    Washing Machine HSN Code: GST Rate, Classification & Invoicing Guide for Businesses
    Tallysolutions
    Tally Solutions
    Jul 14, 2026
    30 second summary | Washing machines are classified under HSN code 8450 and attract 18% GST from 22 September 2025. Businesses must use the correct HSN code, issue GST-compliant invoices, comply with GSTR-1 HSN reporting requirements and satisfy input tax credit (ITC) conditions to ensure GST compliance and avoid penalties.
    Washing machines are classified under Harmonised System of Nomenclature (HSN) code 8450 and attract 18% GST. Using the correct HSN code is essential for accurate GST invoicing, GSTR-1 HSN reporting and claiming eligible ITC, helping businesses remain GST-compliant.
    HSN 8450 falls under Chapter 84 of the HSN schedule and covers "Household or laundry-type washing machines, including machines which both wash and dry; parts thereof." It includes household and commercial washing machines, including automatic and semi-automatic models, along with their parts.
    What is the HSN classification of washing machines?
    Washing machines are classified under HSN code 8450, with further sub-classifications based on the machine type, dry linen capacity and parts. The applicable HSN code is as follows:
    Description
    HSN code
    Household or laundry-type washing machines (including machines that both wash and dry), each with a dry linen capacity not exceeding 10 kg
    8450
    Household or laundry-type washing machines (including machines that both wash and dry), each with a dry linen capacity not exceeding 10 kg (fully automatic machines)
    84501100
    Household or laundry-type washing machines (including machines that both wash and dry), each with a dry linen capacity not exceeding 10 kg (other machines with built-in centrifugal drier)
    84501200
    Household or laundry-type washing machines (including machines that both wash and dry), each with a dry linen capacity not exceeding 10 kg (other machines)
    84501900
    Household or laundry-type washing machines (including machines that both wash and dry), each with a dry linen capacity exceeding 10 kg
    84502000
    Parts for household or laundry-type washing machines (including machines that both wash and dry)
    845090
    Parts for household-type washing machines (including machines that both wash and dry)
    84509010
    Other parts for household or laundry-type washing machines (including machines that both wash and dry)
    84509090
    What is the GST rate on washing machines?
    The Goods and Services Tax (GST) rate on washing machines is 18% with effect from 22 September 2025. Following the GST rate rationalisation approved at the 56th GST Council meeting, washing machines were not included among the household and consumer products receiving a lower tax rate. Accordingly, all household or laundry-type washing machines, including washer-dryer combinations classified under HSN 8450, continue to attract 18% GST.
    Businesses supplying these products must charge the applicable GST on both domestic and commercial sales unless a specific exemption applies under GST law.
    What are the recent regulatory changes affecting businesses?
    Here are the key regulatory changes related to washing machine invoicing:
    • Mandatory HSN reporting in GSTR-1 (May 2025 onwards)
    From May 2025, the GST portal mandates HSN-wise reporting in Table 12 of GSTR-1/1A. Key requirements include:
    • Taxpayers with an Annual Aggregate Turnover (AATO) of up to ₹5 crore must report 4-digit HSN codes.
    • Taxpayers with an AATO above ₹5 crore must report 6-digit HSN codes.
    • Manual entry of HSN codes is no longer permitted. Taxpayers must select the appropriate code from a predefined dropdown, after which the portal auto-populates the corresponding description.
    • Table 12 has been bifurcated into separate tabs for B2B and B2C supplies, enabling HSN-wise validation for each category.
    • Mandatory ISD mechanism for ITC distribution (April 2025 onwards)
    From 1 April 2025, businesses with multiple GST registrations under the same PAN must distribute common ITC exclusively through the Input Service Distributor (ISD) mechanism.
    For washing machine businesses with multiple GST registrations, including factories, regional warehouses and showrooms, common input services such as auditing, software licensing, security, banking and consultancy must be distributed through the ISD mechanism. Non-compliance can result in:
    • Denial of ITC claims
    • Recovery of incorrect ITC along with applicable interest
    • A penalty of at least ₹10,000 or the value of the incorrect ITC, whichever is higher
    Can businesses claim ITC?
