    Fastener HSN Code “GST Rate, Classification & Invoicing Guide for Businesses”
    Tallysolutions
    Tally Solutions
    May 21, 2026
    30 second summary | Fasteners such as nuts, bolts, screws, nails and anchors are classified under Chapter 73. Threaded fasteners HSN 7318 (18%), nails 7317 (18%) and anchors 7316 (18%). Apparel fasteners: snap-fasteners 9606 (18%) and zippers 9607 (12%). Classification depends on type/use; correct HSN is essential for compliance and invoicing.
    Fasteners such as bolts, nuts, screws, washers, rivets and similar components are classified under HSN 7318 in GST and typically attract 18% GST as essential joining and assembly components used across construction, machinery, furniture and industrial manufacturing.
    This classification under Chapter 73 (articles of iron and steel) ensures uniform tax treatment for metal fastening products and makes correct HSN reporting critical for accurate invoicing and GST compliance in business transactions.
    What Is the HSN Code and GST Rate for Fasteners?
    Fasteners under GST are generally classified under Chapter 73 of the HSN system and attract a 18% GST rate. These include essential joining components such as bolts, nuts, screws, washers, rivets and similar iron and steel articles used in construction, machinery, furniture and industrial assembly.
    Correct classification under the appropriate HSN sub-heading is important for accurate GST invoicing and compliance.
    Category
    HSN Code / Number
    Description
    Screws, bolts, nuts (general category)
    7318
    Covers screws, bolts, nuts, washers, rivets, cotter pins and similar fastening articles of iron or steel.
    Coach screws
    73181100
    Heavy-duty screws used in wood and structural applications.
    Wood screws
    73181200
    Screws designed for fastening wood materials.
    Screw hooks & screw rings
    73181300
    Hooks and rings with screw threads used in fittings and fixtures.
    Self-tapping screws
    73181400
    Screws that create their own thread during installation.
    Other screws and bolts
    73181500
    Includes machine bolts, hex bolts and general-purpose threaded fasteners.
    Nuts
    73181600
    Includes hex nuts, lock nuts, flange nuts and similar fastening components.
    Other threaded fasteners
    73181900
    Covers threaded fasteners not specifically classified elsewhere.
    Spring washers
    73182100
    Washers used to prevent loosening due to vibration.
    Other washers
    73182200
    Flat washers and similar components used with bolts and nuts.
    Rivets
    73182300
    Permanent fasteners used in metal joining applications.
    Cotters and cotter pins
    73182400
    Pins used to secure fasteners in mechanical assemblies.
    Circlips
    73182910
    Retaining rings used to hold components in place.
    Other non-threaded fasteners
    73182990
    Includes miscellaneous fastening items not elsewhere classified.
    Nails, tacks, drawing pins
    7317
    Includes nails and similar fastening items used in wood and construction.
    Anchors & Grapnels
    7316
    Marine/nautical anchors, grapnels and their parts.
    What Are Fasteners Under Chapter 96 (Buttons, Snap Fasteners & Zippers) and Their HSN Codes?
    Fasteners and Their HSN Codes
    Fasteners under Chapter 96 are consumer-focused fastening components used mainly in garments, footwear, bags and accessories, unlike industrial fasteners covered under Chapter 73.
    These items typically include snap fasteners, press studs and zippers. While they were earlier associated with the 12% and 28% GST slabs, post the recent rate rationalisation, many sub-categories now fall under 0%, 5% or 18% GST, depending on classification and usage. Businesses should always verify the latest applicable GST rate before issuing an invoice.
    Here is the breakdown of this chapter:
    Category
    HSN Code / Number
    Description
    Press-fasteners, snap-fasteners, press-studs
    960610
    Covers press-fasteners, snap-fasteners, press-studs and their parts used in garments and accessories.
    Press-fasteners (metal)
    96061010
    Metal press-fasteners and similar fastening components.
    Press-fasteners (other)
    96061020
    Other types of press-fasteners and parts.
    Slide fasteners (zippers)
    96071100
    Slide fasteners (zippers) used in garments, bags and accessories.
    Parts of slide fasteners
    96072000
    Components and parts of zippers.
    What common mistakes should businesses avoid when classifying fasteners under HSN?
    Even though fasteners are widely used across industries, incorrect HSN classification can lead to GST errors, mismatched reporting and compliance issues. Businesses should avoid these common mistakes while assigning HSN codes:
    • Confusing nails with threaded fasteners: Nails fall under HSN 7317, while screws, bolts and similar threaded fasteners fall under HSN 7318. Mixing these categories often results in incorrect GST reporting.
    • Applying one HSN code to all hardware items: Not all hardware items are fasteners. Tools, fittings and fabrication accessories may fall under different HSN chapters, so using a single blanket code can lead to misclassification.
    • Wrong classification of anchors: Marine anchors are classified under HSN 7316. However, construction or industrial anchor fasteners may fall under HSN 7318 or even HSN 7326, depending on the material, structure, threading and intended use.
    • Missing product specifications during classification: Key details such as thread type, design (self-tapping vs standard) and application area directly affect HSN selection. Ignoring these specifications often leads to incorrect classification and invoicing errors.
    How to find the right fastener HSN code
    Selecting the correct HSN code for fasteners is essential for accurate GST reporting, invoicing and compliance. Since fasteners include a wide range of products, classification should always be based on specific product characteristics rather than a general category.
    To classify fasteners correctly, consider the following:
    • Type of fastener: screw, bolt, nut, nail, anchor, etc.
    • Threading: whether the product is threaded or non-threaded
    • Material: iron, steel, stainless steel or other base metals
    • Application: usage in construction, machinery, furniture or industrial assembly
    Evaluating these factors carefully helps ensure correct HSN selection and reduces the risk of GST classification errors.
    Conclusion
    Fasteners may appear simple, but accurate GST classification depends on correctly identifying the right HSN code, with most items commonly falling under HSN 7318 at 18% GST. The real complexity lies in distinguishing between subcategories such as screws, nails, and anchors, where small differences in design and usage directly affect classification.
    For businesses dealing with multiple hardware SKUs, maintaining precise HSN mapping and consistent invoicing is essential to ensure compliance and avoid reporting errors. Using a solution like TallyPrime helps streamline this process by improving classification accuracy, automating GST calculations and simplifying inventory and billing management for smoother, error-free operations.
    Verify GSTIN details online
    cta banner image
    Published on May 21, 2026
