    HSN Code 8421: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    Jun 2, 2026
    30 second summary | HSN Code 8421 covers centrifuges, water filters, air purifiers and other filtering or purifying machinery. This guide explains the products classified under 8421, the applicable 18% GST rate, ITC eligibility, e-invoicing rules and GST return filing requirements that businesses should know for smooth compliance.
    HSN Code 8421 belongs to Chapter 84 of the Harmonised System of Nomenclature, which covers nuclear reactors, boilers, machinery, and mechanical appliances. This code sits under Section XVI of the HSN schedule, covering machinery and mechanical appliances, electrical equipment, and parts thereof. It is highly relevant to manufacturers, traders, distributors and importers across industries such as pharmaceuticals, food processing, automotive, FMCG, water treatment and industrial equipment.
    Which goods are covered under HSN Code 8421?
    HSN 8421 is broken into specific sub-headings based on the type of equipment. Here is the breakdown:
    Description
    HSN Code
    Centrifuges (including centrifugal dryers)
    8421
    Cream separators [centrifuges, including centrifugal dryers]
    84211100
    Clothes dryers [centrifuges, including centrifugal dryers]
    84211200
    Other centrifuges
    842119
    Bowl centrifuges
    84211910
    Basket centrifuges
    84211920
    Continuous automatic centrifuges
    84211930
    Self-cleaning centrifuges
    84211940
    Decanter centrifuges (horizontal bowl)
    84211950
    Screw conveyor centrifuges
    84211960
    Other centrifuges for chemical industries
    84211991
    Other centrifuges – others
    84211999
    Machinery and apparatus for filtering or purifying water
    842121
    Ion exchanger plant or apparatus for filtering or purifying water
    84212110
    Household-type filters for filtering or purifying water
    84212120
    Other machinery and apparatus for filtering or purifying water
    84212190
    Machinery and apparatus for filtering or purifying beverages other than water
    84212200
    Oil or petrol filters for internal combustion engines
    84212300
    Other filtering or purifying machinery and apparatus for liquids
    84212900
    Intake air filters for internal combustion engines
    84213100
    Other filtering or purifying machinery and apparatus for gases
    842139
    Air separators used in processing, smelting or refining of minerals
    84213910
    Air purifiers or air cleaners
    84213920
    Other filtering or purifying machinery and apparatus for gases – others
    84213990
    Parts of centrifuges, including centrifugal dryers
    84219100
    Other parts of filtering or purifying machinery and apparatus
    84219900
    What GST rate applies to HSN Code 8421?
    After the GST rate rationalisation announced in the 56th GST Council meeting held on 3 September 2025, effective from 22 September 2025, there was no specific notified reduction or revision for HSN 8421 in the published HSN-wise rate schedule. Accordingly, HSN Code 8421 continues to attract 18% GST in most cases under the revised GST framework. This rate applies to the supply of both imported and domestically manufactured machinery falling under this heading, unless a separate exemption notification or concessional entry specifically covers a product under 8421.
    What are the GST filing requirements for HSN 8421?
    Businesses dealing in products classified under HSN 8421 need to comply with several GST return and invoicing requirements detailed below.
    1. GSTR-1
    GSTR-1 is the monthly or quarterly return used to report all outward taxable supplies made during a tax period.
    For businesses supplying HSN 8421 products, outward supplies are reported in:
    • Table 4 for inter-state supplies made to registered persons
    • Table 5 for inter-state supplies made to unregistered persons
    • Table 7 for intra-state taxable supplies
    • Table 12 must include an HSN-wise summary of outward supplies, along with the taxable value, GST rate, IGST, CGST and SGST.
    From April 2025, Table 12 is divided into separate B2B and B2C sections. Taxpayers must report HSN-wise details separately under each category.
    Due dates:
    • Monthly filers with aggregate annual turnover above ₹5 crore: 11th of the following month
    • Quarterly filers under QRMP with turnover up to ₹5 crore: 13th of the month following the quarter
    2. GSTR-3B
    GSTR-3B is the summary self-assessment return where taxpayers declare outward supplies, inward supplies, input tax credit claimed and tax payable.
    For HSN 8421 businesses:
    • Total taxable outward supplies are reported in Table 3.1
    • Eligible input tax credit (ITC) on purchases such as raw materials, components, capital goods and input services is claimed in Table 4
    From January 2026, GSTN has strengthened ITC validation checks. If the ITC claimed in GSTR-3B exceeds the eligible amount appearing in GSTR-2B, filing may be restricted until reconciliation is completed.
    Due dates:
    • Taxpayers with turnover above ₹5 crore: 20th of the following month
    • Quarterly Return, Monthly Payment  (QRMP) taxpayers: 22nd or 24th of the month following the quarter, depending on the state category
    3. GSTR-2B
    GSTR-2B is an auto-generated and static input tax credit statement made available on the 14th of every month.
