    Teflon Tape HSN Code: GST Rate, Classification & Invoicing Guide for Businesses
    Tallysolutions
    Tally Solutions
    Jun 16, 2026
    30 second summary | Teflon tape (PTFE tape) is generally classified under Chapter 39 of the HSN schedule as a plastic-based sealing product and attracts 18% GST. Businesses must report the correct HSN code on invoices, comply with e-invoicing rules where applicable and follow the updated GSTR-1 HSN reporting requirements introduced from May 2025.
    Teflon tape, commonly known as PTFE (polytetrafluoroethylene) tape or plumber's tape, is a thin, flexible sealing material used to seal pipe threads, prevent leaks, and reduce friction in threaded joints. It is used in plumbing, gas lines, hydraulics, electrical insulation, and various industrial processes. The name "Teflon" is a registered brand name owned by Chemours (formerly DuPont), though the product is sold generically as PTFE tape or thread seal tape.
    From a tax classification perspective, Teflon tape is treated as a plastic product under India's GST regime, since PTFE is a synthetic polymer and therefore falls under the broader category of plastics and articles thereof.
    What is the HSN code for teflon tape?
    There is no single dedicated tariff entry for "Teflon tape" in India's Harmonised System of Nomenclature (HSN) schedule. Businesses must identify the most appropriate code based on the product's physical form and characteristics. As a thin, flat strip of plastic supplied in rolls and used for sealing, Teflon tape is classified under Chapter 39 – Plastics and Articles Thereof.
    Here is the detailed breakdown of Chapter 39:
    Description
    HSN
    Self-adhesive plastic products in rolls with a width not exceeding 20 cm
    39191000
    Plastic stickers (self-adhesive)
    39199010
    Cellulose adhesive tape
    39199020
    Self-adhesive plastic sheets and tapes (other)
    39199090
    Rigid plain polyethylene sheets
    39201011
    Flexible plain polyethylene sheets
    39201012
    Bleached polyester fabrics made from mixed filaments
    39201013
    Other polyethylene sheets
    39201019
    Rigid plain sheets of ethylene polymers (other)
    39201091
    Flexible plain sheets of ethylene polymers (other)
    39201092
    Other products of ethylene polymers
    39201099
    Rigid plain sheets of propylene polymers
    39202010
    Flexible plain sheets of propylene polymers
    39202020
    Other sheets and films of propylene polymers
    39202090
    Rigid plain sheets of styrene polymers
    39203010
    Flexible plain sheets of styrene polymers
    39203020
    Other sheets and films of styrene polymers
    39203090
    Geomembranes made of polyethylene conforming to IS 16352
    39204300
    Sheets and films of vinyl chloride polymers
    39204900
    Rigid plain acrylic sheets made of poly(methyl methacrylate) (PMMA)
    39205111
    Flexible plain acrylic sheets made of poly(methyl methacrylate) (PMMA)
    39205112
    PMMA sheets (other)
    39205119
    Other rigid plain acrylic sheets made of poly(methyl methacrylate)
    39205191
    Other flexible plain acrylic sheets made of poly(methyl methacrylate)
    39205192
    Other products made of poly(methyl methacrylate)
    39205199
    Rigid plain polyacrylate sheets
    39205911
    Flexible plain polyacrylate sheets
    39205912
    Polyacrylate sheets (other)
    39205919
    Other rigid plain acrylic polymer sheets
    39205991
    Acrylic polymer products (other)
    39205992
    Other acrylic polymer sheets and films
    39205999
    Rigid plain polycarbonate sheets
    39206110
    Flexible plain polycarbonate sheets
    39206120
    Cotton carpets (excluding durries)
    39206190
    Rigid plain poly(ethylene terephthalate) (PET) sheets
    39206210
    Flexible plain poly(ethylene terephthalate) (PET) sheets
    39206220
    Other poly(ethylene terephthalate) products
    39206290
    Rigid plain unsaturated polyester sheets
    39206310
    Polyester packaging film (other)
    39206320
    Other unsaturated polyester sheets
    39206390
    Rigid plain polyester packaging film
    39206911
    Flexible plain polyester packaging film
    39206912
    Cellulose nitrate (celluloid) sheets
    39206919
    Rigid plain polyester sun and dust control film
    39206921
    Flexible plain polyester sun and dust control film
    39206922
    Other polyester sun and dust control film
    39206929
    Rigid plain polyester film
    39206931
    Flexible plain polyester film
    39206932
    Other polyester film
    39206939
    Rigid plain polyester sheets
    39206991
    Flexible plain polyester sheets
    39206992
    Other non-cellular polyester sheets
    39206999
    Rigid plain sheets of other cellulose derivatives
    39207111
    Transparent cellophane film
    39207119
    Plain cellulose nitrate (celluloid) sheets
    39207121
    Oil-extended styrene butadiene rubber
    39207129
