    HSN Code 3919: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    Jun 3, 2026
    30 second summary | HSN Code 3919 covers self-adhesive plastic tapes, films, sheets, labels and stickers supplied in flat form or rolls. These goods generally attract 18% GST. Correct classification supports invoices, e-way bills, GST returns and Input Tax Credit (ITC) claims. Using tools like TallyPrime can reduce filing errors.
    3919 HSN Code classifies self-adhesive plastic products such as tapes, films, labels, stickers and sheets. It is used to determine GST rates while ensuring accurate invoicing, e-way bill generation, return filing and ITC claims. Correct classification under this code directly impacts tax compliance and reduces the risk of errors or disputes.
    Products like label films, packaging tapes, sticker sheets, protective adhesive films and branding decals, though used across different industries, often fall under this single heading, making proper identification essential for businesses dealing in such materials.
    What is HSN Code 3919?
    HSN stands for Harmonised System of Nomenclature, an internationally accepted system for classifying goods for taxation and trade.
    3919 HSN Code includes self-adhesive plates, sheets, film, foil, tape, strip and other flat shapes of plastics, whether or not in rolls. These are commonly used in:
    • Packaging
    • Electrical insulation
    • Surface protection
    • Branding and labels
    • Industrial bonding
    • Retail stickers
    • Signage
    • Stationery uses
    GST rate and classification under HSN Code 3919
    Effective from 1 July 2017, unless notified otherwise, products classified under Chapter 39, HSN Code 3919 generally attract 18% GST without compensation cess. For detailed reporting in GST systems and customs filings, businesses may need to refer to the 3919 HSN Code 8-digit classification to identify specific product types accurately.
    Description
    HSN
    Self-adhesive plastic flat shapes including plates, sheets, film, foil, tape, strip, whether or not in rolls
    3919
    Self-adhesive plastic rolls with width not exceeding 20 cm, including plates, sheets, film, foil, tape or strip
    39191000
    Other self-adhesive plastic flat shapes not specifically covered elsewhere
    391990
    Plastic stickers, printed or unprinted, embossed or impregnated, self-adhesive
    39199010
    Cellulose adhesive tape and similar self-adhesive plastic tapes
    39199020
    Other miscellaneous self-adhesive plastic products under this category
    39199090
    Can you claim ITC on purchases under HSN Code 3919?
    Yes, ITC can generally be claimed on purchases under HSN Code 3919 if the goods are used or intended to be used in the course or furtherance of business and all conditions under the CGST Act are satisfied.
    Under Section 16(1) of the CGST Act, 2017, a registered person may avail ITC on inward supplies used for business. However, Section 16(2) requires all of the following:
    • Possession of a valid tax invoice or debit note issued under Section 31
    • Receipt of goods
    • Tax charged on the supply has been paid to the Government by the supplier
    • Invoice details are furnished by the supplier and reflected as eligible credit, commonly verified through GSTR-2B
    • The recipient has filed the relevant return, typically GSTR-3B
    Under Section 16(4), ITC for an invoice or debit note must be claimed on or before 30 November following the end of the relevant financial year, or the date of filing the annual return, whichever is earlier.
    Note: If payment to the supplier, including tax, is not made within 180 days, ITC may need to be reversed with applicable consequences under Rule 37. ITC is also not available if the goods are used for personal consumption, free samples, exempt supplies subject to reversal rules or where specifically restricted under Section 17(5).
    Conclusion
    HSN Code 3919 should be treated as a control point in your business, not something you fix only after a notice or mismatch arises. The key takeaway is that consistent classification and documentation directly protect your ITC, reduce audit risks and keep GST filings accurate.
    Set up a monthly product master review, verify supplier classifications and maintain sample catalogues or technical sheets as supporting evidence. These simple controls help prevent disputes, speed up reconciliations and ensure smoother compliance.
    For businesses managing multiple adhesive SKUs, tools like TallyPrime can standardise HSN mapping, automate GST checks and link inventory with invoicing. This structured approach keeps operations efficient and helps avoid costly corrections, delays and working capital pressure as you scale.
    Verify GSTIN details online
    cta banner image
    FAQs
    No. It covers coloured, opaque, printed, laminated or metallised self-adhesive plastic products supplied as sheets, strips, rolls or other flat shapes.
    Yes. Imports may be subject to Basic Customs Duty, Social Welfare Surcharge and IGST, depending on the applicable tariff notification and country of origin.
    Yes. Width not exceeding 20 cm is a key criterion for certain roll-based self-adhesive plastic goods under tariff subheading 39191000.
    No. Regular domestic supplies typically follow a forward charge, unless a specific notified reverse charge provision applies.
    Possibly. GST treatment depends on the contract terms, the linkage to the original consideration and whether it qualifies as a genuine warranty replacement or a separate supply.
    Published on June 3, 2026
