    HSN Code 8538: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    May 11, 2026
    30 second summary | 8538 HSN Code applies to parts mainly used with switchgear, circuit breakers, panels and control equipment under headings 8535, 8536 and 8537. Most goods under this code are subject to 18% GST. Businesses can usually claim ITC if eligible and must report supplies correctly in GSTR-1, GSTR-3B, e-way bill and e-invoicing systems where applicable.
    8538 HSN Code covers parts designed for use solely or principally with electrical apparatus of headings 8535, 8536 or 8537, making it important for businesses dealing in switchgear, fuses, circuit breakers, control boards and distribution panels, because the correct classification directly affects GST rates, invoicing, customs documentation and return filing.
    In practical terms, Harmonised System of Nomenclature (HSN) Code 8538 covers components and spare parts made specifically for electrical control and protection equipment, rather than complete electrical apparatus.
    It falls under Chapter 85, which covers electrical machinery, equipment and their parts, and is especially relevant for manufacturers, importers, panel builders, electrical contractors and industrial suppliers handling application-specific electrical parts.
    What are the GST rate and product classification under HSN 8538?
    Goods classified under 8538 HSN Code generally attract 18% GST; 9% CGST, and 9% SGST on intra-state supplies, and 18% IGST on inter-state supplies and imports. The heading covers electrical parts and accessories used principally with apparatus under headings 8535, 8536 or 8537, and no compensation cess applies.
    Description
    HSN Code
    Parts suitable for use solely or principally with apparatus of headings 8535, 8536 or 8537
    8538
    Boards, panels, consoles, desks, cabinets and other bases for goods of heading 8537, not equipped with apparatus
    853810
    Boards, panels, consoles, desks, cabinets and other bases for goods of heading 8537, not equipped with apparatus (for industrial use)
    85381010
    Boards, panels, consoles, desks, cabinets and other bases for goods of heading 8537, not equipped with apparatus (other than industrial use)
    85381090
    Other parts suitable for use solely or principally with apparatus of headings 8535, 8536 or 8537
    85389000
    What is input tax credit (ITC) on HSN 8538 purchases
    A GST-registered business can usually claim Input Tax Credit (ITC) on purchases classified under HSN 8538, provided the conditions under Section 16 of the CGST Act are met.
    • The goods must be used in the course or furtherance of business.
    • A valid tax invoice must be available showing the supplier’s GSTIN, HSN code and tax amount.
    • The supply must be reflected in the supplier’s GSTR-1 and auto-populated in GSTR-2B.
    • ITC is blocked under Section 17(5) if the goods are used for the construction of immovable property for own use, except where they qualify as plant and machinery.
    Electrical switchgear parts procured for installation in a factory’s power distribution infrastructure generally qualify as plant and machinery inputs, so ITC is usually available. Contractors and Engineering, Procurement and Construction (EPC) firms commonly claim ITC on HSN 8538 goods.
    Business filing guide: Using HSN 8538 in GST compliance
    If your business sells goods under HSN 8538, keep these filing requirements in mind.
    GSTR-1 filing
    When you sell goods classified under HSN 8538, report those outward supplies in GSTR-1 under Table 12 (HSN Summary). This section captures the HSN code, unit quantity code (UQC), total quantity, taxable value and applicable IGST, CGST and SGST amounts.
    GSTR-3B filing
    In your monthly or quarterly GSTR-3B, declare your total tax liability and eligible ITC. If you purchase goods under HSN 8538 for business use, the credit can generally be claimed under the Inputs or Capital Goods section, depending on the nature of the purchase.
    E-way bill requirements
    For inter-state movement and, where applicable, intra-state movement, an E-way bill must be generated before dispatch if the consignment value exceeds ₹50,000.
    E-invoicing applicability
    If your business turnover exceeds the applicable GST e-invoicing threshold, eligible B2B supplies should be reported through the Invoice Registration Portal (IRP). Once uploaded, the portal generates an Invoice Reference Number (IRN) and a QR code.
    What are the common classification disputes and how to avoid them
    These are some of the main classification issues businesses should watch for under HSN 8538.
    • Spare part vs accessory
    Both can fall under HSN 8538 if they are used solely or principally with apparatus under headings 8535 to 8537. To reduce classification disputes, keep supplier declarations, product catalogues and technical specification sheets on record.
    • Job work
    If goods classified under HSN 8538 are sent for job work, such as assembly into a panel, the movement should generally follow the challan-based procedure under Rule 45 of the CGST Rules. In such cases, ITC usually remains with the principal manufacturer.
    • Mixed supplies
    When a complete panel is sold along with spare parts, the GST treatment depends on the transaction structure. If both are naturally supplied together as a composite supply, the tax rate of the principal product usually applies. If unrelated items are bundled and sold at a single price as a mixed supply, the highest GST rate in the bundle may apply.
    To simplify compliance, invoices should generally show the panel under HSN 8537 and spare parts under HSN 8538 separately, unless they are intentionally sold as a single package.
    Conclusion
    With 8538 HSN Code, the most important thing is to verify the product description, intended use and tax mapping before every sale, because small classification errors can quickly lead to ITC mismatches, return filing issues and avoidable GST notices.
    A practical monthly review of product masters, vendor invoices and billing entries helps catch errors early and keeps compliance more consistent as volumes grow. Using organised software like TallyPrime can make HSN-wise reporting, invoice checks and GST tracking more accurate while saving valuable time.
    Verify GSTIN details online
    cta banner image
    Published on May 11, 2026
