    What is the Difference Between GSTR-1 and GSTR-3B and When Should I Use Each?
    Tallysolutions
    Tally Solutions
    Updated on Jun 15, 2026
    30 second summary | GSTR-1 is the return where you report your outward supplies, while GSTR-3B is the summary return where you pay your tax. Both are mandatory for most GST-registered businesses. Filing them correctly and on time avoids interest, late fees and blocked input tax credit for your buyers.
    GSTR-1 is a return that records every sale you made during the month or quarter. GSTR-3B is a summary return where you declare your total tax liability and pay it. A business registered under the Goods and Services Tax (GST) must file both returns. One reports what was sold to the government, while the other is used to declare and pay the tax due. Mixing up their purpose or filing one without the other can create compliance issues for both the business and its buyers.
    GSTR-1 vs GSTR-3B: Side-by-side comparison
    Basis
    GSTR-1
    GSTR-3B
    Purpose
    Reports all outward supplies and invoice-level sales details
    Reports tax liability, ITC claims and tax payment summary
    Nature of return
    Detailed statement of transactions
    Self-assessed summary return
    Focus
    Disclosure of sales transactions
    Tax computation and payment
    Level of reporting
    Invoice-wise reporting
    Aggregate-level reporting
    Includes
    B2B invoices, B2C invoices (above ₹2.5 lakh inter-state), exports, debit notes, credit notes, advances and amendments
    Total taxable turnover, CGST, SGST, IGST liability, ITC claimed and net tax payable
    Special transactions covered
    Nil-rated, exempt and non-GST supplies
    Reverse charge liability, ITC reversals, interest and late fees
    Input tax credit (ITC) impact
    Enables buyers to view invoices in GSTR-2B and claim ITC
    Used by taxpayers to claim eligible ITC
    Invoice visibility
    Contains individual invoice details
    Does not contain invoice-wise information
    Tax payment required
    No, it is a disclosure-only return
    Yes, net GST liability must be paid while filing
    Effect of non-filing
    Buyers may be unable to claim ITC on related invoices
    Tax liability remains unpaid and interest continues to accrue
    Primary objective
    Inform the GST system about outward supplies made during the period
    Declare tax liability, adjust ITC and discharge GST dues
    When are GSTR-1 and GSTR-3B due?
    Filing frequency depends on your annual turnover. The table below shows the standard due dates. The GST portal may announce extensions for specific months, so always check the portal for any notifications before filing.
    Return
    Frequency
    Standard due date
    GSTR-1 (turnover up to ₹5 crore)
    Quarterly (QRMP scheme)
    13th of the month following the quarter
    GSTR-1 (turnover above ₹5 crore)
    Monthly
    11th of the following month
    GSTR-3B (turnover up to ₹5 crore)
    Quarterly (QRMP) or monthly (opt-out)
    22nd or 24th of the month following the quarter, depending on the state
    GSTR-3B (turnover above ₹5 crore)
    Monthly
    20th of the following month
    Why should GSTR-1 be filed before GSTR-3B?
    GSTR-1 and GSTR-3B are connected but serve different purposes in the compliance chain. GSTR-1 feeds the invoice data that populates GSTR-2B for your buyers. GSTR-3B is how you settle the tax liability with the government. File GSTR-1 first so your buyers get timely ITC, then file GSTR-3B to pay what is owed.
    Note: A mismatch between the two returns, where GSTR-3B shows a lower liability than what your GSTR-1 invoices add up to, can trigger a notice from the GST department.
    How can errors be corrected in GSTR-1 and GSTR-3B?
    GSTR-1 allows amendments. If you reported an incorrect invoice, you can correct it in a subsequent month's GSTR-1 through the amendment tables. GSTR-3B does not have a formal amendment mechanism. Errors in GSTR-3B are corrected by adjusting the liability or ITC claim in the next month's GSTR-3B, along with any interest due.
    Amendments to GSTR-1 from a previous financial year (FY) must be only up to November 30 of the following financial year or before filing the annual return for that year, whichever is earlier. Missing this window means the correction cannot be made through the return system.
    What happens if GSTR-1 or GSTR-3B is filed late?
    Late filing of either return attracts fees under Section 47 of the CGST Act, 2017. In the case of GSTR-3B, any delay in filing can also trigger interest on the outstanding tax amount. The interest is calculated at 18% per year from the return due date until the tax is fully paid. For GSTR-1, there is no tax to pay, so only the late fee applies, but the delay still blocks ITC for your buyers until the return is filed.
    If GSTR-3B is not filed for two consecutive months (or one quarter under QRMP), the GST portal may block the business's e-way bill generation. This effectively stops all taxable movement of goods.
    Conclusion
    GSTR-1 and GSTR-3B are not interchangeable. One records what you sold, while the other settles the tax liability with the government. Filing both accurately and in the correct sequence, with GSTR-1 filed before GSTR-3B and before the applicable deadlines, forms the foundation of GST compliance. Keeping your books aligned with your GST returns is much easier when your accounting software links invoices directly to return data.
    TallyPrime does this automatically, pulling invoice data from your books into the GST return forms so you are not reconciling two sets of records manually.
    Verify GSTIN details online
    cta banner image
    FAQs
    No. GST returns follow a prescribed filing sequence. For a given tax period, GSTR-1 must be submitted before GSTR-3B becomes available for filing on the GST portal.
    If the turnover reported in GSTR-1 exceeds the liability declared in GSTR-3B, the discrepancy may be treated as a short payment of tax. Under Rule 88C of the CGST Rules, the taxpayer can receive an automated notice requiring either payment of the differential amount or a justification for the mismatch.
    Yes. Even if you had no outward supplies in a period, you must file a nil GSTR-1 by the due date.
    No. Once GSTR-3B is submitted and the taxes are paid, it cannot be revised. Any error, whether an over-claimed ITC or an under-reported liability, must be corrected in the next period's GSTR-3B.
    No. Taxpayers enrolled under the Composition Scheme follow a different compliance framework. They submit CMP-08 every quarter to report and pay tax and file GSTR-4 once a year. Filing GSTR-1 and GSTR-3B is not required under this scheme.
    Published on June 15, 2026
