HSN stands for Harmonized System of Nomenclature, which is a 6-8 digit number used to classify goods all across the world. This helps with taxation and with keeping track of the trade in such goods. HSN Code 8471 applies to automatic data processing (ADP) machines such as computers, laptops, and related units.
Most products under this category attract an 18% GST rate in India. Correct classification ensures accurate GST returns, proper invoicing, and compliance with import and export requirements. Businesses can also claim Input Tax Credit (ITC) on eligible purchases.
What falls under HSN Code 8471?
HSN Code 8471 covers automatic data processing (ADP) machines and their functional units, along with certain specialised data-handling equipment.
As per the official classification, this category includes:
- Automatic data processing machines (computers, laptops, servers)
- Units of such machines (input/output devices, storage units, processing units)
- Magnetic or optical readers are used to read encoded data
- Machines for transcribing data onto data media in coded form
- Machines that process data but don’t clearly fit into any other specific HSN category.
For example, a specialised industrial or laboratory device like a custom-built data processing unit used in industrial automation that doesn’t qualify as a standard computer or telecom device, or a dedicated data logging and processing machine used in laboratories to capture and analyse test data.
Detailed product classification under HSN Code 8471
Products under HSN 8471 are divided into sub-categories based on their function:
HSN Code |
Description |
GST Rate |
CESS (%) |
8471 |
Automatic data processing (ADP) machines, including computers, data readers, and data processing devices not classified elsewhere |
18% |
0 |
84711000 |
Analogue or hybrid automatic data processing machines |
18% |
0 |
847130 |
Portable computers (laptops, notebooks, tablets) weighing up to 10 kg with CPU, keyboard, and display |
18% |
0 |
84713010 |
Personal laptops and portable computers |
18% |
0 |
84713090 |
Other portable data processing machines |
18% |
0 |
847141 |
Computers with CPU, input, and output units combined in a single housing |
18% |
0 |
84714110 / 20 / 90 |
Other digital computers with integrated components (various types) |
18% |
0 |
84714900 |
Other digital ADP systems not elsewhere specified |
18% |
0 |
84715000 |
Standalone processing units (CPU units) not combined with input/output devices |
18% |
0 |
847160 |
Input or output devices (with or without storage) |
18% |
0 |
84716010 – 84716090 |
Various input/output devices such as keyboards, scanners, and other peripherals |
18% |
0 |
847170 |
Storage devices for data processing systems |
18% |
0 |
84717010 |
Floppy disk drives |
18% |
0 |
84717020 |
Hard disk drives (HDD) |
18% |
0 |
84717030 |
Removable or exchangeable storage devices (e.g., USB drives) |
18% |
0 |
84717040 / 50 |
Magnetic tape and cartridge tape storage devices |
18% |
0 |
84717060 |
CD-ROM drives |
18% |
0 |
84717070 |
DVD drives and similar optical storage devices |
18% |
0 |
84717090 |
Other storage devices not specifically classified |
18% |
0 |
84718000 |
Other units of ADP machines (not covered elsewhere) |
18% |
0 |
84719000 |
Other data processing machines and related equipment not elsewhere classified |
18% |
0 |
Note: Some devices such as networking equipment, may fall under other HSN codes (e.g., 8517) depending on their function.
Common classification exceptions under HSN 8471
Certain IT hardware items are often confused with HSN 8471 but are classified differently as per the GST tariff schedule and customs classification rules.
Monitors:
- Generally classified under HSN 8528 as “monitors and projectors,” not under HSN 8471
- GST rate may be 18% or 28%, depending on specifications and applicable GST rate notifications
- Only monitors that are solely or principally used with automatic data processing (ADP) machines may be classified under HSN 8471, as per tariff interpretation rules
Printers:
- They are classified under HSN 8443 as per the GST tariff classification
- The GST rate applied is 18%
This classification is based on the GST tariff schedule aligned with the Customs Tariff Act and relevant notifications issued by the Central Board of Indirect Taxes and Customs (CBIC).
What are the invoicing and GST filing requirements?
Businesses selling computers, laptops, and related IT hardware under HSN Code 8471 must follow specific GST documentation and reporting rules to stay compliant.
HSN codes in invoices
Your GST invoices must include the correct HSN code for each product sold. Businesses with higher turnover are required to mention 6-digit or 8-digit HSN codes as per GST rules. Using the correct HSN code ensures accurate tax calculation and helps you avoid mismatches during GST return filing. For example, laptops are classified under HSN code 84713010, while desktop computers fall under HSN code 84714110.
Reporting sales in GST returns
You must report all sales of IT hardware properly in GST returns. In GSTR-1, you are required to report details of all outward supplies, including invoice-wise data and corresponding HSN codes. GSTR-3B is a summary return where businesses declare total sales and claim Input Tax Credit (ITC). Accurate reporting in both returns will ensure correct tax payment and smooth reconciliation with buyers.
E-way bill requirements
You’ll need to generate an e-way bill when transporting goods, and the consignment value exceeds ₹50,000. This requirement applies to the movement of goods for sale, stock transfers between branches, and supplies made for job work or other business purposes. You may face penalties or transit-delays on failing to generate an e-way bill.
Common errors businesses should avoid while using HSN code 8471
These mistakes can lead to penalties, notices, or ITC denial:
- Misclassifying monitors or printers under the wrong HSN
- Not updating HSN codes in invoices
- Claiming ITC on ineligible purchases
- Ignoring import licensing requirements
- Incorrect reporting in GST returns
Why correct HSN classification matters
For IT hardware businesses, even minor classification errors can lead to significant compliance issues. Accurate HSN usage ensures:
- Proper GST rate application
- Smooth GST return filing
- Faster customs clearance
- Reduced risk of tax disputes
- Seamless reconciliation of ITC
Conclusion
As digital infrastructure expands, the scope and scrutiny of HSN Code 8471 continue to grow. Businesses dealing in computers and peripherals should not only focus on GST rates but also stay updated on evolving import policies and classification nuances, especially for hybrid devices and advanced hardware.
Using reliable accounting software like TallyPrime help in automating GST calculations, and ensure accurate return filing. It will help businesses stay compliant without manual errors.
