    PF/EPF Employer Compliance Guide
    Abilash Senguttuvan
    Updated on Sep 28, 2026
    30 second summary | Employees’ Provident Fund (EPF) is a retirement scheme for organised-sector employees, governed by EPFO, requiring employers and employees to each contribute 12% of wages monthly. Employer responsibilities span registration, contribution splits, monthly ECR filing and documentation. Staying compliant helps avoid penalties and builds employee trust.
    Every month, Indian employers set aside a portion of their employees' wages into a fund meant to grow over time, subject to applicable withdrawal rules for retirement, job changes and other permitted circumstances. This is the idea behind the Provident Fund (PF), a retirement savings mechanism built on regular monthly contributions.
    The Employees' Provident Fund (EPF) is a statutory social security and retirement savings framework administered by the Employees' Provident Fund Organisation (EPFO). The Code on Social Security, 2020, which came into force on 21 November 2025, forms part of the current legal framework for social security, while EPFO continues to administer the applicable PF, pension and insurance schemes and related procedures.
    Staying compliant with EPF requirements helps businesses meet statutory obligations, avoid interest, damages and other compliance consequences, and keep employee records in order. It also supports employees’ access to PF, pension, insurance and related social security benefits
    How does EPF employer compliance work?
    The monthly EPF process starts with calculating the employer and employee contributions and reporting them through the Electronic Challan-cum-Return (ECR). The contributions are credited or accounted for under the relevant EPFO schemes against the employee's member records linked with the UAN.
    Establishments with 20 or more employees are generally covered, subject to the applicable provisions and rules. The ₹15,000 monthly wage ceiling remains relevant for mandatory coverage and certain contribution calculations, including the Employees' Pension Scheme (EPS). Employees earning above the prescribed ceiling may also continue or become covered under circumstances permitted by applicable law, including eligible joint options or voluntary higher-wage contributions.
    Smaller establishments can seek voluntary coverage subject to the prescribed conditions, and once an establishment comes under EPF coverage, it generally remains covered even if its employee count later falls below 20. Under the current social security framework, EPF coverage applies more uniformly to establishments with 20 or more employees, regardless of industry classification.
    The process mainly relies on a few key identifiers and records:
    • UAN: A unique and portable number allotted to an employee that helps link EPF member IDs across eligible employments.
    • Establishment code: A unique reference number allotted to the employer at the time of EPFO registration, used for identification and prescribed compliance processes.
    • ECR: The monthly electronic return and challan process used to report wage, contribution and other prescribed member details, replacing several earlier paper-based reporting requirements.
    How to stay EPF-compliant: Step-by-step process
    Once an establishment becomes liable, EPF compliance involves a one-time registration followed by a recurring monthly filing and payment cycle.
    Step 1: Register as an employer
    Start by checking the 20-employee threshold for EPF applicability, considering the employees relevant for coverage. Once liable, register through the EPFO Unified Portal within 30 days and receive the establishment code.
    Step 2: Set up employee UAN and KYC
    Generate a UAN for every eligible employee and approve UAN activation from the employer portal. Complete the required KYC with Aadhaar, PAN and bank details. File and update Form 5A, containing ownership particulars, when ownership details change.
    Step 3: Calculate monthly contributions
    Calculate the employer and employee contributions at 12% of basic wages plus dearness allowance for both employer and employee shares. The employer’s share is then divided among EPF, Employees’ Pension Scheme (EPS), Employees’ Deposit Linked Insurance (EDLI) and administrative charges.
    Step 4: File the ECR and generate challan
    Upload the monthly wage and contribution information in the specified format on the EPFO Unified Employer Portal. The challan amount would be generated based on the uploaded information. Filing a nil return is mandatory even if there are no contributing members.
    Step 5: Make the payment
    Pay through net banking, National Electronic Fund Transfer (NEFT) or Real-Time Gross Settlement (RTGS) using the portal’s payment gateway. ECR filing and payment are due by the 15th of the following month. For example, July wages are due by 15 August, even if the date falls on a weekend or holiday.
    What is the EPF contribution rate breakup for employers?
    In most covered establishments, both the employer and employee generally contribute 12% of the applicable PF wage base, subject to prescribed exceptions. The employee's entire 12% generally goes into the EPF account. The employer's 12% statutory contribution is generally allocated between EPF and EPS, while EDLI contributions and administrative charges are additional employer costs.
