    How to Track Job Costs and Profitability in TallyPrime
    Tallysolutions
    Tally Solutions
    Updated on Nov 4, 2026
    30 second summary | Job costing helps you track costs and revenue for each job or project separately. In TallyPrime, you can do this using cost centres, which let you assign transactions to a specific job and see exactly how much you spent, earned and ultimately made or lost.
    Job costing means tracking all the costs and revenue linked to a particular job, project or contract so you can see how profitable it really is. It is part of cost accounting, which helps businesses understand how much they spend on specific activities instead of looking at costs for the business as a whole.
    In TallyPrime, you can put this into practice using cost centres. You can tag expenses and income to a specific job, and TallyPrime brings this information together in reports so you can see your profits or losses and how much you spent and earned on each job.
    How does job costing work in TallyPrime?
    TallyPrime uses cost centres as the building block for job costing. When you record any transaction, such as a material purchase, a salary payment or a client invoice, you can assign it to a cost centre that represents a specific job. The software then accumulates all transactions for each cost centre and lets you compare income against expenses for any job in minimal time.
    Here is the detailed workflow of TallyPrime:
    Cost centres
    A cost centre is any named unit to which costs and income can be allocated. In job costing, each job is set up as a separate cost centre. The name you give a cost centre is the name that appears in all reports, so clear naming matters.
    Cost centre hierarchy
    TallyPrime lets you organise cost centres into groups, making it easier to track different parts of a project. For example, if a project has three sub-jobs, you can create a cost centre for the main project and separate cost centres for each sub-job. This lets you view the combined costs and revenue for the project, while also tracking the details of each sub-job separately.
    Cost categories
    A cost category gives you another way to group and track costs across your business. If you use more than one cost category in TallyPrime, you can allocate the same transaction across multiple categories. This is useful when you want to track a cost from different dimensions, such as by job and by department at the same time.
    Cost centre reports
    TallyPrime provides several built-in reports for job costing. The cost centre breakup shows every transaction tagged to a specific job. The cost centre summary shows all jobs side by side with their net balances. A monthly view lets you see how costs have built up over time.
    How do you set up cost centres for job costing in TallyPrime?
    Before you can tag transactions to a job, you need to enable cost centres and create one for each job. The steps below cover the full setup.
    Creating a cost centre for a job
    Press Alt+G (Go To) > Create Master > Cost Centre and press Enter. Alternatively, you can go to Gateway of Tally > Create > Cost Centre and press Enter. If Cost Centres are not enabled, TallyPrime will prompt you to activate the feature. Select Yes or press Y to enable it.
    • Name: Enter the name of the cost centre. You can also specify aliases if required.
    • Under: Select Primary if the cost centre is independent, or select an existing cost centre if you want to group it under another cost centre.
    Review the details and press Ctrl+A to save the cost centre.
    How do you allocate job costs in TallyPrime?
    Allocation happens at the point of recording a transaction. When you enter an expense or income voucher, TallyPrime prompts you to specify a cost centre after you select the ledger account.
    Step 1: Recording expenses against a job
    Open a payment or journal voucher. Select the expense ledger. TallyPrime will display a cost centre allocation screen. Enter the name of the job and the full amount. Save the voucher. The expense is now linked to that job and will appear in its cost centre reports.
    Step 2: Allocating one expense across multiple jobs
    If a single purchase benefits more than one job, enter the total in the voucher and then split it across jobs in the cost centre allocation screen. Add a row for each job and enter the portion each should carry. The individual amounts must add up to the total voucher amount. TallyPrime will not save the entry if they do not match.
    Step 3: Assigning income to a job
    The process for income is identical to the process for expenses. Open a receipt or sales voucher, select the income ledger, and allocate it to the relevant job in the cost centre screen. Without income allocation, TallyPrime can only show the costs for a job, not its profit.
    How do you track job-wise expenses and income?
    Once transactions are allocated, TallyPrime’s reports let you view the financial position of any job. The three most useful views are described below.
    Checking the cost centre breakup
    Go to Gateway of Tally and select Display, then Statements of Accounts, then Cost Centres, then Cost Centre Breakup. Choose the job from the list. TallyPrime shows every income and expense entry tagged to that job, grouped by ledger. You can open any line to see the original voucher.
    Viewing the cost centre summary
    The cost centre summary lists every cost centre with its total income, total expense and net balance in a single screen. Go to Gateway of Tally, then Display, then Statements of Accounts, then Cost Centres, then Cost Centre Summary. This is the fastest way to compare the current financial position of all active jobs.
    Reviewing monthly job costs
    Within the cost centre breakup, press Alt+F2 or use the period filter to switch to a month-by-month view. This shows how costs have accumulated across the life of a job and makes it easier to spot months where spending was unusually high.
    How can you compare the costs of different jobs?
    Use the cost centre summary report to compare jobs. It displays all cost centres in a table with income, expense and net columns. If you want to compare only a subset of jobs, you can filter by cost category or date range. For a more detailed side-by-side view, export the report and arrange the jobs in a spreadsheet. Within TallyPrime, you can also use the columnar format available in some report views to place jobs next to each other.
    How do cost categories help with job costing?
