    What is the MSME Turnover Limit and How Is It Calculated for Eligibility?
    Tallysolutions
    Tally Solutions
    Aug 7, 2026
    30 second summary | India revised MSME classification in March 2025, adding annual turnover alongside investment as a dual criterion. Micro-enterprises must stay below ₹10 crore, small enterprises below ₹100 crore and medium enterprises below ₹500 crore in annual turnover. Export sales are excluded from this calculation.
    India’s MSME classification, revised in March 2025, uses two criteria to determine a business’s category. Both investment in plant and machinery or equipment and annual turnover must fall within the prescribed limits.
    If either exceeds the ceiling for a given category, the enterprise moves up to the next tier.
    What are the current MSME turnover limits?
    The Ministry of Micro, Small and Medium Enterprises (MSME) revised its classification criteria through a gazette notification dated 21 March 2025. The framework applies to both manufacturing and service enterprises under a single composite standard, removing the earlier distinction between the two sectors.
    Category
    Investment in plant and machinery or equipment
    Annual turnover
    Micro
    Up to ₹2.5 crore
    Up to ₹10 crore
    Small
    Up to ₹25 crore
    Up to ₹100 crore
    Medium
    Up to ₹125 crore
    Up to ₹500 crore
    An enterprise must meet both criteria to stay within a category. A business with ₹20 crore in investment but ₹120 crore in turnover does not qualify as small. Although the investment is within the small enterprise ceiling (₹25 crore), the turnover exceeds the small enterprise limit of ₹100 crore, placing it in the medium category.
    How is MSME turnover calculated?
    Turnover for MSME classification means the total annual revenue from all business activities of the enterprise. The source of the figure is the enterprise’s Goods and Services Tax (GST) returns, or income tax returns for enterprises not registered under GST.
    Several rules govern the calculation.
    • Turnover is measured for the financial year (FY) running from 1 April to 31 March.
    • For the year of incorporation, only the revenue from the date of incorporation to the end of that FY is counted.
    • If a business operates multiple units under a single Permanent Account Number (PAN), the aggregate revenue across all units is used.
    The classification is reviewed annually. The category assigned for any given FY is based on the investment and turnover figures from the previous FY.
    Does export turnover count toward the MSME limit?
    No. Export revenue is excluded from the turnover calculation under the revised MSME classification framework. The ministry’s gazette notification specifies that exports of goods, services or both are not counted when determining whether an enterprise meets the turnover ceiling for its category.
    A business can therefore have substantial export revenue without that income pushing it into a higher classification tier, as long as domestic turnover stays within the applicable limit. This exclusion lets small enterprises pursue export activity without losing MSME status as a consequence.
    How does Udyam registration verify your turnover?
    The Udyam registration portal draws turnover data directly from the income tax department and the GST Network (GSTN). Enterprises do not self-declare turnover; the portal auto-populates the figure using the PAN and GSTIN linked to the registration.
    This means the figures used for MSME classification match what the enterprise has already reported in official tax filings. If an enterprise files revised returns, the Udyam system reflects the updated figures during the next annual reclassification.
    Conclusion
    MSME eligibility in India rests on two tests: investment and turnover. Both must fall within the right range for the classification to hold. Knowing how turnover is measured, what gets excluded and how the annual update cycle works helps a business plan around its category. This, in turn, helps it make the most of the benefits attached to that category.
    TallyPrime tracks business revenue throughout the year. This makes it easy to monitor where the enterprise stands against the applicable MSME turnover ceiling before the FY closes.
    FAQs
    Yes. Enterprises not registered under GST can use their income tax return figures as the turnover basis during Udyam registration. The classification process does not require a GSTIN if the enterprise is below the GST registration threshold.
    The figure used is the gross turnover reported in GST or income tax returns. There is no separate adjustment for returns, discounts or taxes in the MSME classification exercise.
    The composite limit applies to all activities of the enterprise. Since July 2020, there is no separate limit for manufacturing and service functions. Total investment and total turnover from all activities are assessed together.
    No. The investment and turnover limits under the Micro, Small and Medium Enterprises Development (MSMED) Act apply uniformly across all sectors and states. There is no sector-specific or state-level variation to the thresholds.
    No. The category is determined entirely by the actual investment and turnover figures from official filings. An enterprise cannot opt into a higher classification tier.
    Revenue from business activities is what counts. Passive income, including dividends or rental income from property unrelated to the business, is generally not included in the turnover figure used for MSME classification.
    Published on August 7, 2026
