    HSN Code 9405: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    Jun 16, 2026
    30 second summary | HSN Code 9405 covers lamps, lighting fittings, illuminated signs, nameplates and their parts. This guide explains key HSN sub-codes, applicable GST rates, product classifications, ITC eligibility, e-Way Bill requirements and GST return filing procedures for businesses dealing in lighting products.
    HSN Code 9405 falls under Chapter 94 of the Harmonised System of Nomenclature and covers lamps and lighting fittings, including searchlights and spotlights and parts thereof, not elsewhere specified or included; illuminated signs, illuminated nameplates and the like having a permanently fixed light source, and parts thereof. In simpler terms, it applies to the entire universe of lighting products, from LED bulbs and tube lights to chandeliers, emergency lamps, illuminated signage and related spare parts.
    If you are a manufacturer, wholesaler, retailer or importer/exporter of any lighting product in India, HSN 9405 is the classification you will use for GST compliance.
    Which products fall under HSN Code 9405 and what is their GST rate?
    Under the GST rate changes effective from 22 September 2025, based on the recommendations of the 56th GST Council, goods classified under HSN 8471 are generally subject to GST at 18%. This rate serves as the standard tax applicable to most computer hardware, data processing equipment and related information technology products covered under the revised GST framework.
    Here is the detailed breakdown of HSN 9405:
    Description
    HSN code
    Chandeliers and other electric ceiling or wall lighting fittings, excluding lighting used for public open spaces or thoroughfares (includes high mast lights)
    940510
    Electric table, desk, bedside and floor-standing lamps
    940520
    Electric lighting sets designed for Christmas trees (includes plastic poly bags)
    940530
    Electric lamps and lighting fittings not elsewhere specified (includes silicon tubes)
    940540
    Non-electrical lamps and lighting fittings not elsewhere specified
    940550
    Illuminated signs, illuminated nameplates and similar products with a permanently fixed light source
    940560
    Parts of lamps, lighting fittings, illuminated signs and nameplates made of glass, not elsewhere specified
    940591
    Parts of lamps, lighting fittings, illuminated signs and nameplates made of plastics, not elsewhere specified
    940592
    Parts of lamps, lighting fittings, illuminated signs and nameplates not elsewhere specified (includes LED strips and signage boards)
    940599
    Complete hanging lamp fittings (includes tubelights)
    94051010
    Wall lamps
    94051020
    Other lighting fittings for public lighting spaces (includes high mast lights, LED fittings, LED flood lights, LED light fittings, LED lights and light fittings)
    94051090
    Complete table lamp fittings (includes laser lights and CFL lamps)
    94052010
    Other table, desk, bedside and floor-standing lamps (includes CFL bulbs and LED strip lights)
    94052090
    Electric lighting sets used for Christmas trees (includes Christmas lights and plastic poly bags)
    94053000
    Searchlights and spotlights
    94054010
    Other electric lamps and lighting fittings (includes LED modules, solar modules/panels, FOB machines, solar lights, UV lamps, tubelights, glow signs, grid ceilings, solar LED street lights, LED controllers, LED downlights, LED grow lights, LED light fixtures and silicon tubes)
    94054090
    Hurricane lanterns
    94055010
    Miners’ safety lamps
    94055020
    Kerosene pressure lanterns
    94055031
    Other oil pressure lamps
    94055039
    Solar lanterns and solar lamps (includes solar batteries, solar lanterns, solar street lights and solar systems)
    94055040
    Other metal oil lamps
    94055051
    Other non-metal oil lamps
    94055059
    Illuminated signs, nameplates and similar products made of plastics
    94056010
    Illuminated signs, nameplates and similar products made of other materials (includes ACP sheets, ACP sign boards and glow sign boards)
    94056090
    Parts of lamps and lighting fittings made of glass
    94059100
    Parts of lamps and lighting fittings made of plastics
    94059200
    Other parts of lamps and lighting fittings (includes tubelights, heat sink parts, candle holders, lamp shades, downlights, display boards, LED street lights, LED spot lights, LED boards, LED drivers and signage boards)
    94059900
    How to file GST returns for HSN Code 9405: Step-by-step guide
    If you are a business owner dealing with products classified under HSN 9405, here is your step guide to file GST returns:
    Step 1: File GSTR-1 (outward supplies)
    GSTR-1 is where you report all your sales invoices for the period.
    How to access:
    1. Log in to www.gst.gov.in with your GSTIN and credentials.
    2. Go to Services → Returns → Returns Dashboard.
    3. Select the return period (month or quarter).
    4. Click on GSTR-1.
    Key tables to fill:
    • Table 4 (B2B Invoices): Enter all invoices raised to GST-registered buyers, including HSN, taxable value, and tax amounts.
    • Table 5 (B2C Large Invoices): For unregistered buyers where the invoice value exceeds ₹2.5 lakh (inter-state).
