    Which Systems are Good for Indian Packaging Material Manufacturers with Job Work and Conversion Charges?
    Tallysolutions
    Tally Solutions
    Jul 22, 2026
    30 second summary | Packaging manufacturers need software that tracks material movement, job work, conversion charges and GST in one place. While integrated accounting software is sufficient for most small and mid-sized businesses, larger manufacturers with more complex operations may benefit from an ERP system. The right choice depends on the scale and complexity of the business.
    Packaging manufacturers deal with raw materials, job workers, and conversion charges every day. Material moves out to a processing vendor and returns in a different form, and the conversion charges have to land in the final product cost.
    When that movement is not recorded properly, stock figures stop matching reality and costing errors eat into margins. This usually happens because the software cannot track material movement, job work, and conversion charges together. A system that connects all three keeps costing accurate without separate registers or manual reconciliation.
    Types of systems used by manufacturers
    The right system for a packaging business depends on its size, product mix and job work volume. Here is how the common categories compare:
    Accounting software with integrated features
    Tools in this category combine bookkeeping with stock and production tracking. TallyPrime, for instance, manages job work through delivery challans, tracks material sent out for processing, allocates conversion charges to product costing and handles GST compliance without extra plugins. For small and mid-sized packaging units with a single production line, this is often sufficient.
    Manufacturing ERP systems
    Larger operations with multiple production lines sometimes need a full Enterprise Resource Planning (ERP) setup covering procurement, production planning, inventory and shop floor scheduling. This level of customisation comes with a higher cost, and implementation can take months. For many small businesses, this level of complexity is unnecessary.
    Cloud-based business management tools
    These are typically lighter, subscription-driven and accessible through a browser. They suit businesses that value remote access and basic reporting, although many lack the depth required for job work costing or GST-specific documentation.
    Industry-specific solutions
    Some vendors develop software specifically for packaging or plastics manufacturing, with features such as die and mould tracking. These can be useful for niche setups, although they generally cost more and often have a smaller support ecosystem than mainstream accounting software.
    Why do job work and conversion charges matter?
    In a job work arrangement, a packaging manufacturer sends raw material such as kraft paper or plastic granules to an outside vendor. The vendor processes them into printed sheets, laminated rolls or moulded components before returning them.
    Conversion charges are the fees the manufacturer pays the vendor for this processing. Costing errors begin when these charges are not tracked accurately. If a business cannot see exactly how much conversion cost went into a batch, it cannot price that batch correctly. Profitability figures no longer reflect reality, and the problem often remains unnoticed until the end of the quarter.
    Costing typically goes wrong in the following situations:
    • Untracked movement: Raw material sent out for job work may be recorded as a sale or disappear from stock reports, making inventory records unreliable.
    • Manual charge entry: Conversion charges recorded on paper or spreadsheets increase the risk of errors and delay billing.
    • No link between job work and GST: Job work has specific Goods and Services Tax (GST) requirements relating to delivery challans and time limits for returning materials. Basic billing software often cannot manage these requirements.
    This is why plain invoicing tools or generic accounting software without manufacturing capabilities often fall short for packaging manufacturers.
    What do packaging manufacturers need in a system?
    Before picking any software, it helps to understand what it needs to support in day-to-day operations.
    • Raw material, work in progress (WIP) and finished goods tracking: The system should show stock at every stage, not just finished goods in the warehouse. This includes material held by job workers.
    • Job work handling: It should generate delivery challans, track material sent and received, and flag pending job work that exceeds the permitted return period.
    • Conversion charge tracking: Charges paid should be linked to the exact batch or product they relate to. Only then does the true product cost become visible.
    • Purchase, sales and dispatch management: Everything from purchase orders to final dispatch should be managed within one system instead of across multiple registers.
    • GST and accounting support: Job work challans, e-way bills and GST returns should be handled without manual reconciliation.
    • Multi-location stock visibility: Manufacturers operating multiple units or warehouses should be able to view stock and job work status for each location in real time.
    How to choose the right system
    The right pick depends on how the business operates, not simply on what competitors use.
    • Business size: A small unit with a single production line rarely needs a full ERP system. A larger manufacturer with multiple product lines may eventually outgrow basic accounting software.
    • Number of products and job workers: More Stock Keeping Units (SKUs) and more job work vendors require stronger tracking and reporting capabilities, rather than basic bookkeeping features.
    • Need for location-wise stock: Manufacturers operating multiple warehouses or units should prioritise systems that provide both consolidated and location-wise inventory visibility.
    • Reporting and compliance requirements: If GST filings, e-way bills and job work compliance consume significant time, the system should automate as much of the process as possible.
    • Budget and implementation: ERP systems can take months to implement and require considerable staff training. Accounting software with manufacturing features is usually quicker to deploy and easier to adopt.
    Conclusion
    The right system is one that matches the way the business operates. Packaging manufacturers need software that treats job work and conversion charges as part of everyday operations rather than as an afterthought. TallyPrime addresses these requirements by bringing stock tracking, job work challans, conversion costing and GST compliance together in one system, without the overhead of a full ERP implementation. For most Indian packaging businesses, this balance between functionality and simplicity helps maintain accurate costing while keeping operations efficient.
    FAQs
    Yes. A single job worker can process multiple products, provided each movement is documented separately so that material quantities, processing charges and GST compliance remain traceable.
    Conversion charges form part of the manufacturing cost. Recording them accurately helps businesses calculate product-wise margins and set selling prices that reflect the actual cost of production.
    Yes. ITC can be claimed even when inputs are sent directly to a job worker's premises. Under Section 19 of the Central GST (CGST) Act, the principal can claim the credit without first taking physical possession of the goods.
    No. GST law does not require a written agreement. However, maintaining one helps establish the terms of the arrangement and supports compliance during departmental scrutiny or disputes.
    No. The manufacturer can continue claiming depreciation because ownership of the capital goods does not change. Only physical possession is temporarily transferred to the job worker.
    Published on July 22, 2026
