If you are wondering how to get PDF bank statements into Tally without retyping every line, here is the short answer. Docs by Ira reads a supported digital PDF statement with AI and turns it into structured transactions. You review them, import them into TallyPrime, and then create vouchers or reconcile. This guide walks through the process, the benefits, and the points to watch.
Why are PDF bank statements slowing down your accounting
Ask any accountant what they dread at month-end, and bank statements come up quickly. Every payment, receipt, and bank charge needs an entry in the books. A busy account can show hundreds of lines in a single month, and each line has a date, a narration, and an amount that someone has to check.
The format worsens it. Most banks let you download a statement as a PDF, and that is the file people usually have on hand. TallyPrime can import bank statements, but the standard bank statement import expects a CSV or Excel file downloaded from the bank portal. PDF statements and Excel files converted from PDF are not supported.
So people pick one of two routes:
- Convert the PDF to Excel first. This adds a step, and converted files can have merged columns, shifted dates, or broken rows. Someone then has to clean the sheet before it is usable.
- Type the entries by hand. This process is slow and tiring, and one wrong digit can throw off the balance.
Neither route is pleasant when a filing or audit date is close. Extracting the data is only half the job. You still have to check it and carry it into your books.
What is Docs by Ira?
Docs by Ira is the first capability under TallyIra, Tally's AI for accounting workflows. It converts invoices and supported PDF bank statements into structured data that can be imported into your accounting work in TallyPrime.
A simple way to picture it: you hand over a document, and an assistant reads it, sorts the details into tidy fields, and returns them to you for checking. You decide what goes into your books.
It handles two kinds of work in one plugin:
- Invoices: It extracts details, maps parties and items to existing masters, flags exceptions, and prepares draft vouchers for review. A master is a saved record in Tally, such as a party, an item, or a ledger. A voucher is the basic record of a single transaction.
- Bank statements: It extracts and validates transactions from a supported PDF statement, allowing you to import them into TallyPrime and continue with accounting.
Key benefits of using Docs by Ira for bank statements
The goal is simple. You spend less time typing and more time checking. Here is what that looks like in practice.
- Less manual data entry: AI-powered extraction reads transaction details, so you do not have to key in each line yourself.
- Smarter transaction creation: Intelligent mapping, exception highlighting, and bulk voucher creation make everyday accounting easier.
- Easier bank reconciliation: You import the transactions and use TallyPrime's existing reconciliation features to match them with your books. Bank reconciliation means comparing your books with the bank statement to confirm that both show the same balance and entries.
- You stay in control: You review, verify, and approve before anything is posted.
Together, these help you automate bank entries in Tally without losing the human check that accounting needs. The word "automate" here means the repetitive typing is handled for you. It does not mean entries post on their own.
What makes Docs by Ira different
Plenty of tools can read a document. What sets Docs by Ira apart is where it sits. Three points matter most.
It lives inside your TallyPrime workflow
You go from extracted data to accounting without leaving the Tally ecosystem. There is no separate document-processing platform to sign in to and no external adaptor to transfer results. Bank transactions can be imported and then used to create vouchers or to reconcile.
You keep the final say.
Docs by Ira doesn't push you out of the process. It highlights exceptions so you can see where to fix them and lets you correct information before moving on. Bank transactions will be checked prior to import. It does not claim error-free extraction, and it does not post entries or reconcile on its own.
Mobile gives you a head start.
A bank statement can be uploaded from the TallyIra app, for example, when a client sends a PDF on your phone. The upload can begin there, but processing and accounting are completed in TallyPrime on the desktop. Treat the phone as a convenient front door, not as a full accounting setup.
Capabilities that make the workflow work
These features support the experience from the first upload to the final voucher.
- AI-powered extraction: It reads transaction details from supported bank statement PDFs. For invoices, it reads fields such as party, invoice number, date, amounts, GST, and line items.
- Exception highlighting and validation: It helps surface missing details, mismatches, and other issues so you can review them. It does not guarantee error-free extraction.
- Bulk processing: You can create multiple receipt, payment, and contra vouchers from a statement in a few steps.
- Smart mapping (invoices): It maps parties and items to existing masters, helps create new ones, and detects duplicate invoices, which is what makes bulk invoice upload practical in a busy month. Once you map something, the system learns from your action and handles it next time.
