    HSN Code 8471:Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    Updated on Jun 2, 2026
    30 second summary | HSN Code 8471 covers computers, laptops, storage devices and related data processing equipment under GST. This guide explains its product classification, applicable 18% GST rate, ITC conditions, e-way bill requirements, key return forms such as GSTR-1 and GSTR-3B and practical compliance tips for businesses dealing in IT hardware.
    If your business sells laptops, desktop computers, CPUs, servers, storage drives or related data-processing equipment, Harmonised System of Nomenclature (HSN) Code 8471 is one code you will likely deal with regularly. From raising tax invoices to filing GST returns and claiming input tax credit, using the correct HSN classification matters for both compliance and billing accuracy.
    Under India’s GST framework, HSN Code 8471 covers automatic data processing machines and units thereof, including certain input and output devices, storage units and processing units used with computer systems. Businesses dealing in IT hardware, electronics distribution, imports, wholesale supply or online retail often report outward supplies under this heading
    What is HSN Code 8471?
    HSN Code 8471 falls under Chapter 84 of the Harmonised System of Nomenclature, which broadly deals with machinery and mechanical appliances. Here is the full description:
    Description
    HSN Code
    Automatic data processing machines and related units; magnetic or optical readers; machines used for recording data onto coded media and machines for processing such data, not elsewhere specified or included (including analogue or hybrid automatic data processing machines)
    8471
    847110
    84711000
    Portable automatic data processing machines (portable computers and similar devices), weighing not more than 10 kg, consisting of at least a central processing unit, keyboard and display
    847130
    Portable automatic data processing machines (laptops and similar portable computers), weighing not more than 10 kg, consisting of at least a CPU, keyboard and display
    84713010
    Other portable automatic data processing machines, weighing not more than 10 kg, consisting of at least a CPU, keyboard and display
    84713090
    Other digital automatic data processing machines comprising, in the same housing, at least a central processing unit and an input/output unit
    847141
    Other digital automatic data processing machines comprising, in the same housing, at least a CPU and an input unit/output unit
    84714110
    Other digital automatic data processing machines comprising, in the same housing, at least a CPU with both input and output units
    84714120
    Other digital automatic data processing machines comprising, in the same housing, at least a CPU and an input/output unit (other)
    84714190
    Other digital automatic data processing machines presented in the form of systems
    847149
    Other digital automatic data processing machines presented as systems
    84714900
    Processing units other than those of sub-headings 847141 or 847149, whether or not containing storage units, input units or output units in the same housing
    847150
    Processing units other than those under 847141 or 847149, whether or not containing storage, input or output units in the same housing
    84715000
    Input or output units for automatic data processing machines, whether or not containing storage units in the same housing
    847160
    84716010
    Input or output units for automatic data processing machines (other specified units)
    84716021
    84716022
    84716023
    84716024
    84716025
    84716026
    84716027
    84716029
    84716030
    84716040
    84716050
    84716060
    Input or output units for automatic data processing machines (other units)
    84716090
    Storage units for automatic data processing machines (floppy disk drives)
    847170
    84717010
    Storage units for automatic data processing machines (hard disk drives)
    84717020
    Storage units for automatic data processing machines (removable or exchangeable disk drives)
    84717030
    Storage units for automatic data processing machines (magnetic tape drives)
    84717040
    Storage units for automatic data processing machines (cartridge tape drives)
    84717050
    Storage units for automatic data processing machines (CD-ROM drives)
    84717060
    Storage units for automatic data processing machines (digital video disc drives)
    84717070
    Storage units for automatic data processing machines (other storage units)
    84717090
    Other units of automatic data processing machines
    847180
    84718000
    Other automatic data processing machines and units thereof
    847190
    84719000
    How are HSN 8471 products taxed under GST?
    Under the GST rate rationalisation announced in the 56th GST Council meeting, HSN 8471 goods continue to be charged GST at 18% from 22 September 2025. There was no change in the tax rate for this HSN under the revised structure. Businesses supplying products under HSN 8471 must charge 18% GST on invoices, which is split as 9% CGST + 9% SGST for intra-state sales and 18% IGST for inter-state sales.
    Key return filing forms for HSN Code 8471
    Here are the key GST return filing forms relevant for businesses dealing in HSN Code 8471:
    GSTR-1
    Businesses selling goods under HSN Code 8471 must report invoice-wise details of outward taxable supplies in GSTR-1. This includes B2B sales, B2C sales, debit notes and credit notes. The HSN code and taxable value of products are disclosed here. Monthly filers generally file by the 11th of the following month, while quarterly filers under QRMP file by the 13th after the quarter ends.
    GSTR-3B
    This is the main return used to declare total sales, input tax credit claimed and net GST payable on HSN 8471 goods. Tax liability is discharged through GSTR-3B after adjusting the eligible ITC. It is filed monthly or quarterly, depending on the taxpayer category.