    Yes. Businesses can claim ITC on washing machines purchased for use in the course or furtherance of business, such as for resale, rental, commercial laundry, staff accommodation, hotels, hospitals or as eligible capital goods, provided the following GST conditions are satisfied:
    • You must be GST-registered.
    • The washing machine must be used, or intended to be used, in the course or furtherance of business.
    • You must possess a valid tax invoice or other prescribed document issued by the supplier.
    • The washing machine must have been received. If it is supplied in multiple lots, ITC can be claimed only after the final lot is received.
    • The supplier must upload the invoice in their GST return, and it should be reflected in your GSTR-2B.
    • The supplier must pay the GST collected to the government. ITC is available only when the tax has actually been paid.
    • You must file your GST return (GSTR-3B) to claim the credit.
    • You must pay the supplier the invoice value, including GST, within 180 days. If payment is not made within this period, the ITC must be reversed, including any applicable interest. The credit can be reclaimed once payment is made.
    • ITC must be claimed within the prescribed time limit, that is, by 30 November following the end of the relevant financial year or before filing the annual return for that financial year, whichever is earlier.
    What are the GST invoicing requirements for washing machine businesses?
    GST-registered businesses selling washing machines must issue a tax invoice that complies with Rule 46 of the CGST Rules. The invoice must include the following mandatory particulars:
    Invoice Field
    Requirement
    Supplier's name and address
    Full legal name as per GST registration
    GSTIN of supplier
    Mandatory
    Invoice number
    Sequential, unique per financial year
    Invoice date
    Date of supply
    HSN code
    4-digit (AATO ≤ ₹5 Cr) or 6-digit (AATO > ₹5 Cr)
    Description of goods
    Model name, capacity, type (front-load/top-load, etc.)
    Quantity
    In applicable unit (numbers/pieces)
    Taxable value
    Pre-GST price
    CGST/SGST or IGST
    Rate and amount separately
    Total invoice value
    Including GST
    Place of supply
    State code/name
    Buyer's GSTIN (for B2B)
    If the buyer is a registered dealer
    Signature
    Physical or digital
    A tax invoice must be issued for taxable B2C sales; only for very small supplies (below ₹200, to an unregistered buyer who does not require an invoice) may a consolidated invoice be raised at day-end.
    Separately, for GSTR-1 reporting, inter-state B2C supplies above ₹1 lakh per invoice (reduced from ₹2.5 lakh with effect from 1 August 2024) must be reported invoice-wise as B2C (Large); smaller B2C supplies are reported as consolidated, rate- and state-wise summaries. The appropriate HSN code must be reported in GSTR-1 wherever required.
    How can businesses ensure GST compliance for washing machine sales?
    Businesses can ensure GST compliance by correctly classifying products, issuing accurate invoices, reconciling ITC regularly and keeping up with GST law changes.
    Some practical tips include:
    • Map SKUs to HSN codes in your accounting software. Every washing machine model in your product catalogue should be pre-tagged with its correct HSN code in your billing system to minimise errors at the point of sale.
    • Invoice washing machines and spare parts separately. If you supply a washing machine along with spare parts, such as a pump or control board, list them as separate line items with their respective HSN codes and values to avoid classification disputes.
    • Reconcile your GSTR-2B every month. ITC is available only on invoices reflected in your GSTR-2B. If a supplier delays filing, the credit will appear in a later tax period. Regular reconciliation helps prevent ineligible ITC claims.
    • Distinguish goods from services in repair and maintenance transactions. When a technician replaces a part, bill the part (goods) under the applicable HSN code and the service charge separately under the appropriate SAC (Service Accounting Code).
    • Keep track of GST rate changes. The GST Council may revise GST rates. Businesses should verify the applicable rates on the official CBIC website before updating their invoicing systems after any Council meeting.
    Conclusion
    Using the correct HSN code, charging the applicable GST rate and issuing GST-compliant invoices are essential for avoiding errors in return filing, claiming eligible ITC and reducing the risk of disputes or penalties. As GST compliance requirements continue to evolve, maintaining accurate product classification and financial records is critical.
    With TallyPrime, businesses can streamline invoicing, manage HSN codes, maintain organised records and support accurate GST compliance with greater efficiency.
    Verify GSTIN details online
    cta banner image
    Published on July 14, 2026
