    HSN Code 8504: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    Jun 16, 2026
    30 second summary | HSN Code 8504 covers electrical transformers, static converters such as rectifiers and inverters and inductors and their parts. Most goods under this classification attract 18% GST following the September 2025 GST rate rationalisation. Businesses must use the correct HSN sub-code while reporting sales in GSTR-1, GSTR-3B and GSTR-9.
    Harmonised System of Nomenclature (HSN) Code 8504 refers to "Electrical Transformers, Static Converters (e.g., Rectifiers) and Inductors; Parts Thereof." This classification code is essential for identifying electrical equipment and components for import/export purposes based on their nature, composition and intended use. Common products under HSN Code 8504 include power transformers, distribution transformers, rectifier units and inductors.
    Which products are categorised under HSN Code 8504?
    Here is the detailed breakdown of products classified under HSN 8504:
    Description
    HSN Code
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Ballasts for discharge lamps or tubes, conventional type
    8504
    850410
    85041010
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Ballasts for compact fluorescent lamps (CFLs)
    85041020
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Ballasts for discharge lamps or tubes, other
    85041090
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Liquid dielectric transformers with a power handling capacity not exceeding 650 kVA
    850421
    85042100
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Liquid dielectric transformers with a power handling capacity exceeding 650 kVA but not exceeding 10,000 kVA
    850422
    85042200
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Liquid dielectric transformers with a power handling capacity exceeding 10,000 kVA but not exceeding 50,000 kVA
    850423
    85042310
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Liquid dielectric transformers with a power handling capacity exceeding 50,000 kVA but not exceeding 100,000 kVA
    85042320
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Liquid dielectric transformers with a power handling capacity exceeding 100,000 kVA but not exceeding 250,000 kVA
    85042330
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Liquid dielectric transformers with a power handling capacity exceeding 250,000 kVA
    85042340
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Other transformers with a power handling capacity not exceeding 1 kVA
    850431
    85043100
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Other transformers with a power handling capacity exceeding 1 kVA but not exceeding 16 kVA
    850432
    85043200
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Other transformers with a power handling capacity exceeding 16 kVA but not exceeding 500 kVA
    850433
    85043300
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Other transformers with a power handling capacity exceeding 500 kVA
    850434
    85043400
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Static converters: Electric inverter
    850440
    85044010
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Static converters: Rectifiers, DIP bridge rectifier
    85044021
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Static converters: Rectifiers, other
    85044029
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Static converters: Battery chargers
    85044030
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Static converters: Voltage regulators and stabilisers (other than automatic)
    85044040
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Static converters: Other
    85044090
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Other inductors: Choke coils (chokes)
    850450
    85045010
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Other inductors: Other
    85045090
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Parts of transformers
    850490
    85049010
    Electrical transformers, static converters (e.g., rectifiers) and inductors – Other parts
    85049090
    What GST rate applies to HSN 8504?
    Following the GST rate rationalisation approved in the 56th GST Council Meeting and implemented from 22 September 2025, most goods covered under HSN 8504 are taxable at the standard GST rate of 18%. Under the revised GST framework, the earlier 12% and 28% slabs were largely merged into the standard rate. The applicable Integrated GST (IGST) rate on imports of HSN 8504 products is also generally 18%, unless a specific exemption or concessional notification applies.
    Step-by-Step: How to file GSTR-1 for HSN 8504
    GSTR-1 is the return where you report all outward supplies (sales). Here's how to file it correctly for HSN 8504 goods:
    Step 1: Log in to the GST portal
    Log in to the official GST portal at gst.gov.in using your credentials (username and password). Navigate to the 'Returns Dashboard' by following the path: Services → Returns.
    Step 2: Select the return period
    Choose the relevant month or quarter for which you are filing. If you are a quarterly filer under the QRMP scheme, select the applicable quarter.
    Step 3: Fill outward supply details
    Enter your B2B invoices (sales to registered dealers) and B2C invoices (sales to unregistered buyers) in their respective sections. For HSN 8504 goods, ensure each invoice carries the correct HSN sub-code.
