    HSN Code 8536: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    Jun 2, 2026
    30 second summary | HSN Code 8536 covers electrical components such as switches, relays, fuses, plugs and sockets used for circuits up to 1,000V. This guide explains the applicable GST rate, the eligible ITC conditions, the required return filing forms and the practical compliance steps businesses should follow in 2026.
    HSN (Harmonised System of Nomenclature) is a globally accepted product classification system created by the World Customs Organisation. It is used by more than 200 countries to classify goods using a standardised 6-digit code. This common coding system helps ensure consistency in taxation, customs procedures and international trade across markets.
    HSN Code 8536 falls under Chapter 85 of the HSN classification, which covers Electrical Machinery and Equipment and Parts Thereof.
    The key qualifier here is the voltage threshold: not exceeding 1,000 volts. This distinguishes HSN 8536 from its close neighbour, HSN 8535, which covers similar apparatus for voltages exceeding 1,000 volts (used in high-voltage industrial settings).
    Which products are classified under HSN Code 8536?
    HSN 8536 covers a wide range of everyday and industrial electrical components. Here is a detailed breakdown:
    Description
    HSN
    Electrical apparatus used for switching, protecting, or connecting electrical circuits (including fuses, junction boxes, lamp-holders, plugs, relays, sockets, surge suppressors, switches) for voltage not exceeding 1,000 V
    8536
    853610
    Fuse units and electrical fuses for circuit protection
    85361010
    Cartridge fuses for electrical circuit protection
    85361020
    Plug-type fuses for electrical circuit protection
    85361030
    Fuse holders used with electrical circuits
    85361040
    Fuse bases and related fuse mounting parts
    85361050
    Cut-outs for electrical circuit protection
    85361060
    Other electrical fuses and fuse components
    85361090
    Automatic circuit breakers for electrical circuits
    853620
    Miniature circuit breakers (MCBs)
    85362010
    Moulded case circuit breakers (MCCBs)
    85362020
    Earth leakage circuit breakers
    85362030
    Air circuit breakers
    85362040
    Other automatic circuit breakers
    85362090
    Other apparatus for protecting electrical circuits (including surge suppressors and similar protective devices)
    853630
    Surge suppressors and other electrical protective apparatus
    85363000
    Relays for a voltage not exceeding 60 V
    853641
    Low-voltage relays not exceeding 60 V
    85364100
    Relays for a voltage exceeding 60 V
    853649
    Other relays for electrical circuits
    85364900
    Electrical switches used for making or breaking electrical circuit connections
    853650
    Push-button and similar switches
    85365010
    Rotary and selector switches
    85365020
    Other electrical switches
    85365090
    Lamp-holders designed for electrical lamps
    853661
    Lamp-holders
    85366110
    Other lamp-holder components
    85366190
    Electrical plugs and sockets for circuit connections
    853669
    Electrical plugs
    85366910
    Electrical sockets and other connectors
    85366990
    Connectors for optical fibres, optical fibre bundles, or cables
    853670
    Optical fibre connectors
    85367000
    Other electrical apparatus for making connections to or in electrical circuits (including terminals, junction boxes, connectors)
    853690
    Electrical terminals and terminal strips
    85369010
    Junction boxes for electrical connections
    85369020
    Connectors and cable joining components
    85369030
    Other electrical connection apparatus
    85369090
    What GST rate applies to HSN Code 8536?
    After the GST rate rationalisation approved at the 56th GST Council meeting and brought into effect on 22 September 2025, goods classified under HSN Code 8536 continue to attract GST at 18%. The 56th Council significantly simplified the GST structure by moving many goods to the 5%, 18% and 40% slabs; however, HSN 8536 was not shifted to a new slab and remains under the standard 18% rate.
    What are the eligibility conditions for input tax credit (ITC) under HSN Code 8536?
    To claim ITC, businesses must satisfy the following terms and conditions:
    • Only a registered taxpayer can claim ITC. If the purchaser is not registered under GST, the tax paid on HSN 8536 goods is included in the cost, and no credit can be claimed.
    • The buyer must possess a proper GST tax invoice or debit note issued by the supplier, containing the GSTIN, invoice number, HSN code, tax amount and other prescribed details. Without a valid document, ITC is not available.
