    Bricks HSN Code: GST Rate, Classification & Invoicing Guide
    Tallysolutions
    Tally Solutions
    Updated on Jun 25, 2026
    30 second summary | Red clay bricks (also referred to as country bricks or wire-cut bricks) are typically classified under HSN 6904 10 00 — Ceramic building bricks. They attract 12% GST with ITC, or 6% under the special composition scheme without ITC, consistent with other ceramic construction bricks of this category.
    Bricks in India are classified under different HSN codes based on their material type; such as clay bricks, fly ash bricks, concrete blocks and roofing tiles, and attract GST accordingly, making correct classification essential for accurate invoicing, input tax credit (ITC) claims and GST compliance.
    Incorrect HSN usage can lead to wrong tax payment, ITC denial or compliance issues during audits, especially since GST rates vary depending on the brick type and applicable scheme (with or without ITC).
    How are bricks classified under HSN codes?
    HSN stands for Harmonised System of Nomenclature. It is a globally accepted coding system used to classify goods for taxation purposes. Bricks are classified under different HSN headings based on their material composition and type:
    Category
    HSN Code / Number
    Description
    Fly Ash Bricks/Blocks
    6815
    Covers articles of stone, carbon fibres, peat or other mineral substances not elsewhere specified. It includes sand lime/calcium silicate  bricks, graphite filters, carbon fibre articles and various mineral products.
    Sub-classifications of 6815:
    • 6815 10 - Non-electrical graphite or other carbon articles, including carbon fibres and filter candles
    • 6815 20 - Articles of peat
    • 6815 91 00 - Articles containing magnesite, dolomite or chromite
    • 6815 99 - Other articles, including fly ash bricks and tiles (6815 99 10) and sanitary/kitchen ware of fly ash (6815 99 20)
    Cement, concrete or artificial stone bricks
    6810
    Covers articles of cement, concrete or artificial stone, whether reinforced or not. It includes construction items such as building blocks, tiles, bricks, flagstones and prefabricated structural components.
    Subclassifications and examples:
    • 6810 11 10 - Cement bricks
    • 6810 11 90 - Other building blocks and bricks
    • 6810 19 10 - Cement tiles for mosaic
    • 6810 19 90 - Paver blocks and other cement tiles
    • 6810 91 00 - Prefabricated structural components used for building or civil engineering purpose (e.g., RCC poles, fly ash blocks)
    • 6810 99 90 - Other articles like cement pipes and concrete boulders
    6904
    Includes ceramic building bricks, flooring blocks, support or filler tiles, and similar ceramic construction goods. It applies to items, like clay bricks and fly ash bricks
    HSN 6904 breakdown:
    • 6904 10 00 - Ceramic building bricks
    • 6904 90 00 - Other (including ceramic flooring blocks, support or filler tiles)
    Note: Fly ash bricks can fall under either HSN 6815 (articles of mineral substances) or HSN 6904 (ceramic building bricks) depending on their composition and manufacturing process. Bricks made primarily from fly ash bonded with lime/gypsum typically fall under 6815 99 10, while fly ash bricks manufactured using a ceramic process may be classified under 6904. If unsure, consult a GST practitioner or refer to the applicable customs tariff heading for your specific product.
    Refractory bricks (heat-resistant, used in furnaces)
    6902
    Applies to refractory ceramic constructional goods, such as bricks, blocks and tiles, used in construction, excluding those made of siliceous fossil meals. These materials, containing over 50% alumina, silica or magnesia/calcium/chromium
    Subheadings under HSN 6902:
    • 6902 10 - Containing >50% Mg, Ca or Cr (e.g., Magnesite bricks, Chrome magnesite bricks).
    • 6902 20 - Containing >50% Alumina or Silica (e.g., High alumina bricks, Silica bricks).
    • 6902 90 - Other refractory goods (e.g., Fire clay bricks, Graphite carbon bricks)
    Siliceous Fossil Meals Bricks
    6901
    Covers bricks, blocks, tiles and ceramic goods made from siliceous fossil meals (like kieselguhr, tripolite or diatomite) or similar siliceous earths. These are generally used in construction.
    Key Details for this code:
    6901 00 10 - Bricks of siliceous fossil meals
    6901 00 20 - Blocks of siliceous fossil meals.
    6901 00 30 - Tiles of siliceous fossil meals.
