    HSN Code for AC, Refrigerator, Washing Machine & Home Appliances: GST Rate Guide
    Tallysolutions
    Tally Solutions
    May 29, 2026
    30 second summary | Home appliances such as refrigerators, air conditioners and washing machines fall under Chapters 84 and 85 of the HSN system and are generally taxed at 18% GST. The correct HSN code varies by product type and specification, making accurate classification essential for proper GST billing, invoicing and compliance.
    Air conditioners, refrigerators, washing machines and most major home appliances are classified under Chapters 84 and 85 of the Harmonised System of Nomenclature (HSN). They are generally taxed at 18% Goods and Services Tax (GST).
    Correct classification is essential for accurate GST invoicing, Input Tax Credit (ITC) claims and compliance, especially since small variations in product type or specification can affect the applicable HSN code and reporting requirements.
    What are the HSN codes and GST rates for air conditioning machines?
    Air conditioners fall under HSN 8415 and are further classified based on type, capacity and application. The GST rate for all categories below is 18%, as per the current GST classification.
    Appliance Category
    HSN Code
    Description
    GST Rate
    Air Conditioners (General)
    8415
    Air conditioning machines having a motor-driven fan and temperature and humidity changing elements
    18%
    Window or wall-type air conditioners
    8415 10
    Window, wall-mounted or split-system air conditioners
    18%
    Air conditioners for motor vehicles
    8415 20
    Air conditioning systems used in motor vehicles such as cars and buses
    18%
    AC machines incorporating a refrigerating unit
    8415 81
    Air conditioning machines incorporating a refrigerating unit and a reversible heat pump valve
    18%
    Other air conditioning machines with refrigerating unit
    8415 82
    Other AC machines incorporating a refrigerating unit
    18%
    Air conditioning machines without refrigerating unit
    8415 83
    Air handling units and similar systems without an independent refrigerating unit
    18%
    Read more on HSN Code: Full Form, List & GST Rates
    What are the HSN codes and GST rates for refrigerators and freezers?
    Refrigeration appliances fall under HSN 8418, covering household, commercial and industrial cooling equipment. The GST rate for all categories listed below is 18%.
    Appliance Category
    HSN Code
    Description
    GST Rate
    Refrigerators & Freezers (General)
    8418
    Refrigerators, freezers and other refrigerating or freezing equipment
    18%
    Combined refrigerator-freezers
    8418 10
    Refrigerator-freezer combinations with separate external doors
    18%
    Household refrigerators
    8418 21
    Compression-type household refrigerators
    18%
    Chest freezers
    8418 30
    Chest-type freezers with capacity not exceeding 800 litres
    18%
    Upright freezers
    8418 40
    Upright-type freezers with capacity not exceeding 900 litres
    18%
    Refrigerated display furniture
    8418 50 00
    Display counters, cabinets, showcases and similar refrigerated furniture
    18%
    Heat pumps
    8418 61 00
    Heat pumps other than air conditioning machines under heading 8415
    18%
    Other refrigerating or freezing equipment
    8418 69
    18%
    Ice-making machinery
    8418 69 10
    Ice-making machinery for commercial or industrial use
    18%
    Water coolers
    8418 69 20
    Water coolers and similar cooling equipment
    18%
    What are the HSN codes and GST rates for washing machines?
    Washing machines are grouped under HSN 8450, including fully automatic, semi-automatic and commercial variants. Here’s a list of its classification and sub-classifications:
    Appliance Category
    HSN Code
    Description
    GST Rate
    Washing Machines (General)
    8450
    Household or laundry-type washing machines, including washer-dryers
    18%
    Fully automatic washing machines (≤10 kg)
    8450 11 00
    Fully automatic washing machines with dry linen capacity not exceeding 10 kg
    18%
    Washing machines with built-in centrifugal dryer
    8450 12 00
    Washing machines incorporating a built-in centrifugal dryer
    18%
    Other household washing machines (≤10 kg)
    8450 19 00
    Other household washing machines with dry linen capacity not exceeding 10 kg
    18%
    Washing machines (>10 kg)
    8450 20 00
    Household or laundry-type washing machines with dry linen capacity exceeding 10 kg
    What are the HSN codes and GST rates for other common home appliances?
    HSN codes and GST rates for home appliances
    Other everyday home appliances fall under different HSN codes, but most attract a standard 18% GST rate. The table below provides a detailed breakdown of washing machine classifications under HSN 8450.
    Appliance Category
    HSN Code
    Description
    GST Rate
    8450
    18%
    8450 11 00
    18%
    8450 12 00
    18%
    8450 19 00
    18%
    8450 20 00
    Here's an HSN Code Verification and Validation Guide For Businesses
    Conclusion
    Most standard household appliances attract 18% GST under the revised GST rate structure effective from September 2025, making appliance taxation more uniform for businesses and consumers. However, the correct HSN code remains critical for accurate invoicing, smooth GST filing and error-free compliance, especially when product specifications and configurations vary across models.
    Even small differences in appliance type can change classification, so businesses must maintain accurate HSN mapping for every product in their catalogue. Regular cross-checking with GST notifications helps prevent invoicing errors and classification mismatches during audits or assessments.
    Using accounting solutions like TallyPrime can further simplify compliance by automating GST calculations, managing HSN codes, generating accurate invoices and streamlining return filing, helping businesses maintain consistency and reduce manual errors in day-to-day operations.
    Verify GSTIN details online
    cta banner image
    FAQs
    The HSN code 8418 91 applies to parts of refrigeration equipment, such as refrigerator compressors, shelves, crispers, racks, thermostats, sensors, control boards and water dispenser attachments. These items are generally taxed at an 18% GST rate under the current classification.
    Yes, furniture designed to receive refrigerating or freezing equipment falls under HSN 8418, specifically 8418 91 00. It is taxed at an 18% GST rate, similar to other refrigeration-related equipment and parts.
    If installation is billed separately, it generally attracts 18% GST as a service. When installation is bundled with the product, it is treated as a composite supply and taxed at the GST rate applicable to the main appliance.
    Most spare parts and accessories for home appliances attract 18% GST, the same rate as that applicable to many finished appliances. The exact HSN classification depends on the specific component being supplied.
    Yes, companies can claim ITC on appliances like air conditioners, refrigerators and washing machines if they are used for business purposes. ITC is not allowed when these items are used for personal consumption or non-business use, as per GST provisions.
    Published on May 29, 2026