    • Table 7 (B2C Small Invoices): Aggregate of all small B2C supplies, state-wise.
    • Table 12 (HSN Summary): This is where you report the HSN-wise summary of all outward supplies. Select HSN code 9405 (or the appropriate sub-code) from the dropdown, enter total quantity, taxable value and tax amounts. This table is now bifurcated into B2B and B2C tabs as of early 2025.
    Due dates for GSTR-1:
    • Monthly filers: 11th of the following month
    • Quarterly filers (QRMP scheme): 13th of the month following the quarter
    Note: From 1st January 2022, you cannot file GSTR-1 if the previous period's GSTR-3B has not been filed. Always file GSTR-3B first for prior periods.
    Step 2: File GSTR-3B (summary return & tax payment)
    GSTR-3B is where you declare your net tax liability and pay GST.
    Steps:
    1. Log in to the GST portal → Services → Returns → Returns Dashboard.
    2. Select GSTR-3B for the relevant period.
    3. In Table 3.1 (Outward Supplies): Enter total taxable value and tax for supplies under HSN 9405.
    4. In Table 4 (ITC): Claim Input Tax Credit on purchases of lighting goods or inputs used in their manufacture/supply.
    5. Net tax payable = Output tax – Eligible ITC.
    6. Pay the balance through the Electronic Cash Ledger or adjust through the Electronic Credit Ledger.
    7. Submit and file using DSC (Digital Signature Certificate) or EVC (Electronic Verification Code).
    Due dates for GSTR-3B:
    • Monthly filers: 20th of the following month
    • Quarterly filers (QRMP - Category X states): 22nd of the month following the quarter
    • Quarterly filers (QRMP - Category Y states): 24th of the month following the quarter
    Step 3: Claim Input Tax Credit (ITC) correctly
    GST-registered businesses that purchase lighting products under HSN 9405 for use in taxable supplies or commercial purposes are eligible to claim ITC. Key conditions:
    • The supplier must have filed their GSTR-1, and the invoice must appear in your GSTR-2B (static ITC statement).
    • You must possess a valid tax invoice.
    • The goods must be used for business purposes (not for personal consumption or exempt supplies).
    • ITC must be claimed within the time limits prescribed under Section 16 of the CGST Act.
    Step 4: E-way bill and e-invoicing
    If you are transporting lighting goods (HSN 9405) and the consignment value exceeds ₹50,000, you must generate an e-Way Bill on the e-Way Bill portal (ewaybillgst.gov.in) before movement of goods.
    Businesses whose Aggregate Annual Turnover (AATO) exceeds the notified threshold are required to generate e-invoices through the Invoice Registration Portal (IRP) for all B2B transactions. The e-invoice system auto-populates data into GSTR-1, reducing manual errors. Check the current threshold on the GST portal, as it has been progressively lowered.
    Step 6: File GSTR-9 (annual return)
    At the end of each financial year, you must file GSTR-9, the Annual Return, which reconciles all monthly/quarterly filings.
    For HSN 9405 specifically:
    • Table 17 (HSN Summary of Outward Supplies): Mandatory. Enter HSN code 9405 (or sub-codes), UQC (unit of measurement), total quantity, total value and tax breakup. The GST portal will flag an error if you try to compute liabilities without filling this table.
    • Table 18 (HSN Summary of Inward Supplies): Report HSN-wise purchases of lighting goods.
    • Auto-populated data from your GSTR-1 and GSTR-3B will be pre-filled. Verify and reconcile with your books before finalising.
    Due date for GSTR-9: Generally 31st December of the year following the financial year (e.g., 31st December 2025 for FY 2024–25), subject to CBIC extensions.
    Conclusion
    Accurate HSN classification is not just a tax requirement; it also helps businesses maintain cleaner records, reduce reporting mismatches and improve operational efficiency. As product ranges expand, periodically reviewing HSN mappings, invoices and inventory data can help prevent compliance issues and support smoother audits. Businesses dealing in lighting products can further simplify day-to-day GST management by using accounting software such as TallyPrime, which streamlines bookkeeping, tracks inventory, and generates GST-ready reports from a single platform.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes. Importers of lamps, lighting fittings, illuminated signs and related parts classified under HSN 9405 must declare the correct HSN code in import documents, customs filings and GST returns to ensure proper tax compliance.
    Yes. Exporters should use the correct HSN classification in shipping bills, invoices and other export-related documents to facilitate customs clearance and ensure accurate reporting.
    A business can refer to the Customs Tariff, GST rate notifications, product specifications and official classification guidelines. In complex cases, professional tax advice may be required.
    Yes. Product design, functionality, mounting type, material composition and intended application can result in different sub-classifications under HSN 9405.
    Corrections may be made through the amendment provisions available in subsequent GST returns, subject to GST rules and timelines prescribed by the tax authorities.
    Published on June 16, 2026
