    SAC Code for Rental Services: Property, Vehicle, Equipment Rent GST Guide
    Tallysolutions
    Tally Solutions
    May 12, 2026
    30 second summary | Different SAC codes apply depending on what is being rented, such as property, vehicles or equipment. Correct classification is important for GST compliance. Tenants can claim input tax credit only if the landlord is GST registered. If not, GST may be payable under the reverse charge mechanism. Using the wrong SAC code can lead to errors in GST returns and penalties.
    The 997212 HSN Code applies to the renting or leasing of non-residential property under GST and is taxed at 18% under Harmonised System of Nomenclature (HSN) 9972, which covers real estate services. This classification directly impacts Goods and Services Tax (GST) rate application, input tax credit (ITC) eligibility and return accuracy, making correct coding essential for compliance.
    Rental services under GST are broadly classified into immovable property, vehicles with an operator and equipment leasing, each mapped to different Service Accounting Codes (SAC) codes with separate tax treatment.
    Incorrect classification can lead to errors in GST returns, mismatches in GSTR-2B and increased scrutiny, so accurate SAC code selection is necessary from the outset.
    What rental services fall under HSN code 997212?
    The 997212 HSN Code applies to the renting or leasing of non-residential property by owners or leaseholders. It covers commercial spaces used for business or income generation.
    Common examples include:
    • Offices and co-working spaces
    • Shops and showrooms
    • Warehouses and factories
    • Theatres and convention centres
    • Exhibition halls and cold storage units
    • Industrial sheds and mixed-use commercial buildings
    What is the GST rate on non-residential property rent under SAC 997212?
    Renting out non-residential property under 997212 HSN Code is treated as a taxable service and generally attracts 18% GST (9% CGST + 9% SGST for intra-state supplies or 18% IGST for inter-state transactions). A landlord is required to register for GST if their aggregate annual turnover exceeds ₹20 lakh (₹10 lakh in certain special category states).
    If the landlord remains below this threshold and is unregistered, GST is not charged. However, where an unregistered landlord rents to a GST-registered tenant, the tenant may be liable to pay GST under the Reverse Charge Mechanism (RCM), as per notified provisions. If both parties are unregistered and below the threshold, GST does not apply.
    HSN code 9972 vs SAC 9973 vs SAC 9966: Which code applies to your rental?
    Choosing the right code depends on what you rent and how it is used. HSN code 9972 covers real estate services, and 997212 is the specific code for non-residential property rental.
    SAC 9973 applies to the leasing of goods. This includes machinery, equipment and tools that do not require an operator. Ownership remains with the lessor, and the asset is used for a defined period.
    SAC 9966 applies to vehicle rental services with an operator. This includes cab services, staff transport and chartered buses, in which the operator is responsible for operating the vehicle.
    Let’s have a look at a quick comparison:
    SAC Heading
    Covers
    GST rate
    Example
    9972 (997212)
    Non-residential immovable property rental
    18%
    Office, warehouse, shop
    9973
    Machinery/equipment leasing (without operator)
    18% (5% for certain transport)
    Forklift, crane, copier
    9966
    Vehicle rental with operator
    5% (no ITC) or 12% (with ITC)
    Cab hire, charter bus
    Problems come from wrong classification. It affects GST returns, ITC mismatches and there could be possible rejection during reconciliation.
    Can you claim input tax credit on rent paid under HSN 997212?
    A registered tenant can claim ITC on the 18% GST paid on commercial rent under HSN 997212, provided the property is used for business purposes and all GST conditions are met.
    In certain cases, ITC is blocked. Credits on specific inputs are restricted under Section 17(5) of the CGST Act. A key restriction applies to the construction of immovable property on one’s own account.
    The process is stricter in reverse charge cases. The tenant must first pay GST in cash through the electronic cash ledger, and ITC can then be claimed in the same return period.
    Delays create cost risks. If the tenant misses the ITC claim deadline for the financial year, the credit is lost and the GST paid becomes a permanent expense.
    The invoice must reflect in GSTR-2B for ITC claims. Any mismatch between GSTR-2B and purchase records must be resolved before filing GSTR-3B.
    How to mention HSN code 997212 on GST invoices and returns?
    The landlord must include HSN code 997212 on invoices for rent of non-residential property. The invoice should clearly show service details and the GST breakup.
    Each invoice must include:
    • SAC code and service description
    • Taxable value (rent amount)
    • Applicable GST rate and tax amount
    • GSTIN of the landlord and the tenant
    • Place of supply
    SAC reporting depends on turnover. Businesses with a turnover of up to ₹5 crore can use the 4-digit code 9972. Businesses above ₹5 crore must use the full 6-digit code 997212.
    The e-invoicing system enforces this requirement and may reject invoices with incorrect or incomplete SAC details for higher turnover businesses.
    In return, landlords report rental income in GSTR-1 under the correct SAC. Tenants claim ITC in GSTR-3B based on eligible invoices.
    If reverse charge applies, the tenant must report the tax in Table 3.1(d) of GSTR-3B and then claim ITC in Table 4A. Using the correct SAC code is important, as errors can lead to ITC mismatches during GSTR-2B reconciliation and may trigger compliance checks.
    What are the risks of misclassification and non-compliance
    If GST rules are incorrectly applied to rental transactions, it is not treated as a minor error. It can directly impact finances and compliance. Here are some common risks explained:
    • ITC reversal: If a tenant claims ITC for an invoice with the wrong SAC code, it may be flagged during GSTR-2B matching and the credit may be denied.
    • Interest and penalties: If the landlord is not registered under GST and tax under the RCM is not paid correctly, the taxpayer may have to pay the tax along with interest and penalties.
    • Blocked credit: In some cases, ITC is not allowed. For example, if the rent relates to the construction of immovable property for own use, credit cannot be claimed under Section 17(5) of the CGST Act.
    • GSTR-1 issues: If the SAC code is incorrect or does not match the applicable turnover classification, invoices may result in errors or rejections, leading to delays in return filing.
    Final thoughts
    Correct SAC classification for rental services is essential for accurate GST calculation, valid input tax credit claims and smooth return filing. Using the wrong code can lead to penalties, ITC rejection and reporting errors, making verification before invoicing a critical compliance step.
    Staying consistent with the correct classification helps businesses avoid unnecessary tax disputes and ensures cleaner GST compliance. Tools like TallyPrime simplify this process by applying the appropriate SAC codes and supporting accurate GST calculation and return filing, helping businesses stay compliant with less effort.
    Verify GSTIN details online
    cta banner image
    Published on May 12, 2026
