    Plywood HSN Code “GST Rate, Classification & Invoicing Guide for Businesses”
    Tallysolutions
    Tally Solutions
    Jun 2, 2026
    30 second summary | Plywood falls under HSN 4412 (Chapter 44: Wood and Articles of Wood) and is generally taxed at 18% GST, including marine, decorative and blockboard varieties. Proper classification, correct HSN usage, accurate invoicing and ITC compliance are key to smooth GST filing.
    Plywood is classified under HSN 4412 in Chapter 44 (Wood and Articles of Wood) and is taxed under GST as an engineered wood product widely used in construction, furniture and interiors. This classification directly impacts how businesses apply Goods and Services Tax (GST) rates, issue invoices and claim input tax credit, making accurate categorisation essential for compliance and cost control.
    HSN (Harmonised System of Nomenclature) 4412 covers plywood, veneered panels and similar laminated wood products made by bonding layers of wood under pressure. These products are treated as standardised goods under GST, ensuring uniform tax application across most plywood categories.
    While the general GST rate remains consistent, classification may vary slightly depending on thickness, wood type, surface finish and end use, which businesses must account for when invoicing and reporting.
    What are the different plywood HSN codes and how is plywood classified?
    The table below outlines the key HSN codes and descriptions related to plywood and related wood-based products:
    Category
    HSN Code / Number
    Description
    Plywood, veneered panels and laminated wood
    4412
    Covers plywood sheets, veneered panels and similar laminated wood products used in furniture and construction.
    Bamboo plywood
    4412 10 00
    Plywood made using bamboo layers or strips.
    Non-bamboo wood sheets plywood
    4412 34
    Classifies specialised plywood made from non-bamboo wood sheets, where each ply is 6 mm or less, and at least one outer ply is a specific non-coniferous (hardwood) type.
    Common sub-codes include:
    4412 34 10: Decorative plywood with non-coniferous outer ply
    4412 34 20: Tea chest panels (non-coniferous)
    4412 34 30: Marine/aircraft plywood with non-coniferous outer ply
    4412 34 40: Cutting and trimmings of plywood (width 5 cm)
    4412 34 90: Other
    Decorative / laminated plywood
    4412 31
    Includes plywood with decorative surface layers or laminates used in interiors and furniture.
    Non-coniferous plywood
    4412 33
    Covers plywood, consisting solely of sheets of wood, with at least one outer ply of specific non-coniferous wood (such as alder, ash, birch or eucalyptus), where each ply does not exceed 6 mm thickness.
    Main sub-classifications include:
    4412 33 10: Decorative plywood
    4412 33 30: Marine and Aircraft plywood
    4412 33 40: Cutting and trimmings of plywood
    4412 33 90: Other, with at least one outer ply of non-coniferous wood.
    Coniferous plywood
    4412 39
    Includes plywood and laminated wood products, specifically featuring outer plies made of coniferous wood where each layer is 6 mm thick or less.
    Sub-classifications cover various types, including decorative plywood (44123910), tea chest panels (44123920), marine/aircraft plywood (44123930), small cuttings (44123940) and other coniferous plywood (44123990).
    Veneered panels
    4412 41
    Pertains to plywood, veneered panels and similar laminated wood products that contain at least one outer ply of tropical wood (e.g., Acacia, Teak, Meranti). Its common applications are in furniture manufacturing, decorative panels and structural plywood.
    Laminated Veneered Lumber (LVL)
    4412 49
    Refers to Laminated Veneered Lumber (LVL) that is characterised as "Other, with both outer plies of coniferous wood". It’s commonly used in structural applications, construction and sometimes in furniture manufacturing.
    Blockboard (tropical outer ply)
    4412 51
    Refers to plywood, veneered panels and similar laminated wood that feature at least one outer ply of tropical wood. This classification includes products like blockboard, laminboard and battenboard.
    Blockboard (non-coniferous)
    4412 52
    Covers wood products classified as plywood, veneered panels and similar laminated wood, specifically featuring at least one outer ply of non-coniferous wood. It includes products like blockboard, laminboard and battenboard, commonly used in construction and furniture making.
