    HSN Code 7308: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    May 29, 2026
    30 second summary | HSN Code 7308 covers iron and steel structures such as towers, roofing frameworks, scaffolding and fabricated structural parts. The article explains product classification, the latest 18% GST rate, ITC eligibility, customs impact and GST compliance rules for businesses dealing in steel structures.
    Harmonised System of Nomenclature (HSN) Code 7308 covers structures and their parts made from iron or steel. This code is widely used in the construction, infrastructure, engineering and fabrication industries in India. Businesses involved in manufacturing, supplying or importing steel structures must use the correct HSN classification to ensure accurate GST billing and tax compliance.
    Under the GST system, HSN codes help identify goods and determine the applicable tax rate. Therefore, understanding HSN Code 7308 is important for fabricators, contractors, EPC companies, wholesalers and exporters.
    Which products fall under the 7308 HSN Code?
    HSN 7308 sits within the broader GST hierarchy as follows:
    • Section XV: Base Metals & Articles of Base Metal
    • Chapter 73: Articles of Iron or Steel
    Here is the detailed breakdown of the 7308 HSN Code classification:
    Description
    HSN Code
    Iron or steel structures and structural parts excluding prefabricated buildings under heading 9406, including bridges, bridge sections, lock gates, towers, lattice masts, roofs, roofing frameworks, doors, windows, shutters, balustrades, pillars and columns
    7308
    Iron or steel structures and structural parts such as bridges, bridge sections, towers, lattice masts, roofs, roofing frameworks, doors, windows, shutters, balustrades, pillars and columns
    730810
    Iron or steel fabricated structures and structural components, including bridges, lock gates, towers, roofs, doors, windows and related framework parts
    73081000
    Towers and lattice masts made of iron or steel used in structural applications
    730820
    Galvanised iron or steel towers designed for transmission or telecom infrastructure
    73082011
    Other iron or steel towers and lattice masts not elsewhere specified
    73082019
    Iron or steel lattice masts used for industrial, telecom or power installations
    73082020
    Doors, windows and their frames, thresholds and shutters made of iron or steel
    730830
    Iron or steel doors, windows, frames, thresholds and shutters for residential or industrial use
    73083000
    Scaffolding, shuttering, propping and pit-propping equipment made of iron or steel
    730840
    Iron or steel scaffolding and similar temporary structural support equipment
    73084000
    Other iron or steel structures and structural parts not specifically classified elsewhere
    730890
    Plates, rods, angles, sections, tubes and similar prepared structural components of iron or steel
    73089010
    Iron or steel structural components prepared for use in bridges, buildings or industrial projects
    73089020
    Iron or steel framework sections and fabricated structural assemblies
    73089030
    Structural panels, frameworks and support systems made of iron or steel
    73089040
    Iron or steel fabricated beams, girders and support structures
    73089050
    Industrial iron or steel structural assemblies and framework components
    73089060
    Ready-to-install iron or steel structural sections and fabricated parts
    73089070
    Other miscellaneous iron or steel structural products and fabricated parts
    73089090
    Use this HSN Code Finder to find a preferred HSN code.
    How much GST is charged on products falling under HSN 7308?
    Under the GST regime, goods classified under HSN 7308 continue to attract 18% GST after the GST rate rationalisation approved during the 56th GST Council Meeting held in September 2025. The revised GST structure, effective from 22 September 2025, largely retained iron and steel construction products within the standard 18% slab, as these items are treated as industrial and infrastructure-related goods rather than essential commodities.
    Input Tax Credit (ITC) on HSN 7308 purchases
    Businesses registered under GST that purchase goods falling under HSN 7308 for use in their taxable business activities are generally eligible to claim Input Tax Credit (ITC) on the GST paid. However, some important conditions and restrictions apply:
    • ITC is available when steel structures are purchased for use in manufacturing, trading, or for use in providing taxable services (such as industrial construction contracts).
    • ITC may be blocked under Section 17(5) of the CGST Act if the structures are used for the construction of immovable property for the business's own use (i.e., not for further sale as a works contractor). This is a frequently litigated area, and businesses should carefully document the end use of purchased materials.
    • Works contractors purchasing HSN 7308 goods for use in providing works contract services can generally claim ITC where the end output is also a taxable works contract supply.
    • As part of post-56th Council reform, provisional refunds of 90% for inverted duty structure (IDS) claims became available from 1st November 2025, on a risk-based, automated basis, relevant for businesses where input GST rates exceed output tax rates.
    Conclusion
    For businesses dealing in steel fabrication, industrial structures or infrastructure supply, HSN Code 7308 directly affects billing accuracy, ITC eligibility and overall GST compliance. Even small mistakes in classification or documentation can create unnecessary delays during audits, return filing or ITC reconciliation.
    This makes it important for businesses to maintain proper product mapping, vendor records and GST documentation from the start, rather than correcting errors later. As GST compliance becomes increasingly automated, using accounting and business management solutions like TallyPrime can help businesses manage HSN-wise invoicing, GST reporting, reconciliation and compliance tracking more efficiently while reducing manual errors.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes, fabricated steel components used to build warehouses, factory sheds and industrial structures generally fall under HSN 7308. However, if an entire prefabricated building is supplied as a complete unit, it may instead fall under HSN 9406 depending on the product structure and contract terms.
    Yes, exporters are generally required to mention the correct HSN classification in shipping bills, commercial invoices and GST-related export documentation. Incorrect HSN reporting can delay customs clearance and refund processing.
    Yes, businesses can correct errors through debit notes, credit notes or amended invoices, depending on the nature of the mistake.
    No. HSN 7308 applies to goods classification, while fabrication or processing services are generally classified under SAC (Services Accounting Code). Businesses providing fabrication as a service must separately determine the applicable SAC and GST treatment.
    Yes, imported iron and steel structures may attract Basic Customs Duty (BCD), Social Welfare Surcharge and IGST at the time of import, depending on the product category and applicable trade notifications.
    Published on May 29, 2026