    Cost categories allow you to analyse costs along more than one dimension at the same time. A single transaction can be allocated to one cost centre under the Jobs category and a different cost centre under the Departments category simultaneously.
    Creating a cost category
    Go to Gateway of Tally and select Accounts Info, then Cost Categories, then Create. Enter a name such as Jobs or Departments. Enable “Allocate revenue items” if you want to tag income entries to this category as well. Save with Ctrl+A.
    Using parallel allocation
    When you record a transaction and cost categories are active, TallyPrime will ask you to allocate the entry under each category separately. You can assign it to Job A under Jobs and to the Operations department under Departments in the same voucher. Both allocations are saved, and both appear in the respective reports.
    What are the best practices for accurate job cost tracking?
    Accurate job costing depends as much on process discipline as on software configuration. The practices below reduce the most common sources of error.
    Creating a separate cost centre for each job
    Grouping multiple jobs under one cost centre makes the data impossible to untangle later. Create one cost centre per job from the start, even if the jobs seem similar.
    Using consistent job names
    Decide on a naming convention before you begin. A format such as JOB-YYYY-001 or the client name followed by a project code prevents duplicate or near-duplicate cost centres from appearing in reports.
    Allocating expenses when recording transactions
    Allocating costs at the time of entry is more reliable than doing it later. Entries recorded without a cost centre allocation require a manual journal to correct, and the risk of missing or misallocating them increases the longer the correction is delayed.
    Allotting shared costs carefully
    Costs that benefit more than one job, such as equipment hire or office utilities, must be split on a logical and consistent basis. Document the basis you use, whether it is time spent, square footage or another metric, so the same method is applied each time and can be audited.
    Tracking both income and expenses
    A cost centre that records only expenses cannot show whether a job was profitable. Make income allocation a standard step in your billing process so every job has both sides of the equation.
    Reviewing job costs regularly
    Reviewing cost centre reports at month end or at key project milestones lets you catch cost overruns while there is still time to act. A review only at project completion is too late to influence the outcome.
    Reconciling job costs with financial records
    The total costs allocated across all cost centres for a given ledger should match the ledger’s closing balance in the trial balance. A discrepancy means some transactions were recorded without a cost centre allocation. Identify unallocated entries and correct them with allocation journals before closing the period.
    What is cost centre class in TallyPrime?
    A cost centre class is a saved allocation template that defines how TallyPrime should distribute a transaction across multiple cost centres. You set it up once by specifying the cost centres and their percentage shares. When a voucher is recorded under that class, TallyPrime applies the split automatically.
    This removes the need to manually enter allocation details for every recurring entry, which reduces both the time taken and the risk of allocation errors. Cost centre classes are especially useful for overheads that must be distributed across several active jobs on a fixed formula.
    Do I need cost categories for basic job costing?
    If all you need is to track costs and income by job, a single default cost category with one cost centre per job is enough. Cost categories become relevant when you need to analyse the same transaction across two independent dimensions simultaneously; for example, by job and by department, or by job and by geographical region. Adding cost categories to a basic setup also adds allocation steps to every voucher entry, so it is worth confirming that you actually need the second dimension before enabling multiple categories.
    Conclusion
    Knowing the cost of each job is more useful than knowing the cost of the business as a whole when you are making decisions about pricing, resource allocation or which types of work to take on. Getting there requires two things: a cost structure that mirrors how your jobs are organised, and the discipline to allocate every income and expense entry at the time it is recorded.
    TallyPrime’s cost centre framework handles the reporting side, but the accuracy of those reports depends entirely on what goes in. Set the structure up before transactions begin, name jobs consistently, allocate income as well as expenses, and review the numbers at regular intervals. That combination gives you data you can act on rather than data you need to question.
    FAQs
    Financial accounting records the total income and expenditure of a business and produces statements for external users such as investors and tax authorities. Cost accounting breaks those totals down by job, product or department to show where costs are incurred and whether individual activities are profitable.
    The objectives of cost accounting in a project-based context are to determine the actual cost of each job, to identify which jobs return a profit, and to generate data that supports accurate pricing of future work. Cost accounting also helps identify inefficiencies within a specific job so they can be addressed before they affect the overall business.
    Yes. Any expense ledger, whether it covers raw materials, wages, subcontractor fees or allocated overheads, can be tagged to a cost centre. As long as each expense type uses its own ledger and is allocated to the relevant job at the time of entry, TallyPrime’s reports will show each cost category separately within the job.
    The transaction is posted to the correct ledger in the financial accounts but does not appear in any cost centre report. If several entries are left unallocated, the job cost reports will understate expenses and any profitability figure drawn from them will be overstated. The fix is to identify unallocated entries and post allocation journals to correct them.
    TallyPrime’s cost centre reports show income and expenses for a job and the net difference between them, which gives you the job’s profit or loss. The layout is not the same as a formal profit and loss account. For a formatted P&L by job, you would need to export the cost centre data and structure it separately.
    The cost concept in accounting holds that transactions should be recorded at their actual cost at the time they occur. In TallyPrime, this applies to every voucher entry. The cost centre allocation does not change what is recorded; it determines how that recorded cost is attributed to a job. The two operate at different levels, but both depend on entries being made accurately and at the right time.
    Published on August 18, 2026