    Regenerated cellulose products (other)
    39207191
    Transparent cellophane products (other)
    39207192
    Flexible plain regenerated cellulose sheets (other)
    39207199
    Flexible plain vulcanised fibre sheets
    39207210
    Other vulcanised fibre sheets
    39207220
    Rigid plain poly(vinyl butyral) sheets
    39207290
    Flexible plain plasticised cellulose acetate sheets
    39207311
    Other non-plasticised cellulose acetate sheets
    39207312
    Rigid plain non-plasticised cellulose acetate sheets
    39207319
    Rigid plain plasticised cellulose acetate sheets
    39207321
    Plasticised cellulose acetate sheets
    39207322
    Other plasticised cellulose acetate sheets
    39207329
    Frozen swine meat, pre-packaged
    39207391
    Flexible plain cellulose acetate sheets
    39207392
    Other plates, sheets and films of cellulose acetate plastics
    39207399
    Rigid cellulose nitrate (celluloid) sheets
    39207911
    Flexible cellulose nitrate (celluloid) sheets
    39207912
    Other cellulose nitrate (celluloid) sheets
    39207919
    Other cellulose derivative sheets
    39207991
    Rigid plain cellulose acetate sheets
    39207992
    Flexible plain sheets of other cellulose derivatives
    39207999
    39209110
    Flexible plain poly(vinyl butyral) sheets
    39209111
    Other poly(vinyl butyral) sheets
    39209112
    Rubber conveyor belts reinforced with plastics containing less than 25% rubber
    39209119
    Flexible plain poly(vinyl butyral) products
    39209120
    Other products of poly(vinyl butyral)
    39209190
    Rigid plain polyamide fluoride film
    39209211
    Flexible plain polyamide fluoride film
    39209212
    Polyamide fluoride film (other)
    39209219
    Rigid plain polyamide sheets
    39209291
    Flexible plain polyamide sheets
    39209292
    Other polyamide products
    39209299
    Rigid plain sheets of amino resins
    39209310
    Flexible plastic sheets of amino resins
    39209320
    Other amino resin plastic products
    39209390
    Rigid plain sheets of phenolic resins
    39209410
    Flexible sheets of phenolic resins
    39209420
    Other phenolic resin products
    39209490
    Other poly(vinyl acetate) products
    39209911
    Regenerated cellulose-based plastic products
    39209912
    Flexible plain poly(vinyl acetate) sheets
    39209919
    Rigid plain vinyl plastic films, sheets and strips
    39209921
    Flexible vinyl plastic films, sheets and strips
    39209922
    Other vinyl plastic products
    39209929
    Rigid plain vinyl chloride-vinyl acetate copolymer sheets
    39209931
    Flexible plain vinyl chloride-vinyl acetate copolymer sheets
    39209932
    Other vinyl chloride-vinyl acetate copolymer sheets
    39209939
    Rigid plain PTFE (polytetrafluoroethylene) sheets
    39209941
    Flexible plain PTFE (polytetrafluoroethylene) sheets
    39209942
    Other PTFE sheets
    39209949
    Reflective sheeting made of plastics
    39209951
    Retro-reflective plain sheeting
    39209952
    Other retro-reflective plastic sheeting
    39209959
    Rigid plain poly(vinyl acetate) sheets
    39209960
    Other rigid plain plastic sheets
    39209991
    Flexible plain plastic sheets
    39209992
    Other plastic sheets, films and products
    39209999
    Cellular plastics made from styrene polymers
    39211100
    Cellular plastics made from vinyl chloride polymers
    39211200
    Flexible cellular plastics made from polyurethane
    39211310
    Other cellular plastics made from polyurethane
    39211390
    Cellular plastics made from regenerated cellulose
    39211400
    39211900
    Thermocol products
    39219010
    Rigid lacquered sheets of vinyl polymers
    39219021
    Flexible lacquered sheets of vinyl chloride polymers
    39219022
    Rigid metallised polymer sheets
    39219023
    Flexible metallised PVC sheets
    39219024
    Rigid laminated sheets of vinyl polymers
    39219025
    Flexible laminated sheets of vinyl chloride polymers
    39219026
    Other products of vinyl chloride polymers
    39219029
    Rigid lacquered cellulose sheets
    39219031
    Flexible lacquered sheets of regenerated cellulose
    39219032
    Metallised cellulose sheets
    39219033
    Flexible regenerated cellulose sheets
    39219034
    Rigid laminated cellulose sheets
    39219035
    Flexible laminated sheets of regenerated cellulose
    39219036
    Handles of cutlery made of base metal and other products
    39219039
    Other rigid lacquered plastic sheets
    39219091
    Other flexible lacquered plastic sheets
    39219092
    Other rigid metallised plastic sheets
    39219093
    Other flexible metallised plastic sheets
    39219094
    Other rigid laminated plastic sheets
    39219095
    Other flexible laminated plastic sheets
    39219096
    Other plastic plates, sheets, films, foils and strips
    39219099
    Which GST slab applies to teflon tape?
