    How to Estimate Working Capital Requirements: Methods and Strategies for Business Owners
    Tallysolutions
    Tally Solutions
    Jun 2, 2026
    30 second summary | Working capital is the money a business needs to fund its day-to-day operations. Estimating it accurately helps you avoid cash shortfalls, plan borrowing and keep operations running without interruption.
    Working capital is the difference between a business’s current assets and current liabilities: it is the net liquid resource available to run operations day to day. To estimate how much you need, calculate your operating cycle (the time between spending cash and recovering it from customers), then multiply it by your average daily operating cost. The result tells you the minimum cash your business must keep available at all times.
    Most businesses underestimate this figure and then scramble for short-term loans when suppliers need to be paid before customers have settled their invoices. Getting the estimate right from the start removes that pressure.
    What are the methods to estimate working capital requirements
    There are three widely used methods. The right one depends on your business type, stage, and the data you have available.
    1. The operating cycle method
    This is the most precise method for businesses with defined production or trade cycles.
    Formula: Working capital required = (Daily operating cost) x (Operating cycle in days)
    To apply it:
    • Calculate total operating costs per year (purchases, wages, overheads).
    • Divide by 365 to get the daily operating cost.
    • Estimate your operating cycle: add average inventory holding days, average collection days from debtors, then subtract average payment days to creditors.
    • Multiply the daily operating cost by the operating cycle length.
    Example: A manufacturer with annual operating costs of ₹73,00,000, an inventory holding period of 45 days, a debtor collection period of 30 days, and a creditor payment period of 20 days has an operating cycle of 55 days. Daily operating cost = ₹20,000. Working capital required = ₹20,000 x 55 = ₹11,00,000.
    2. The balance sheet method
    This method uses your existing balance sheet to check whether your current assets adequately cover your current liabilities.
    Formula: Net working capital = Current assets – Current liabilities
    A positive figure means the business has a buffer. Lenders, particularly banks, use this method when assessing working capital loan eligibility under the Tandon Committee norms, which the Reserve Bank of India (RBI) introduced as a guideline for bank credit to industry.
    3. The projected sales or turnover method
    This method is suited to trading businesses and those with predictable revenue. It estimates working capital as a percentage of projected annual sales.
    Formula: Working capital required = (Projected annual sales / 5) or 20% of projected sales
    The 20% figure is a rough benchmark. The actual percentage depends on your industry margins, payment terms and inventory turnover. Businesses with fast inventory movement and prompt-paying customers may need as little as 10%; those with slow collections may need 25% or more.
    What are the factors that affect your working capital estimate
    No estimate is static. The following factors can push your actual requirement higher or lower than your initial calculation:
    • Business seasonality: If sales spike during festivals or harvest seasons, your peak working capital needs may be 30–50% higher than the annual average.
    • Credit terms: Giving customers 60-day credit instead of 30-day credit doubles your receivables cycle and increases your requirement accordingly.
    • Supplier terms: Securing longer payment terms from suppliers reduces your net working capital need.
    • Inventory management: Excess stock ties up cash. Reducing days of inventory held frees up working capital without additional borrowing.
    How to manage working capital effectively
    Accurate estimation is only the first step. These strategies help you make the most of the working capital you have:
    • Tighten your receivables cycle by sending invoices immediately after delivery and following up on overdue payments within 7 days of the due date.
    • Negotiate extended payment terms with suppliers, particularly for regular, high-volume purchases.
    • Review your inventory levels monthly. Holding stock that is not moving within 90 days is usually a sign of over-purchasing.
    • Use a rolling 13-week cash flow forecast so you can spot shortfalls three months in advance and arrange credit before it becomes urgent.
    • If you have seasonal peaks, arrange a working capital credit line before the peak, not during it, since banks take 3–4 weeks to process credit applications.
    Conclusion
    Estimating working capital accurately helps businesses maintain smooth operations, avoid cash shortages and improve financial stability. By choosing the right estimation method and reviewing requirements regularly, businesses can plan growth with greater confidence and control. Using accounting and business management software like TallyPrime can simplify cash flow tracking, inventory management and financial planning.
    FAQs
    A current ratio of 2:1 is often cited as a safe benchmark, meaning current assets are double the current liabilities. However, this varies by industry.
    GST creates a timing mismatch: businesses pay GST on purchases immediately but recover the credit only when they file returns and offset it against output tax liability.
    At a minimum, once a year as part of annual budgeting. Additionally, any of the following should trigger a revision: a 20% or more change in revenue, a significant change in customer and etc.
    Gross working capital refers to the total value of a business’s current assets (cash, receivables, inventory and short-term investments). Net working capital is current assets minus current liabilities.
    Yes. Excess working capital usually signals that cash is sitting idle in receivables, inventory or bank accounts instead of being reinvested.
    Published on June 2, 2026