    GSTR-9
    Registered taxpayers dealing in HSN 8471 goods may also need to file GSTR-9, which summarises annual turnover, tax paid and input tax credit (ITC) claimed for the financial year. It helps reconcile yearly GST records with monthly and quarterly returns.
    IFF (Invoice Furnishing Facility)
    Taxpayers under the QRMP scheme can optionally upload B2B invoices for the first two months of a quarter via IFF, so buyers can claim input tax credit without waiting for the quarterly GSTR-1 filing.
    Key conditions for ITC under HSN Code 8471
    Here are the key conditions that businesses must meet before claiming ITC:
    • ITC can be claimed only if the buyer is registered under GST. If a business purchases goods under HSN 8471 but is not registered, GST paid on the purchase cannot be claimed as a credit.
    • The computer hardware or IT equipment must be used in the course or furtherance of business. If it is bought for personal use, ITC is not allowed. If used partly for business and partly for personal purposes, only the business-use portion can be claimed.
    • The buyer must have a proper GST invoice issued by the supplier showing the supplier's GSTIN, HSN Code 8471, taxable value, and GST charged. Without this invoice, ITC may be denied.
    • ITC can be claimed only after the computers or related equipment are actually delivered to the buyer. Booking an order or making an advance payment alone is not enough.
    • The supplier should report the invoice correctly in GSTR-1 so that it appears in the buyer’s GSTR-2B. Businesses generally match purchase records with GSTR-2B before claiming credit.
    • The buyer must file GSTR-3B to claim ITC. Credit is usually claimed in the tax period in which all conditions are fulfilled.
    • If payment for the invoice is not made within 180 days from the invoice date, the ITC claimed may need to be reversed along with applicable interest. Credit can usually be reclaimed once payment is made.
    • ITC should not fall under blocked credits listed in Section 17(5) of the CGST Act. IT hardware used for business operations is generally eligible unless specifically restricted.
    • ITC must be claimed within the time limit under Section 16(4) of the CGST Act; otherwise, the credit may lapse.
    When is an e-way bill mandatory for HSN code 8471 goods?
    Under GST, movement of goods classified under HSN 8471 generally requires an e-way bill when the consignment value exceeds ₹50,000. This applies to both supply and certain non-supply movements. The legal basis comes from Section 68 of the CGST Act, 2017, read with Rule 138 of the CGST Rules, 2017. Here are the key conditions:
    • The ₹50,000 threshold is calculated based on the invoice value or consignment value mentioned in the tax invoice, bill of supply, or delivery challan.
    • If multiple computer items under HSN 8471 are transported together and the total invoice value exceeds ₹50,000, an e-way bill must be generated before dispatch.
    • The supplier, recipient or transporter can generate the e-way bill on the official GST e-way bill portal.
    • From 1 January 2025, e-way bills can be generated only for invoices/documents issued within the previous 180 days.
    • If HSN 8471 goods are moved without a valid e-way bill where required, authorities may impose a penalty of ₹10,000 or the tax sought to be evaded, whichever is higher, along with possible detention of goods/vehicle.
    Common filing tips for businesses
    Businesses dealing in computers and electronics should regularly review HSN mapping, as product descriptions can overlap across IT hardware categories.
    A few practical checks include:
    • Maintain correct Stock Keeping Unit (SKU) wise HSN mapping in Enterprise Resource Planning (ERP) or billing software
    • Verify whether accessories fall under 8471 or another heading before invoicing
    • Keep purchase invoices properly reconciled for ITC claims
    • Cross-check vendor HSN reporting with your books
    • Review import documentation for customs classification consistency
    • Match HSN data between the invoice, e-invoice and GST return before filing
    Conclusion
    As GST compliance around technology products becomes more detail-driven, even small classification errors can lead to delays, notices or blocked working capital. A practical way forward is to establish a periodic internal review process for tax and inventory data, rather than checking only at the time of filing.
    Businesses using software like TallyPrime can make this easier by creating stronger workflows between billing, stock and tax reporting teams. Staying organised behind the scenes often speeds up compliance and makes it far less stressful as the business scales.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes. Refurbished or used computers can also fall under HSN Code 8471 if they meet the product classification under automatic data processing machines or related units. GST generally applies to their taxable transaction value unless a specific valuation rule applies.
    Not necessarily. The hardware may fall under HSN 8471, but software taxation can vary depending on whether it is supplied pre-installed, separately licensed or delivered digitally.
    In certain cases, yes. Barcode scanners or optical readers may be classified under HSN 8471 if they function as data input devices connected with automatic data processing systems.
    Yes. A single invoice can include multiple HSN codes where different products are supplied together, provided each item is correctly described with its applicable HSN and taxable value.
    In many cases, yes. External storage devices such as hard disk drives or certain SSD-based storage units may be classified under HSN 8471 depending on their specifications.
    Published on June 2, 2026