    Following the GST rate rationalisation approved in the 56th GST Council Meeting and effective from 22 September 2025, Teflon tape remains subject to 18% GST. It is classified as a plastic-based industrial and plumbing product and is therefore not covered under the concessional 5% GST category for essential goods. Suppliers are required to levy GST at 18% on the taxable value of the product and disclose the relevant HSN code in tax invoices and GST returns.
    This rate applies to Teflon tape used for thread sealing, plumbing connections, gas pipelines and various industrial maintenance purposes across India.
    Invoicing requirements for teflon tape
    Correctly mentioning HSN codes on tax invoices is mandatory under GST rules. As per Notification No. 78/2020 – Central Tax dated 15 October 2020, the number of HSN digits required depends on the supplier's Aggregate Annual Turnover (AATO):
    HSN Digits Required on Invoice
    Up to ₹5 crore
    4-digit HSN (for B2B); optional for B2C
    Above ₹5 crore
    6-digit HSN (for all supplies)
    Exporters
    8-digit HSN mandatory
    What are the e-invoicing rules for teflon tape suppliers?
    For businesses supplying Teflon tape in B2B transactions, e-invoicing (generating an Invoice Reference Number via the Invoice Registration Portal) is mandatory if annual turnover exceeds ₹5 crore. Additionally, from 1 April 2025, businesses with AATO of ₹10 crore or more must upload e-invoices to the IRP within 30 days of the invoice date.
    Missing this time limit effectively makes the invoice invalid under Rule 48(4) of the GST rules. This means the recipient cannot claim ITC, and there are hefty penalties for non-compliance, which can reach up to ₹10,000 per missing invoice and ₹25,000 per incorrect invoice.
    GSTR-1 reporting guide
    The GST Network (GSTN) implemented Phase 3 of HSN code reporting in Table 12 of GSTR-1/GSTR-1A, effective from the May 2025 return period. Key changes include:
    • Table 12 is now split into two tabs: B2B Supplies and B2C Supplies. HSN summary must be entered separately for each.
    • B2B Supplies (Table 12A) requires taxpayers to report the correct HSN code, unit of quantity (UQC) and value for all B2B supplies. System validations cross-check these values across the return.
    • B2C Supplies (Table 12B) is optional for taxpayers with AATO up to ₹5 crore in the previous financial year, as clarified by CBIC.
    • Manual HSN entry is disallowed. Taxpayers must now select HSN codes from a system-generated dropdown in the GSTN portal, reducing errors.
    • Table 13 is now mandatory for all taxpayers from May 2025. It requires listing all documents issued (invoices, credit notes and debit notes) during the tax period.
    Conclusion
    As GST compliance becomes increasingly technology-driven, businesses should move beyond basic tax reporting and focus on creating standardised product masters, automated validation checks and audit-ready documentation processes. Regular reconciliation between sales, inventory and tax records can help identify discrepancies before they become compliance risks.
    Adopting an integrated business management solution such as TallyPrime can simplify classification, improve reporting accuracy and help businesses stay prepared for evolving GST requirements without disrupting day-to-day operations.
    Verify GSTIN details online
    cta banner image
    FAQs
    The classification may depend on whether the kit is supplied as a composite or mixed supply. The principal product in the kit often determines the GST treatment.
    Exports are classified as zero-rated supplies. You can export without paying Integrated GST (IGST) by filing an annual Letter of Undertaking (LUT) on the GST Portal, or you can pay the IGST and claim a refund.
    Businesses should retain tax invoices, purchase orders, delivery challans, e-way bills (where applicable), payment records, and stock registers for audit and compliance purposes.
    An e-way bill is required on the E-Way Bill System whenever your consignment value exceeds ₹50,000. Keep in mind that some state governments set different (often higher) limits for intrastate movement, so always verify your specific state's threshold before transport.
    Generally, colour variations such as white, yellow, pink or green do not determine classification. The product's material composition and nature are more important.
    Published on June 16, 2026