    • Input tax credit can be claimed only after the HSN 8536 goods are physically received by the buyer. If delivery is pending, ITC cannot be availed yet.
    • The supplier should report the invoice correctly in GSTR-1, and it should appear in the buyer’s GSTR-2B. Credit is generally claimed based on invoices reflected there.
    • ITC can be availed only when the recipient has filed the relevant GST return, mainly GSTR-3B.
    • Payment for the invoice value plus GST should be made to the supplier within 180 days from the invoice date. If not paid, the ITC claimed may need reversal with interest.
    • ITC on HSN 8536 invoices must be claimed on or before 30 November following the end of the financial year, or before filing the annual return, whichever is earlier.
    • Credit should not fall under blocked credit restrictions under Section 17(5) of the CGST Act.
    Which GST returns need to be filed for HSN Code 8536?
    Here are the key GST return filing forms for HSN Code 8536:
    GSTR-1
    Businesses dealing in goods under HSN 8536 must report all taxable sales in GSTR-1. Invoice details, such as taxable value, GST amount, buyer GSTIN (for B2B sales) and HSN code, are disclosed here. It can be filed monthly or quarterly, depending on the taxpayer’s scheme.
    GSTR-3B
    This is the main tax payment return. Taxpayers report summary figures of outward supplies of HSN 8536 goods, input tax credit claimed on purchases, and net GST payable. It is filed monthly or quarterly.
    Invoice Furnishing Facility (IFF)
    Taxpayers under the QRMP scheme can upload B2B invoices for the first two months of a quarter using IFF so buyers can claim input tax credit without waiting for quarterly GSTR-1.
    GSTR-9
    Businesses supplying HSN 8536 products may need to file GSTR-9, which summarises yearly turnover, tax paid, and input tax credit claimed for the financial year.
    GSTR-9C
    Applicable in cases where audit or reconciliation requirements arise under GST provisions. It compares annual return figures with the books of accounts.
    Practical compliance tips for 2026
    Here is a quick compliance tips for businesses dealing with products under HSN 8536:
    • Update your ERP/billing software to reflect the post-September 2025 GST framework and ensure HSN codes map correctly to the 18% slab.
    • Maintain purchase records with HSN-wise breakdowns for annual audit trails and GST audit readiness.
    • Train your accounts team to distinguish 8536 sub-codes, especially for mixed supplies involving both MCBs and distribution boards in a single project.
    • Consult a GST practitioner for classification decisions on borderline products, such as smart home switch modules with embedded controllers, which may overlap with Chapter 84 or 85 electronics headings.
    Conclusion
    As electrical products become more specialised and compliance checks more data-driven, small classification errors can quickly turn into delayed payments, blocked credits, or customer disputes. A smart approach is to build a product-wise compliance checklist before issuing invoices, especially if your business handles multiple stock keeping units (SKUs) across switches, relays, connectors or fuse components.
    Keeping tax, inventory and invoicing connected in one workflow can save hours every month and reduce manual follow-ups. Tools like TallyPrime can make this process easier by helping businesses manage stock, billing and GST reporting from one place with better accuracy.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes. Imported goods such as switches, relays, plugs, sockets or circuit breakers classified under HSN 8536 are taxed under the same code at the time of customs clearance in India. Importers must mention the correct HSN while filing Bill of Entry documents.
    Some spare parts may fall under HSN 8536 if they are specifically designed as an electrical connection or protection apparatus. However, depending on the product’s use and design, certain parts may be classified elsewhere under Chapter 85, so classification should be checked carefully.
    A business can verify classification by checking the GST tariff schedule, customs tariff notifications, product technical specifications, voltage rating, and the product’s intended function.
    It can, but in some cases. Classification depends on the product’s main function. If the item primarily performs switching or circuit connection, it may fall under 8536. If software or control electronics are the principal feature, another heading may apply.
    Yes. A composition taxpayer can sell HSN 8536 goods if otherwise eligible under GST rules. However, composition dealers cannot collect GST separately from customers or allow buyers to claim ITC on such purchases.
    Published on June 2, 2026