    Step 4: Report HSN summary in Table 12
    Table 12 of GSTR-1 requires an HSN-wise summary of all outward supplies. Auto-filling of the HSN-wise summary based on imported sales details is available on the portal. The portal has implemented validations, and from the February 2025 return period onwards, manual entry of HSN codes has been replaced by choosing the correct HSN from a given drop-down menu. Table 12 has been bifurcated into two tabs: B2B and B2C to report these supplies separately.
    Select HSN 8504 (or the appropriate sub-code) from the drop-down, enter the taxable value, IGST/CGST/SGST amounts and the quantity in the applicable unit of measurement (UQC).
    Step 5: Submit and file
    Preview your return, check for errors and submit. File using your Digital Signature Certificate (DSC) or EVC (Electronic Verification Code).
    Due dates for GSTR-1:
    • Monthly filers (turnover above ₹5 crore): 11th of the following month
    • Quarterly filers under QRMP (turnover up to ₹5 crore): 13th of the month following the quarter
    Note:
    • File GSTR-3B. It is a summary return. Steps to file GSTR-3B: Log in → Returns Dashboard → Select GSTR-3B → Fill outward supplies (sales). In GSTR-3B, report the total taxable value of HSN 8504 supplies under the appropriate tax head. Declare your outward tax liability and set off against available Input Tax Credit (ITC). The due date for GSTR-3B is the 20th of the following month for monthly filers; the 22nd or 24th, depending on the state category, for quarterly QRMP filers.
    • At the end of the financial year, all regular taxpayers must file GSTR-9 (Annual Return). Starting from the financial year 2024-25, if the taxpayer clicks "Compute Liabilities" without filling in Table 17, HSN-wise Summary of Outward Supplies, a highlighted error message will appear. Therefore, ensure all HSN 8504 supplies are correctly summarised in Table 17 of GSTR-9 before computing tax liabilities.
    Conditions for claiming ITC on HSN 8504 products
    Here are the key terms and conditions that must be satisfied to claim ITC under HSN 8504:
    • The claimant must be a registered person under GST. Unregistered persons cannot avail ITC.
    • The HSN 8504 goods must be used or intended to be used in the course or furtherance of business. ITC is not available for personal consumption.
    • The recipient must possess a valid tax invoice, debit note, or other prescribed tax-paying document issued by the supplier.
    • The invoice must contain the prescribed GST particulars such as GSTIN, invoice number, tax amount and description of goods.
    • The recipient must have actually received the goods. ITC cannot be claimed merely based on an invoice.
    • The supplier must have furnished the invoice details in GST returns, and the invoice should be reflected to the recipient through the GST system, typically in GSTR-2B.
    • The tax charged on the supply must have been paid to the Government by the supplier, either in cash or by utilising ITC.
    • The recipient must have filed the prescribed GST returns to avail and utilise the credit.
    • Payment to the supplier must generally be made within 180 days from the invoice date. If payment is not made within this period, the ITC claimed must be reversed, along with any applicable interest, and can be reclaimed after payment.
    • ITC must be claimed within the statutory time limit, generally up to 30 November of the following financial year or the date of filing the annual return, whichever is earlier.
    • ITC cannot be claimed where it is specifically blocked under Section 17(5) or where depreciation is claimed on the GST component of eligible capital goods.
    Conclusion
    Accurate classification is only one part of effective GST compliance. Businesses dealing in HSN 8504 goods should establish a strong system for maintaining product specifications, purchase records and tax documents to minimise reporting errors and support smooth audits.
    Regular reconciliation of sales, purchases and tax credits can help identify discrepancies early and improve compliance efficiency. Using an integrated business management solution such as TallyPrime can further simplify record-keeping, reporting and ongoing GST management.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes. A business may sell different types of transformers, inverters, rectifiers, inductors or related parts, each falling under separate HSN 8504 sub-classifications.
    Not always. Separate parts may fall under specific HSN 850490 classifications or other applicable tariff entries depending on their nature and use.
    Exports may qualify as zero-rated supplies under GST law, subject to fulfilment of prescribed conditions and documentation requirements.
    UQC helps standardise quantity reporting in GST returns and ensures consistency between invoice details and HSN-wise summaries.
    Generally, the classification is determined by the nature of the goods being supplied. Refurbishment does not automatically change the applicable HSN classification.
    Published on June 16, 2026
