 25 (earths and stone), it attracts 5% GST. Sub-codes cover macadam, marble chips, tarred aggregates and similar materials. Correct HSN classification ensures accurate GST invoicing and compliance.
    The 2517 HSN Code classifies construction aggregates, such as gravel, crushed stone and similar materials, under Chapter 25 and attracts a 5% GST rate. These inputs are essential for road construction, concrete production, railway ballast and large infrastructure projects, where classification depends on the material’s nature as an aggregate rather than its end-use industry.
    What Is the Classification Table for HSN Code 2517 with GST Rate?
    To understand how different types of stone aggregates are classified under 2517 HSN Code, the table below lists the relevant sub-codes, their descriptions and the applicable GST rate. This classification is based on the nature of the material (stone aggregates, macadam, marble chips, etc.) used in construction and industrial applications.
    Category
    HSN Code / Number
    Description
    GST Rate
    Pebbles, gravel, crushed stone
    2517
    Aggregates used for concrete, roads, railway ballast, etc.
    5%
    Pebbles, gravel, crushed stone (general)
    2517 10
    Stone aggregates, shingle, flint (heat-treated or not)
    5%
    Pakur stone
    2517 10 10
    Crushed or broken Pakur stone
    5%
    Flint
    2517 10 20
    Flint stone aggregates, used in ball mills for crushing materials such as lime and cement; also widely applied in ceramic and abrasive industries.
    5%
    Other stone aggregates
    2517 10 90
    Other crushed stone or ballast materials
    5%
    Macadam (industrial waste-based)
    2517 20
    Macadam made from slag, dross or similar waste
    5%
    Macadam
    2517 20 00
    Industrial waste-based macadam
    5%
    Tarred macadam
    2517 30
    Bitumen-treated aggregates used in roads
    5%
    Tarred macadam (detailed code)
    2517 30 00
    Tar-coated road construction material
    5%
    Marble chips and powder
    2517 41
    Granules, chippings, powder of marble
    5%
    Marble granules (detailed)
    2517 41 00
    5%
    Other stone granules
    2517 49
    Chips and powder of other stones (granite, basalt, etc.)
    5%
    Other granules
    2517 49 00
    Non-marble stone aggregates
    5%
    Note: GST Treatment for 2517 HSN code:
    • GST Rate: 5% (2.5% CGST + 2.5% SGST or 5% IGST)
    • Most products directly falling under HSN 2517 attract a 5% GST rate. However, businesses should carefully review the classification of processed or composite products, as GST treatment may differ depending on the nature of the goods.
    How to choose the correct 2517 HSN sub-code
    Selecting the correct sub-classification under HSN 2517 requires identifying the exact nature of the material, rather than using the broad category of “stone aggregates.” Since this heading covers multiple product types, businesses must focus on the specific characteristics of the goods they supply.
    • Stone type: Identify whether the material is marble, granite, flint or another variety, as different stones may fall under distinct sub-codes.
    • Level of processing: Check whether the product is crushed, powdered, chipped or further treated (e.g., tarred macadam).
    • Intended use: Determine whether it is used for general construction, road surfacing, railway ballast or other infrastructure applications.
    • Source of material: Distinguish between natural stone and industrial waste-based materials (such as slag-based macadam), as classification differs accordingly.
    Key rule: Always use the most specific 8-digit HSN code that accurately describes the product, rather than relying only on the general heading 2517. This ensures correct GST reporting, reduces classification errors and improves compliance accuracy.
    What common 2517 HSN code classification errors should businesses avoid?
    Common HSN 2517 classification errors usually occur when businesses do not correctly identify the product category or use overly broad coding instead of precise sub-classification.
    • Applying the wrong chapter: One of the most frequent mistakes is classifying materials like cement under HSN 2517. Cement falls under a different heading and attracts a different GST rate, so that misclassification can lead to compliance issues.
    • Using only “2517” instead of sub-codes: Relying on the four-digit heading instead of the correct 8-digit sub-classification can create errors in GST reporting and reduce classification accuracy.
    • Confusing processed vs finished goods: Aggregates under HSN 2517 are raw construction materials such as gravel, crushed stone and macadam. They should not be confused with finished construction products, which are classified under different headings.
    Conclusion
    The 2517 HSN Code plays a key role in classifying construction aggregates such as gravel, crushed stone and similar materials under GST, with a uniform 5% rate that brings clarity and consistency to taxation for businesses in this sector.
    At the same time, accurate sub-code selection remains essential for correct GST filing and compliance, as even small classification errors can lead to reporting issues. Businesses can improve accuracy and streamline invoicing by using tools like TallyPrime, which help automate HSN mapping and ensure smoother GST reporting and record-keeping.
    Verify GSTIN details online
    cta banner image
    Published on May 21, 2026