    Component
    Rate
    EPF
    3.67% of applicable wages, where the standard EPS allocation applies
    EPS
    8.33% of applicable wages, subject to the prescribed ₹15,000 wage ceiling and a maximum contribution of ₹1,250 per month under the standard ceiling-based calculation
    EDLI
    0.50%
    EPF administrative charges
    0.50%, subject to the applicable minimum monthly charge and other prescribed conditions
    EDLI administrative charges
    Nil, as the EDLI administrative charge was removed from June 2018
    In effect, for a typical non-exempt establishment subject to the standard rates, an employer's total monthly PF-related outflow works out to around 13% of the applicable wage base, once the employer's 12% contribution, EDLI contribution and EPF administrative charges are considered. The actual effective cost may vary because of minimum charges, exemptions and other applicable statutory conditions.
    What documents and returns should employers maintain?
    Beyond the monthly ECR, employers are expected to maintain the following supporting records and declarations, either for filing or for audit readiness:
    Document/Return
    Purpose
    Form 2
    Employee nomination details collected at joining
    Form 11
    Declaration of previous EPF membership to link past accounts with the current UAN
    Wage register
    Payroll record of wages, used during EPFO audits/inspections
    Contribution register
    Monthly record of EPF, EPS and EDLI contributions
    Attendance register
    Attendance record cross-checked with wages and contributions during inspections
    Form 3A
    Annual member-wise contribution record, auto-generated from ECR and retained for audit purposes
    New-joiner/exit reporting
    Earlier filed through Forms 5 and 10, now captured in the monthly ECR
    How do you manage ongoing employer responsibilities beyond the monthly challan?
    Once registered, employers also need to track a few recurring tasks alongside the monthly ECR:
    • Attesting transfer claims: When an employee submits an online PF transfer claim, the employer (previous or present, depending on the claim) must attest it using a Digital Signature Certificate (DSC).
    • Verifying previous employment details: If a member’s earlier employment details aren’t in the EPFO database, the previous employer must verify them using their DSC.
    • Maintaining accurate payroll records: UAN mismatches, incorrect EPS wage-ceiling calculations, and unrecorded Non-Calculable Period (NCP) days for employee leave are common errors that delay ECR processing.
    • Annual reconciliation: Employers should reconcile the year's monthly ECRs, challans, contribution records and relevant portal-generated data to identify and correct mismatches.
    What is the effect of the Code on Social Security, 2020?
    The Code on Social Security, 2020 came into force on 21 November 2025 and has introduced several changes to the EPF compliance framework:
    • Wage definition: Basic pay and dearness allowance (DA) must make up at least 50% of total remuneration. Certain excluded components beyond this threshold are added back, which can increase the EPF-contributable wage base.
    • EPF Transition: The 50% wage rule started on 21 November 2025. While legacy schemes (EPF 1952, EPS 1995, EDLI 1976) have a one-year transition period until 21 November 2026, employers must calculate and pay contributions using the new 50% wage definition immediately.
    • Lower appeal deposit: The amount required to appeal an EPFO order has been reduced to 25% of the disputed amount, down from 40–70%.
    • Wider coverage: EPF coverage is being applied more uniformly across establishment types, irrespective of industry classification.
    What are the penalties for non-compliance?
    Missing the payment deadline triggers two separate financial consequences under the EPF Act:
    • Interest under Section 7Q: 12% interest per annum, calculated from the day after the due date until the date of actual payment, is applied.
    • Damages under Section 14B: Penal damages apply to arrears, ranging from 5% per annum for delays of up to two months to 25% per annum for delays exceeding six months.
    The EPF Act provides for imprisonment of up to 1 year for most general non-compliance or evasion offences, though specific fraud or repeat defaults can carry heavier scrutiny. Delayed payments can further create backlogs in the EPFO system, making regular and timely compliance important.
    Conclusion
    EPF compliance is an ongoing payroll responsibility, particularly as the latest wage-related provisions continue to take effect through 2026. Making EPF part of the regular payroll process can help businesses avoid interest, damages and compliance issues.
    TallyPrime’s payroll module helps manage PF, ESI and other statutory deductions accurately, making routine compliance easier. Start your free TallyPrime trial today to experience the benefits firsthand.
    FAQs
    No, apprentices engaged under the Apprentices Act are excluded from mandatory EPF coverage.
    No, the employer bears EPF administrative and EDLI charges entirely, not the employee.
    Yes, with EPFO exemption under Section 17, subject to conditions and separate inspection charges.
    According to Employees' Provident Fund Organisation rules, an EPF account of a member retiring at age 58 actually continues to accrue interest for an additional 3 years (until age 61) before turning inoperative.
    Yes, withdrawals above ₹50,000 before 5 years attract TDS, unless specific exemptions apply.
    Published on September 8, 2026
