    Mobile Accessories HSN Code “GST Rate, Classification & Invoicing Guide for Businesses”
    Tallysolutions
    Tally Solutions
    May 6, 2026
    30 second summary | Mobile accessories are classified by function and material, not a single HSN code. Chargers (8504), earphones (8518), cables (8544) and batteries (8507) fall under Chapter 85, while covers may fall under 3926 or 4202. Most attract 18% GST in 2026, making accurate classification essential for invoicing, GST reporting and ITC claims.
    Mobile accessories do not have a single HSN code; they are classified based on function, material and use, which directly determines the applicable GST rate and invoicing treatment. Most items fall under Chapter 85 (electrical equipment), while covers, cases and protectors fall under plastic, leather or glass categories, with the mobile cover HSN code varying based on the material used.
    Chargers are classified as electrical equipment, and earphones as audio devices, under material-based headings, making correct classification essential for accurate billing and GST compliance.
    Mobile accessories HSN code with GST rate
    Mobile accessories do not fall under a single HSN code, so classification depends on the specific product category, which directly determines the applicable GST rate and invoicing treatment.
    Here’s a structured table for clarity:
    Category
    HSN Code / Number
    Description
    GST Rate
    Mobile phones / smartphones
    8517
    Telephone sets including smartphones and feature phones
    18%
    Mobile chargers / adapters
    8504
    Power adapters and battery chargers
    18%
    Mobile batteries / power banks
    8507
    Lithium-ion batteries and power banks or suppliers
    18%
    Earphones / headphones / earbuds / bluetooth audio devices
    8518
    Wireless audio devices such as Bluetooth earphones, earbuds, headphones and speakers
    18%
    Bluetooth communication devices
    8517
    Wireless communication devices such as Bluetooth transmitters, hands-free calling devices
    18%
    USB / data cables
    8544
    Insulated wires and cables
    18%
    Mobile covers (plastic)
    3926
    Plastic cases and covers
    18%
    Mobile covers (leather)
    4202
    Leather cases and pouches
    18%
    Screen protectors (plastic)
    3919
    Plastic film-based protectors
    18%
    Screen protectors (tempered glass)
    7007
    Toughened safety glass
    18%
    Memory cards
    8523
    Storage devices for mobile phones
    18%
    Mobile spare parts (PCB, display, etc.)
    Varies
    Certain parts may fall under 8517 70, while others may be separately classified
    Mostly 18%
    Why mobile accessories have different HSN codes
    Mobile accessories are classified separately because GST follows a function-based classification system, in which each product is grouped by its function and material composition, which directly determines its tax treatment.
    The GST framework does not group products by usage (such as “mobile-related items”). Instead, it follows a structured system where each product is placed in a chapter that best describes its nature.
    For example:
    • Electrical components: Chapter 85
    • Plastic items: Chapter 39
    • Leather goods: Chapter 42
    • Glass products: Chapter 70
    This approach ensures that each product is taxed correctly based on its characteristics, not just its use with mobile phones.
    What common errors should you avoid in mobile accessories classification?
    Mobile accessories must be classified based on their specific function and material, and errors in classification can lead to incorrect GST application and compliance issues.
    You must avoid the following common mistakes:
    • Applying the HSN for mobile phones (8517) to all accessories.
    • Ignoring material-based classification, such as covers falling under plastic or leather, depending on composition.
    • Grouping bundled items incorrectly; each accessory should be classified separately unless treated as a composite supply.
    • Using generic “electronics” codes instead of selecting the most specific HSN available.
    Conclusion
    Correct classification of mobile accessories is not just a technical requirement; it directly affects GST rates, invoicing accuracy and ITC eligibility. Classify products based on their exact function and material, using the most specific HSN code available to avoid errors and compliance risks.
    Consistent classification practices help businesses maintain accurate reporting and prevent costly mistakes during audits or filings. Using a reliable system like TallyPrime makes this easier by ensuring HSN-based invoicing, GST calculation and record-keeping are aligned with regulatory requirements, helping businesses stay accurate and compliant.
    FAQs
    No. All mobile phones are taxed at 18% GST. Most accessories, though under different HSN codes, also attract the 18% tax.
    Imports attract BCD (reduced to 15% under Budget 2024) and IGST (usually 18%) on the total value. SWS may also apply.
    18% GST is added to the selling price; split into CGST + SGST (intra-state) or IGST (inter-state).
    Yes, if used strictly for business. Personal or mixed use may restrict ITC.
    GST is based on the principal supply or the highest rate. Most bundles are taxed at 18%.
    Published on May 6, 2026