    Blockboard (coniferous)
    4412 59
    Other plywood, veneered panels and similar type of laminated wood, specifically featuring both outer plies of coniferous wood. It is commonly used for trade in blockboard, laminboard and battenboard.
    Blockboard / flush doors
    4412 99
    Includes blockboard, flush doors and similar engineered wood boards.
    Fire-retardant plywood
    4412 94
    Special plywood treated for fire resistance, used in commercial and safety applications.
    Particle board and similar boards
    4410
    Includes particle board, Medium Density Fibreboard (MDF) and other engineered wood alternatives to plywood.
    Builders’ joinery and carpentry (doors, frames)
    4418
    Includes wooden doors, window frames and structural wood components.
    What is the GST rate on plywood?
    Following the GST rate rationalisation approved at the 56th GST Council Meeting held in September 2025, the GST structure was simplified into three major slabs: 5%, 18% and 40%. Under the revised framework effective from 22 September 2025, plywood products were placed under the standard 18% GST slab, replacing the earlier 28% rate applicable on several plywood and laminated wood categories.
    This reduction has lowered the tax burden on furniture manufacturers, builders, interior contractors and hardware businesses, while also improving compliance in the wood and construction sector.
    How to choose the correct plywood HSN code?
    Since different wood-based products may look similar but fall under different headings, businesses must assess specific product characteristics before assigning a code. To classify plywood accurately, consider:
    • Type of product: plywood, blockboard, MDF, etc.
    • Surface finish: decorative, laminated or plain
    • Usage: furniture, construction or structural use
    • Manufacturing process: layered plywood vs compressed boards
    Choosing the correct wood HSN code ensures accurate GST application and helps avoid classification errors during invoicing and compliance.
    What are the common mistakes in plywood HSN classification?
    Even though plywood classification seems simple, businesses often make errors that affect GST compliance:
    • Using incorrect HSN codes for different wood products: Plywood (4412), MDF/particle board (4410) and wooden doors (4418) are different categories. Mixing them can lead to incorrect reporting.
    • Assuming all wood products have the same classification: While the GST rate may be similar (18%), classification depends on the product type, structure and use.
    • Incorrect invoicing of mixed products: Bundling plywood with other materials (like hardware or laminates) without proper breakup can create compliance issues.
    • Ignoring product specifications: Factors such as veneer type, thickness and treatment (e.g., fire-retardant) may affect the exact sub-classification.
    Conclusion
    Plywood classification under GST is relatively straightforward, with most products falling under HSN 4412 and attracting a standard 18% GST rate. However, differences between plywood, MDF, blockboard and other wood products make correct classification essential for compliance.
    For businesses dealing in multiple wood-based products, maintaining accurate HSN mapping and structured invoicing is key to avoiding errors and ensuring smooth GST filings. Using solutions like TallyPrime can help automate classification, efficiently manage invoices and ensure GST compliance, making day-to-day operations easier and more reliable.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes, registered businesses can generally claim ITC on plywood purchases if the plywood is used for business purposes and proper GST invoices are maintained. However, ITC restrictions may apply to the construction of immovable property under Section 17(5) of the CGST Act.
    Plywood is commonly invoiced using units such as square metres (SQM), square feet (SQFT), cubic metres or sheets/pieces, depending on the nature of trade and packaging. Businesses should ensure invoices and e-way bills are consistent.
    Exports of plywood are treated as zero-rated supplies under GST. Exporters can either export under a Letter of Undertaking (LUT) without paying IGST or pay IGST and later claim a refund, subject to applicable conditions.
    No, plywood classification under GST is based on product type and HSN code rather than branding. Both branded and unbranded plywood generally attract the same applicable GST rate.
    Plywood is classified under HSN 4412, while MDF falls under HSN 4411. Although both are wood-based products under Chapter 44, they are treated as separate categories based on their manufacturing processes and structures.
    Published on June 2, 2026
