What is an IT audit? An information technology (IT) audit is a structured assessment of an organisation’s systems, controls and processes to check whether they are secure, compliant and working effectively. It helps identify risks, protect data and ensure systems support business operations.
Auditors review software, hardware, security protocols and data practices using established frameworks such as ISACA (COBIT), ISO (ISO 27001) and NIST to identify gaps and recommend improvements.
Why should companies conduct regular system evaluations?
Regular evaluations ensure that the technology infrastructure supports core business operations without disruptions. Companies rely on digital systems for activities such as inventory management and financial reporting, and an IT assessment helps identify inefficiencies that may affect productivity.
Assessing your systems helps businesses in the following ways:
- Risk mitigation: Identifies vulnerabilities before they are exploited, helping protect sensitive data.
- Regulatory compliance: Verifies adherence to legal frameworks, including data protection laws such as India’s Digital Personal Data Protection Act, 2023.
- Resource optimisation: Highlights underutilised software and systems to help reduce costs.
- Cyber resilience: Improves preparedness against threats such as ransomware, phishing and evolving cyber risks.
What are the primary types of technology infrastructure reviews?
Organisations use different types of IT audits based on operational needs and regulatory requirements. IT audits are usually classified into the following categories:
- IT General Controls (ITGC): Evaluates access controls, change management processes and IT operations.
- Application controls audit: Reviews specific business applications to ensure data accuracy and processing integrity.
- Cybersecurity audit: Assesses threat detection, prevention and incident response capabilities.
- Cloud and infrastructure audit: Examines cloud environments, third-party services and hybrid systems.
- Systems development audit: Reviews how software is designed, developed and implemented.
How does a compliance-focused review differ from an operational one?
A compliance review measures your systems against external legal and regulatory standards set by governing bodies. An operational review focuses on internal efficiency and improving system performance.
IT audits often combine both approaches using a risk-based method to prioritise high-impact vulnerabilities and critical systems. Compliance reviews help reduce legal risks, while operational reviews help improve the use of technology resources.
How do you prepare for a comprehensive technology review?
Preparation affects how smooth and effective an IT audit will be. Management teams need to gather relevant documentation and provide auditors with appropriate system access. Clear communication helps minimise disruption to daily operations. If the scope is unclear or the documentation is incomplete, the audit may miss critical risks or face delays.
Before the audit begins, organisations should:
- Define the scope: Identify which systems, applications and network segments require evaluation.
- Gather documentation: Collect prior audit reports, network diagrams and security policies.
- Assign internal roles: Designate staff to coordinate with auditors.
- Create an IT asset inventory: Track all hardware, software and digital assets.
- Conduct a preliminary risk assessment: Identify high-priority areas.
What specific areas do auditors focus on during the inspection?
Auditors examine multiple layers of the IT environment to assess overall system health. They review controls, policies and system processes to identify risks and gaps.
The inspection typically covers:
- Access management: Ensures only authorised users can access sensitive data.
- Change management: Reviews how updates and system changes are tested and implemented.
- Disaster recovery: Evaluates backup systems and business continuity plans.
- Identity and access management (IAM): Includes role-based access and multi-factor authentication.
- Cloud security controls: Assesses SaaS, IaaS and hybrid infrastructure environments.
- Endpoint security: Focuses on protecting devices connected to organisational networks.
Final remarks
A well-executed IT audit is not a one-time activity but a continuous improvement process. Prioritise high-risk areas, maintain updated documentation and integrate audit findings into your business processes. Regular evaluations help strengthen security, ensure compliance and improve system performance.
To support audit readiness, using reliable accounting software can help maintain accurate records and reduce manual errors. With TallyPrime, we help businesses manage financial data, maintain consistency and stay prepared for audits with better control over their systems.
