    HSN Code 8479: Product Classification, GST Rate & Business Filing Guide
    Tallysolutions
    Tally Solutions
    May 11, 2026
    30 second summary | 8479 HSN Code covers specialised machinery with individual functions not classified elsewhere in Chapter 84. Most goods under this code are subject to 18% GST. Businesses must use the correct HSN code on invoices, GSTR-1, GSTR-3B and e-way bills. Proper classification helps avoid notices, protects ITC claims and improves compliance.
    8479 HSN Code applies to specialised machines and mechanical appliances with individual functions that are not specifically covered elsewhere in Chapter 84, making it important for businesses that manufacture, import, trade or install custom industrial equipment, as the correct classification directly affects Goods and Services Tax (GST) rates, invoicing, customs documentation and return filing.
    In practice, Harmonised System of Nomenclature (HSN) 8479 is commonly used for purpose-built industrial machinery that does not fit neatly under standard equipment headings, such as certain custom processing, handling, mixing, dosing, screening or specialised mechanical units.
    This makes the code especially relevant for manufacturers, importers, Engineering, Procurement and Construction (EPC) contractors, machinery traders and industrial suppliers dealing with non-standard or application-specific industrial equipment.
    What is the GST rate and product classification under HSN 8479
    Most products classified under HSN 8479 currently attract 18% GST, which means 9% CGST and 9% SGST on intra-state supplies, and 18% IGST on inter-state supplies and imports.
    Some items under this heading were earlier taxed at 12%, but many moved to the revised slab structure after the 56th GST Council Meeting. A specific government notification must support any product that still qualifies for 12% GST, so correct product classification remains important before applying the rate.
    Description
    HSN Code
    Machines and mechanical appliances with individual functions, not specified elsewhere in Chapter 84
    8479
    Machinery for public works, construction or similar applications
    84791000
    Machinery for extraction or preparation of animal or fixed vegetable fats/oils
    847920
    Oil-seed crushing or grinding machinery for fat/oil extraction
    84792010
    Other machinery for extraction or preparation of animal or vegetable fats/oils
    84792090
    Presses for manufacturing particle board, fibre board, wood board or machinery for treating wood/ligneous materials
    84793000
    Rope or cable-making machines
    84794000
    Industrial robots, not elsewhere specified
    84795000
    Evaporative air coolers
    84796000
    Machines of a kind used in airports
    847971
    84797100
    Other machines under this category
    847979
    84797900
    Machines for treating metal, including electric wire coil-winders
    84798100
    Mixing, kneading, crushing, grinding, screening, sifting, homogenising, emulsifying or stirring machines
    84798200
    Other machines and mechanical appliances
    847989
    Soap cutting or moulding machinery
    84798910
    Air humidifiers or dehumidifiers (excluding headings 8415 or 8424)
    84798920
    Mechanical shifting machines
    84798930
    Ultrasonic transducers
    84798940
    Car washing machines and related appliances
    84798950
    Coke oven plants
    84798960
    Machinery for manufacture of chemical or pharmaceutical goods
    84798970
    Industrial vacuum cleaners
    84798991
    Briquetting plant and machinery for making briquettes from agricultural residue
    84798992
    Other machinery not specifically covered elsewhere
    84798999
    Parts of machines and mechanical appliances of heading 8479
    847990
    Parts of public works, building or similar machines
    84799010
    Parts of machines for extraction of animal, fruit or vegetable fats/oils
    84799020
    Parts of machines or appliances for treating wood
    84799030
    Parts of machinery used for manufacture of chemicals or pharmaceuticals
    84799040
    Other parts
    84799090
    What is Input Tax Credit (ITC) on HSN 8479 machinery?
    Machines classified under 8479 HSN Code are generally treated as capital goods used in manufacturing or in producing taxable supplies, so the GST paid on purchase can usually be claimed as ITC, subject to Sections 16 and 17 of the CGST Act.
    To claim ITC:
    • The buyer must be a GST-registered entity.
    • The machinery must be used for taxable business purposes, not for personal use or for producing exempt goods or services.
    • A valid GST-compliant tax invoice from a registered supplier must be available.
    • If the asset is used for both taxable and exempt supplies, ITC on the capital goods must be apportioned proportionately.
    Business filing guide: How to use HSN 8479 in GST returns
    If your business handles goods under HSN 8479, keep these filing requirements in mind.
    GSTR-1 filing
    If you are selling machinery under HSN 8479, report the sales in GSTR-1 under the HSN summary section (Table 12). Depending on whether you file monthly or quarterly, each supply should be reported with the correct HSN code. The GSTN system validates HSN classifications so that incorrect mapping can lead to mismatches during GSTR-2B reconciliation.
    GSTR-3B and ITC claims
    If you are claiming ITC on HSN 8479 machinery, make sure the credit is correctly reported in GSTR-3B (Table 4) and matches the supplier’s GSTR-1 data as reflected in GSTR-2B. Since machinery is generally treated as a capital goods, it should also be tracked separately in the capital goods ITC register maintained under Rule 43 of the CGST Rules.
    E-way bill requirements
    Industrial machinery often involves high-value or bulky consignments, so an E-way bill is generally required where the consignment value exceeds ₹50,000. For inter-state movement, the applicable e-way bill rules should be checked based on the nature of the movement and the transaction. Businesses transporting industrial machinery, heavy fabricated units or specialised equipment should generate the e-way bill on the GSTN portal before dispatch.
    Conclusion
    Getting 8479 HSN Code right directly affects your GST rate, ITC claims, invoicing accuracy and return filing, so the most practical takeaway is simple: review the classification carefully whenever you introduce a new machine, change suppliers or expand into new markets.
    A small check at the classification stage can prevent tax mismatches, filing delays and margin leakage later. As your operations grow, using organised accounting software like TallyPrime can make it easier to track stock and invoices, support HSN-wise reporting and ensure greater compliance consistency.
    Verify GSTIN details online
    cta banner image
    Published on May 11, 2026
