What Is a PO Invoice and Why Every Business Needs It for Streamlined Procurement
    Tallysolutions
    Tally Solutions
    Jul 8, 2026
    30 second summary | A PO invoice is a supplier invoice linked to a purchase order. Although it is not a separate document type, it helps businesses verify ordered, received and billed items before payment. PO-based procurement improves spending control, reduces payment errors and duplicate payments, and strengthens the audit trail.
    A Purchase Order (PO) invoice is a supplier invoice that references a purchase order, helping businesses verify that goods or services were authorised, received and billed correctly before payment is made. By linking supplier invoices with purchase orders and receipt records, PO-based procurement reduces payment errors, speeds up discrepancy resolution and provides stronger control over procurement spending and audit compliance.
    What is a PO invoice?
    A PO invoice is a supplier invoice that references an approved purchase order. It is not a separate document type; the purchase order number allows the buyer to link the invoice to the original order for verification and payment approval. This creates a clear trail between what was ordered, what was received and what is being billed.
    For example, if a company issues a purchase order for 100 units of a product at ₹500 per unit, the supplier invoice should include the PO number and reflect the agreed quantities and pricing. This makes verification significantly easier before payment is approved.
    How does PO-based procurement work?
    PO-based procurement works by linking purchasing, receiving and payment documents so that each transaction can be approved, verified and matched before payment is released. While workflows vary between organisations, most PO-based procurement processes follow a similar sequence:
    1. Purchase Requisition
    2. Purchase Order
    3. Goods Receipt
    4. Supplier Invoice
    5. Payment
    Each document serves a different purpose:
    Document
    Purpose
    Internal request/requirement to procure goods or services
    Purchase Order (PO)
    Authorises the purchase and records agreed quantities, prices and terms
    Goods Receipt Note (GRN)
    Confirms what was actually received
    Supplier Invoice
    Requests payment for the goods or services supplied
    Payment Record
    Confirms settlement of the invoice
    When these documents are connected, businesses can verify transactions before releasing funds and quickly identify discrepancies if they arise.
    How does PO-based procurement improve control?
    PO-based procurement improves control by introducing verification at multiple stages before payment is approved.
    Prevents unauthorised purchases
    A purchase order typically goes through an approval process before an order is placed. This helps ensure that payments can be linked to authorised procurement decisions rather than informal purchasing requests.
    Detects pricing and quantity discrepancies
    When invoices are matched against purchase orders, businesses can identify situations where:
    • Quantities differ from the original order
    • Prices do not match the agreed rates
    • Additional line items have been added
    These issues can be addressed before payment is processed.
    Reduces duplicate payments
    Matching invoices against procurement records makes it easier to identify duplicate or erroneous invoices before funds are released. Invoice matching is widely used as a control against duplicate and inaccurate payments.
    Creates a stronger audit trail
    Every payment can be traced back through the purchase order, receipt, invoice and payment record. This provides greater transparency during audits, vendor reviews and internal control assessments.
    Where are PO invoices most commonly used?
    PO invoices are most commonly used in procurement processes involving significant spending, inventory movement or multiple approval levels. Typical use cases include:
    • Inventory procurement
    • Raw material purchases
    • Manufacturing inputs
    • Capital asset purchases
    • Recurring supplier relationships
    • High-value procurement transactions
    Why does invoice matching matter?
    Invoice matching matters because it helps businesses verify that supplier invoices are accurate before payment is approved. By comparing a supplier invoice against procurement records, businesses can confirm that the invoice reflects what was actually ordered and received.
    Two-way matching
    Two-way matching compares the purchase order with the invoice.
    The business verifies whether:
    • Supplier details match
    • Quantities match
    • Prices match
    • Invoice amounts align with the purchase order
    This approach is commonly used for service-based purchases where there may not be a physical receipt process.
    Three-way matching
    Three-way matching adds another layer of control by linking the goods receipt, purchase order and invoice.
    Before payment is approved, the business verifies:
    • What was ordered
    • What was received
    • What is being billed
    This is widely regarded as the standard control mechanism for goods-based procurement because it helps prevent payment for items that were never delivered or were billed incorrectly.
    How does invoice matching work in practice?
    Invoice matching compares procurement documents to identify differences between what was ordered, what was received and what is being billed before payment is approved.
    Consider the following example. A company issues a purchase order for:
    • 500 units
    • ₹200 per unit
    • Total value: ₹1,00,000
    The supplier delivers only 480 units. However, the supplier invoice is raised for the full 500 units.
    Document
    Quantity
    Purchase Order
    500 units
    Goods Received
    480 units
    Supplier Invoice
    500 units
    A three-way matching process immediately identifies a variance of 20 units worth ₹4,000. Without this control, the company could pay for goods it never received. With proper matching, the discrepancy can be investigated and resolved before payment is released.
    PO invoice vs non-PO invoice
    The key difference between a PO invoice and a non-PO invoice is that a PO invoice is linked to an approved purchase order, while a non-PO invoice is processed without a purchase order reference.
    Not every business expense requires a purchase order, and many operational expenses are incurred outside a formal procurement process.
    Scenario
    PO Invoice
    Non-PO Invoice
    Inventory purchases
    Yes
    Rarely
    Raw materials
    Yes
    Rarely
    Capital equipment
    Yes
    Rarely
    Office supplies
    Often
    Sometimes
    Rent
    No
    Yes
    Electricity and utilities
    No
    Yes
    Insurance premiums
    No
    Yes
    Professional services
    Depends on policy
    Common
    SaaS subscriptions
    Sometimes
    Common
    The choice depends on the nature of the expense. High-value, inventory-related and controlled purchases typically follow PO-based procurement, while recurring operational expenses are often processed without a purchase order.
    Conclusion
    A PO invoice is more than a supplier bill with a purchase order reference; it is a key part of a controlled procurement process. By connecting purchase orders, goods receipts and supplier invoices, businesses can verify transactions before payment, reduce errors, prevent duplicate or incorrect payments and maintain a stronger audit trail.
    As procurement volumes grow, these controls become increasingly important for managing costs and protecting working capital. With TallyPrime, businesses can maintain connected procurement, inventory and accounting records in a single system, helping them strengthen invoice matching, improve visibility and support better purchasing decisions.
    Published on July 8, 2026
