    How to Monitor Multiple Payments and Refunds Across Indian Government and Financial Portals
    Tallysolutions
    Tally Solutions
    Jul 14, 2026
    30 second summary | Monitor payments across GST, Income Tax, MCA and EPFO portals using a central payment log, challan verification and monthly reconciliation. Refunds should be monitored through portal-specific tracking tools and reviewed regularly to identify delays, incorrect credits or pending compliance actions.
    To monitor multiple payments and refunds across Indian government and financial portals, businesses should maintain a central payment log, verify transactions using challan or reference numbers, track refund applications regularly and reconcile records every month. This approach helps ensure that payments made through portals are correctly credited and that refund delays or discrepancies are identified early.
    In this article, we will explain a practical process for tracking payments, monitoring refunds and keeping records accurate across multiple platforms.
    What are the steps to track multiple payments across Indian government portals?
    Here are the steps businesses can follow to track multiple payments:
    Step 1: Map out which portals you need to monitor
    Before setting up any tracking routine, list every portal your business regularly interacts with. The common ones for most businesses registered in India are listed below.
    Portal
    What you can track
    Where to find it
    GST portal (gst.gov.in)
    GST payments, IGST refund status, challan history
    Services > Payments > Challan History / Refunds > Track
    Income tax portal (incometax.gov.in)
    Advance tax, self-assessment tax, TDS refund, demand status
    e-File > Income Tax Returns > View Filed Returns
    MCA21 (mca.gov.in)
    Company filing fees, SRN status, payment receipts
    MCA Services > Track Your Payment / Track SRN
    EPFO member portal (epfindia.gov.in)
    PF contribution credits, ECR payment status, claims
    Member Home > Service History
    RBI NEFT/RTGS / payment bank portals
    High-value transfers, vendor remittances
    Bank statements, UTR-based tracking in net banking
    Step 2: Use a single ledger to log every outgoing payment
    The most reliable way to monitor payments across multiple portals is to maintain a single centralised payment log, updated on the day each payment is sent.
    This log should capture the following for every transaction.
    • Portal name and the head of payment (for example, GST/IGST or advance tax)
    • Amount paid and the date of payment
    • Challan identification number (CIN) or unique transaction reference (UTR) number
    • Expected reflection date on the portal (typically one to two working days)
    • Actual confirmation date once it appears on the portal
    • Refund claim reference number, if applicable
    A spreadsheet works for small volumes. For businesses handling 20 or more transactions a month across portals, accounting software that auto-posts bank entries against specific tax heads significantly reduces manual effort and speeds up reconciliation.
    Step 3: Verify payments using challan numbers
    A bank debit alone does not confirm that a payment has been credited to the right government account. Use the challan or reference number to verify on each portal.
    • GST portal: Go to Services > Payments > Challan History. Enter the challan identification number (CIN) generated at the time of payment. The portal shows whether the amount has been credited to the electronic cash ledger under the correct head (IGST, CGST, SGST or cess).
    • Income tax portal: Go to e-File > Income Tax Returns > View Filed Returns, or use the 'Pending Actions' tab. For challan verification, the portal allows you to check payment status using the BSR code and challan serial number.
    Step 4: Track refund status systematically
    Refunds on Indian government portals move through multiple stages. Checking the status only once after filing is not enough. Each portal has a specific tracking path.
    1. GST refunds: Go to Services > Refunds > Track Application Status. Enter the application reference number (ARN). The portal shows the current stage, from filing acknowledgement through to payment order and bank credit.
    2. Income tax refunds: Use the ‘Refund / Demand Status’ tab under the ‘My Account’ section, or use the NSDL refund status tracker at tin.tin.nsdl.com with your PAN and assessment year. The status moves from ‘Refund Issued’ to ‘Credited to Bank Account’ once NSDL sends it.
    3. TDS refunds: If the refund arises from excess TDS deduction, it is processed through the income tax refund system after filing ITR. Verify that the bank account linked to the income tax portal is pre-validated and ECS-enabled, as refunds most often fail due to a bank account mismatch.
    Set a calendar reminder to check the refund status every 7 to 10 days after filing. Refunds can be held for additional documents or bank account re-validation and the portal does not always send an alert when this happens.
    Step 5: Reconcile monthly, not at year-end
    A monthly reconciliation routine catches errors when they are still correctable. The steps below apply across all portals.
    1. Download the ledger or statement from each portal for the month. On the GST portal, this is the electronic cash ledger and the electronic credit ledger.
    2. Match each portal entry against your payment log and bank statement. Any entry present in the bank statement but absent from the portal log needs follow-up.
    3. Flag any challan where the amount or tax head does not match what was intended. On the GST portal, a wrongly classified payment (for example, CGST credited instead of IGST) can be transferred using the GST PMT-09 form without losing the amount.
    4. Check for expired challans. An unused challan on the GST portal is valid only for 15 days after generation. An unused challan for income tax is valid for 15 days. After expiry, it cannot be used for payment, and a new challan must be generated.
    5. Review any refund applications that have been pending for more than 30 days and check whether the portal has raised a deficiency memo or an audit query.
    Conclusion
    The discipline that makes multi-portal tracking work is consistency, not complexity. A payment log updated on the day of each transaction, a monthly reconciliation for each portal and a clear refund follow-up calendar are enough for most businesses to stay current.
    As the volume grows, accounting software that integrates with GST and income tax data, such as TallyPrime, reduces manual reconciliation by pulling ledger data and challan details into one place, making discrepancies visible without logging into each portal separately.
    Published on July 14, 2026