- One plugin, two workflows: Invoice processing and PDF bank statement import share the same docs by Ira experience and page balance.
- No bank-level configuration: Supported digital PDF statements work across banks without conversion to Excel, subject to supported formats. Password-protected PDFs are supported, too.
The last point is the one that answers the question in our title. Because you do not need a converter or a setup for each bank, you can import PDF bank statements directly and spend the saved time on review.
How Docs by Ira works
Here is the full journey for a bank statement. Before you begin, keep a supported digital PDF ready. That means a PDF downloaded from your bank, not a photo or scan of a printout. You also need Docs by Ira enabled on your TallyPrime licence, which requires an active TSS (Tally Software Services) subscription. Registration for TallyIra is done with your TallyPrime serial number.
Step 1: Scan or upload
Upload the statement from the TallyIra app or from TallyPrime. If the bank has locked the PDF with a password, enter it when asked. Once the file is in, you will be able to see its processing status. If something goes wrong, a failure reason appears where relevant, so you know what to fix.
Step 2: Extract and structure
Ira uses AI to read the transaction details, such as the date, the narration, and the debit or credit amount, and arranges them into a structured list.
Step 3: Check
Applicable validation checks run on the extracted data and flag anything that looks off. These checks point you to possible problems. They are a guide, not a replacement for your own review.
Step 4: Review
Check the list extracted against the statement itself. Check the flagged items first, then the opening and closing balances. Handle any issues that need fixing before proceeding. Bank transactions are checked prior to import, and nothing enters your books without being verified. Check the list extracted with the statement itself. Check the flagged items first, then the opening and closing balances. Handle any issues that need fixing before proceeding. Bank transactions are checked prior to import, and nothing enters your books without being verified.
Step 5: Continue in TallyPrime
Bank statement processing and accounting are completed in TallyPrime on a desktop. After import, you have two paths:
- Create vouchers in a few steps. Make multiple receipts, payments, and contra vouchers together. A contra voucher records the movement of money between your cash and bank accounts.
- Use bank reconciliation. Match the imported transactions against your books with TallyPrime's existing subscription. The TallyIra page explains the registration steps.
A quick example
Imagine a small trading firm with a 250-line statement for April. Before, someone converted the PDF to Excel, fixed the broken columns, and typed the missing entries. With Docs by Ira, the accountant uploads the PDF, reviews the extracted list, and corrects the few flagged lines. Then they create the receipt and payment vouchers together and reconcile the rest. The effort shifts from typing to checking, where an accountant's judgement counts.
Here is how the three approaches compare:
Approach |
What you do |
Where the effort goes |
Type each entry. |
Read the PDF and key in every line. |
Data entry |
Convert to Excel first. |
Convert, clean the sheet, then import |
Cleaning and fixing |
Docs by Ira |
Upload, review, import, and create vouchers. |
Reviewing and approving |
If you want to automate bank entries in Tally for multiple clients or banks, the third row is the one that scales.
Who benefits from this workflow?
Small businesses are an important audience for invoice processing. For PDF bank statements, CA and tax consulting firms are especially relevant because they handle statements for many clients each month and must finalise the books before filing and audit dates.
User |
Main need |
Value from Docs by Ira |
CA and tax consultant firms |
Process invoices and bank statements for many clients within deadlines |
Faster turnaround and more time for review, compliance, and advisory work |
Accountants and data-entry operators |
Handle large volumes at month-end. |
Less repetitive entry and support for bulk voucher creation |
Small businesses |
Record supplier invoices and bank transactions without hours of typing. |
Less time on bookkeeping and a quicker path from document to accounting |
Tally Partners |
Help clients adopt efficient workflows. |
A clear way to show the value of TallyPrime's invoice and banking capabilities |
Beyond the statements themselves, these time savings feed into broader cash flow management for SMEs because up-to-date books are easier to trust.
Conclusion
You don't have to convert PDF bank statements or waste an afternoon typing them into your books. Upload a supported digital PDF and let Docs by Ira extract and structure the transactions. Review the information, import the transactions into TallyPrime, and then create multiple vouchers or use TallyPrime’s existing reconciliation features.
Try it on one real statement before your next month-end. Select a bank account that typically takes a long time; upload last month's PDF and record how long it takes compared to your regular practice. Registration for TallyIra runs through your TallyPrime licence, and the banking features in TallyPrime pick up from there once the transactions are imported.