    6901 00 90 - Other ceramic goods of siliceous fossil meals.
    Setts flagstones and curbstones, of natural stone ( except plate)
    6801
    Includes setts, curbstones and flagstones made of natural stone (except slate). This code is primarily used for stone products intended for paving or curbing, such as granite sets or sandstone flags. Some common applications are road construction, paving and landscaping (e.g., granite setts, limestone curbstones)
    Worked monumental or building stone (excluding slate)
    6802
    Covers worked monumental or building stone (excluding slate), mosaic cubes and artificially colored granules, chippings or powder. Common items include processed marble, granite and travertine slabs or tiles.
    Main sub-classifications under HSN  6802:
    6802 10 00 - Tiles, cubes and similar articles, whether or not rectangular, the largest surface area of which is less than 49 sq. cm.
    6802 21 -  Marble, travertine and alabaster, merely cut or sawn into blocks or slabs.
    6802 23 - Granite blocks or tiles.
    6802 29 00 - Other monumental or building stones.
    6802 91/92/93/99 - Further worked stone (processed, decorated, etc.)
    Bricks of pressed or moulded glass
    7016
    Covers paving blocks, slabs, bricks, squares, tiles and other pressed or moulded glass articles used for building or construction purposes, including wired or unwired glass
    What is the GST rate on bricks in India?
    Following the Goods and Services Tax (GST) changes notified after the 56th GST Council meeting in September 2025, only selected brick-related products saw rate adjustments. Contrary to common confusion, most ordinary construction bricks did not move entirely to the 5% slab.
    Ordinary building bricks attract 12% GST with full Input Tax Credit (ITC). However, brick manufacturers who opt for the special composition scheme under Notification No. 02/2022-CT(R) can pay GST at 6% — but without the ability to claim ITC on their purchases. This scheme is available only to manufacturers and not to traders or contractors. Businesses must evaluate which option is more beneficial based on their purchase volumes and ITC eligibility before choosing a scheme.
    No compensation cess currently applies to standard brick categories under GST.
    What are the important invoicing requirements for brick businesses?
    Manufacturers, wholesalers, distributors and contractors dealing in bricks must issue GST-compliant invoices. A proper invoice helps avoid compliance issues and ensures smooth ITC claims.
    A brick invoice should include:
    • Supplier name and GSTIN
    • Invoice number and date
    • Correct HSN code
    • Product description
    • Quantity supplied
    • Taxable value
    • CGST, SGST or IGST amount
    • Place of supply
    • Buyer GSTIN, if registered
    Businesses with an annual aggregate turnover exceeding ₹5 crore are required to generate e-invoices for all B2B transactions under GST. This means every brick sale to a registered buyer must go through the Invoice Registration Portal (IRP), and a valid Invoice Reference Number (IRN) must be printed on the invoice before it is issued.
    Conclusion
    Understanding and applying the correct HSN code and GST rate for bricks is essential for accurate tax compliance, correct pricing and seamless ITC claims. Since similar-looking brick products can fall under different HSN codes, classification must always be based on material, usage and chapter guidelines.
    Correct classification is not optional paperwork. It directly impacts tax liability, ITC eligibility and audit risk. Getting it right ensures fewer disputes and more predictable compliance outcomes for your business.
    Using accounting software like TallyPrime can further simplify this process by helping manage HSN codes, applying the correct GST rates automatically and generating compliant invoices. This reduces manual errors, saves time and strengthens day-to-day GST compliance.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes, AAC blocks and hollow concrete blocks are usually classified under HSN 6810 because they are made from cement, concrete or artificial stone materials rather than traditional clay bricks.
    No, GST is based on material and classification, not the manufacturing method. Both handmade and machine-made bricks follow the same applicable rate.
    Yes, transportation or freight may attract GST separately depending on whether it is charged by a Goods Transport Agency (GTA) and the applicable tax rate structure.
    E-invoicing is mandatory for suppliers whose aggregate turnover exceeds the prescribed threshold notified under GST. The limit was reduced to ₹5 crore in recent updates, replacing the earlier ₹10 crore threshold. Businesses below ₹5 crore turnover can issue regular tax invoices.
    Registered brick manufacturers generally report outward supplies in GSTR-1 and tax liability in GSTR-3B. Businesses under the composition scheme must file CMP-08 and annual GSTR-4 instead of regular monthly returns.
    Published on June 2, 2026