    For businesses purchasing HSN 8421 goods:
    • ITC can generally be claimed only when the purchase invoice appears in GSTR-2B
    • This means the supplier should have filed GSTR-1 or Invoice Furnishing Facility (IFF), and the corresponding return details should be reflected in the GST system
    From October 2025, under the Invoice Management System (IMS), imported goods will be processed separately. Businesses should review both GSTR-2B and the IMS import section to verify the complete ITC position.
    Also, under Rule 37A, if a supplier does not file GSTR-3B by 30 September 2026 for FY 2025–26, the recipient may be required to reverse the ITC by 30 November 2026. The credit can be reclaimed once the supplier files the pending return.
    4. GSTR-9
    GSTR-9 is the annual return that consolidates all GST transactions reported during the financial year.
    For HSN 8421 dealers:
    • HSN-wise outward supply details are reported in Table 17
    • This disclosure is mandatory for taxpayers with turnover above ₹5 crore and optional for certain others based on applicable rules
    • Turnover, tax paid and ITC figures should match the data reported in GSTR-1 and GSTR-3B
    Due date: 31 December following the end of the relevant financial year.
    From 1 January 2026, late fees for delayed GSTR-9 filing are applied automatically from the next day after the due date. GST returns pending beyond three years cannot be filed, which may also lead to permanent loss of eligible ITC.
    5. GSTR-9C
    Businesses with aggregate annual turnover exceeding ₹5 crore are required to file GSTR-9C along with GSTR-9.
    This is a reconciliation statement that compares financial statements with GST returns filed during the year. It is now self-certified by the taxpayer, and separate CA certification is no longer mandatory.
    6. E-invoice (IRN generation)
    E-invoicing applies to B2B transactions for businesses crossing the prescribed turnover threshold.
    For HSN 8421 transactions:
    • Each B2B invoice must be uploaded to the Invoice Registration Portal (IRP)
    • An Invoice Reference Number (IRN) must be generated before the invoice is considered valid under e-invoicing rules
    From 1 April 2025, businesses with an annual turnover of ₹10 crore or more must upload invoices to the IRP within 30 days from the invoice date. The portal may reject delayed uploads beyond this period.
    ITC on HSN 8421 purchases
    Businesses engaged in products under HSN 8421 for their taxable activities are eligible to claim ITC on such purchases. Here are some conditions that must be met:
    • The goods must be used for business purposes in connection with taxable supplies
    • The supplier must have filed their GSTR-1, and the invoice must appear in the buyer's GSTR-2B
    • The supplier must have paid the corresponding GST (otherwise, ITC must be reversed under Rule 37A)
    • The buyer must hold a valid tax invoice with the correct HSN code, GSTIN, and GST amount
    • The goods should not be used for personal consumption or for making exempt supplies
    Note: When HSN 8421 machinery is purchased as a capital good (for use in manufacturing or industrial processes), the full ITC is available in the year of purchase itself, unlike accounting depreciation, which is spread over years. However, if depreciation on the GST component is claimed under income tax, the corresponding ITC cannot be availed.
    Conclusion
    HSN 8421 directly affects pricing, vendor coordination, cash flow planning and how smoothly your GST compliance runs throughout the year. A small mismatch can create unnecessary follow-ups, delayed credits or reporting gaps later. Building a routine around invoice checks, purchase reconciliation and timely return review can save both time and effort.
    Using accounting software like TallyPrime can make this process easier by keeping HSN reporting, tax calculation and compliance tracking organised in one place as your business scales.
    Verify GSTIN details online
    cta banner image
    FAQs
    Not always. Replacement cartridges, membranes, filter candles or purifier consumables may fall under 84219900 as parts of filtering or purifying machinery. However, classification depends on whether the item is sold as a machine part or as a separate consumable component.
    Usually no. AMC charges are generally treated as services, not as a supply of goods under HSN 8421. If spare parts are billed separately along with maintenance services, the invoice may include both Services Accounting Code (SAC) and HSN codes.
    Yes, in most cases. Export invoices and shipping documents generally require the correct HSN classification, especially for customs filing, shipping bills, Letter of Undertaking (LUT)/bond documentation, and GST refund processing related to exports.
    Yes. If the core nature of the product remains the same, used or refurbished centrifuges, filters or purification machinery are generally classified under the same HSN 8421 heading, even when resold after repair or refurbishment.
    Yes, supplies made to a Special Economic Zone (SEZ) unit or SEZ developer for authorised operations may qualify as zero-rated supply, subject to documentation and compliance conditions under GST law.
    Published on June 2, 2026
