    Screwdriver HSN Code “GST Rate, Classification & Invoicing Guide for Businesses”
    Tallysolutions
    Tally Solutions
    Jun 2, 2026
    30 second summary | Screwdrivers and most hand tools are classified under GST Chapter 82. Screwdrivers fall under HSN 8205 and attract 18% GST. Other tools, such as hammers, spanners and measuring tapes, also fall under Chapter 82, while items such as grinding wheels (HSN 6804) and carbon brushes (HSN 8545) are classified separately. Correct HSN use ensures GST compliance and accurate invoicing.
    Screwdrivers fall under HSN 8205 in GST, which covers general-purpose hand tools used for repair, assembly and maintenance work. These tools are part of Section XV, Chapter 82 and are typically subject to 18% GST, making correct classification important for accurate invoicing and compliance.
    HSN 8205 includes manually operated tools not specifically classified elsewhere, commonly used across electrical, construction and industrial applications. While most hand tools follow similar GST treatment, proper classification still depends on the tool’s exact design and function, especially when it overlaps with specialised equipment.
    What is the HSN code for screwdrivers & hand tools with GST rate?
    After the GST rate rationalisation announced at the 56th GST Council meeting in September 2025, most standard industrial and hardware products continue under the revised GST slabs of 5%, 18% and 40%.
    Screwdrivers and related hand tools fall under the standard 18% GST slab in India, as they are treated as industrial and utility goods rather than essential items. The revised GST structure, effective from 22 September 2025, has simplified classification but retained hand tools in the regular tax bracket.
    The table below provides a comprehensive classification of screwdrivers and related tools:
    Category
    HSN Code / Number
    Description
    Hand tools (general category)
    8205
    Covers hand-operated tools not elsewhere specified.
    Screwdrivers
    8205 40 00
    Manual screwdrivers used for fastening screws.
    Spanners (adjustable)
    8204 12 00
    Adjustable spanners and wrenches.
    Spanners (non-adjustable)
    8204 11 00
    Fixed spanners.
    Socket wrenches
    8204 20 00
    Socket sets and similar tools.
    Allen keys (hex keys)
    8204 11 20
    Non-adjustable hand-operated wrenches, which includes hex keys
    Hammers
    8205 20 00
    Hammers and sledge hammers.
    Pliers / crimping tools
    8203 20 00
    Tools used for gripping, cutting and crimping.
    Hacksaw blades
    8202 91 00
    Blades used in hand-operated saws.
    Knives (tool/utility)
    8211
    Knives with cutting blades used for industrial or utility purposes.
    Measuring tapes
    9017 80 10
    Measuring tapes and similar measuring instruments.
    Electrical testers
    9030 33 00
    Voltage testers and electrical measuring devices.
    Grinding wheels
    6804
    Abrasive grinding wheels and discs.
    Carbon brushes
    8545 20 00
    Carbon brushes used in electrical motors.
    Brooms
    9603 10 00
    Brooms and brushes made of natural or synthetic fibres.
    Mops
    9603 90 00
    Mops and similar cleaning tools.
    How to assign the right screwdrivers, HSN code and similar tools
    Accurate HSN classification is important for correct GST application and smooth invoicing. Since hand tools cover a wide range of products, the correct code depends on how the tool is designed and used rather than just its general category.
    When determining the appropriate HSN code, consider:
    • Type of tool: Whether it is a screwdriver, hammer, spanner or another hand tool.
    • Primary function of the tool: Fastening, cutting, gripping, measuring or cleaning.
    • Material and construction: Such as steel tools, insulated tools or specialised builds.
    • Mode of operation: Purely manual tools versus electrically assisted or testing devices.
    Conclusion
    Screwdrivers and most commonly used hand tools fall under Chapter 82 and are generally taxed at 18% GST. However, classification is not always uniform, as tools like measuring devices, electrical components or cleaning equipment may fall under different chapters depending on their specific function.
    For businesses that deal with screwdrivers and related tools, managing accurate HSN classification across multiple product types can quickly become complex, especially when maintaining consistent, compliant invoicing. Using a reliable accounting solution like TallyPrime helps reduce GST errors and simplifies day-to-day compliance by centralising taxation, inventory tracking, e-invoicing, accounting and reporting in one system.
    Verify GSTIN details online
    cta banner image
    FAQs
    No, screwdrivers and most hand tools are not exempt from GST and generally attract 18% GST under their respective HSN codes. These tools are considered standard industrial and consumer goods. There are typically no specific exemptions available, although classification may differ for specialised items; however, the tax rate remains largely consistent across common hand tools.
    Yes, registered taxpayers can claim Input Tax Credit (ITC) on the purchase of screwdrivers and similar tools, provided they are used for business purposes and supported by valid GST invoices. ITC is not available for personal use or non-business activities.
    An e-way bill is required if the consignment value exceeds ₹50,000, as per GST rules. Additionally, e-invoicing may apply depending on the business’s turnover and compliance requirements.
    If screwdrivers are sold as part of a tool kit, GST treatment depends on how the items are packaged and invoiced. If sold as a single set, the entire kit is usually taxed based on the principal item or the highest applicable GST rate in the set (commonly 18%). If items are listed separately, each tool is taxed under its respective HSN code.
    If screwdrivers are sold with interchangeable bits or attachments as a set, they are generally classified under the same HSN code as the main tool (82054000), provided the screwdriver is the primary component. If sold separately, each item should be classified individually.
    Published on June 2, 2026
