    Copper Pipe HSN Code “GST Rate, Classification & Invoicing Guide for Businesses”
    Tallysolutions
    Tally Solutions
    May 11, 2026
    30 second summary | Copper pipes fall under Chapter 74 (Copper and articles thereof) in GST. The main HSN code for pipes and tubes is 7411, attracting 18% GST. Related items, such as fittings (7412), scrap (7404), cables and lugs, also generally attract 18% GST. Correct HSN classification ensures accurate invoicing and proper ITC claims.
    Copper pipes are classified under Harmonised System of Nomenclature (HSN) code 7411 in GST, which falls under Chapter 74 (Copper and Articles Thereof) in Section XV (Base Metals). This classification directly determines the applicable GST rate and invoicing requirements for businesses.
    This HSN code covers copper tubes and pipes in various forms, including coils, straight lengths and industrial tubing, ensuring consistent tax treatment across product variations. Other copper-based items, such as fittings, scrap, cables and connectors, are classified under different HSN codes within the same chapter based on their form and usage, making correct classification essential for accurate billing and Input Tax Credit (ITC) compliance.
    Copper pipe HSN code with GST rate
    Understanding the copper pipe HSN code and HSN codes for related items is critical for accurate Goods and Services Tax (GST) compliance and invoicing.
    Category
    HSN Code / Number
    Description
    GST Rate
    Copper pipes & tubes
    7411
    Copper tubes and pipes used in plumbing, HVAC, refrigeration
    18%
    Copper pipes (refined copper)
    7411 10 00
    Pipes made of refined copper
    18%
    Copper pipes (brass alloys)
    7411 21 00
    Pipes of copper-zinc alloys (brass)
    18%
    Copper pipes (nickel alloys)
    7411 22 00
    Copper-nickel or nickel-silver alloys
    18%
    Other copper pipes
    7411 29 00
    Other copper alloy pipes
    18%
    Copper pipe fittings
    7412
    Couplings, elbows, sleeves, connectors
    18%
    Copper fittings (refined)
    7412 10 00
    Pipe fittings of refined copper
    18%
    Copper fittings (alloys)
    7412 20 00
    Pipe fittings of copper alloys
    18%
    Copper scrap
    7404
    Copper waste and scrap
    18%
    Refined copper (raw form)
    7403
    Copper cathodes, rods and unwrought forms
    18%
    Copper wires
    7408
    Uninsulated copper wire
    18%
    *Insulated copper cables
    8544
    Electrical wires and cables
    18%
    *Copper lugs & connectors
    8536
    Electrical connectors, terminals, lugs
    18%
    Notes:
    • Copper lugs are typically classified under HSN 8536 (electrical connectors and terminals) and attract 18% GST, as they are considered electrical components rather than basic copper articles.
    • Insulated copper cables are classified under HSN 8544 (electrical wires and cables) and attract 18% GST, as they are treated as electrical equipment rather than basic copper articles under Chapter 74.
    Common Mistakes in Copper Pipe HSN Classification
    Businesses often make classification errors due to similar-looking copper products:
    • Confusing pipes with fittings: Pipes fall under 7411, while fittings like elbows and connectors fall under 7412. This distinction is important for accurate invoicing and GST compliance.
    • Wrong classification of electrical copper items: For instance, copper cables and lugs may fall under Chapter 85, not Chapter 74.
    • Treating scrap as finished goods: Copper scrap is not a finished product; it is leftover, waste or recyclable material generated during manufacturing, fabrication or after product use. Under GST classification, this distinction matters. Copper scrap HSN code is 7404, and it is classified separately from copper pipes or rods.
    • Using generic copper HSN codes: HSN classification under GST should be as specific as possible. Using a broad or generic code, such as 7403 (refined copper in raw/unwrought form), for products that clearly fall under a more precise heading, such as 7411 (copper pipes and tubes), can lead to compliance issues.
    What are the invoicing requirements for copper products under GST?
    Businesses dealing in copper products must ensure:
    • Using the correct HSN code (e.g., 7411 for pipes, 7412 for fittings)
    • The correct GST rate application (18% in most cases)
    • Separate line items for pipes, fittings, scrap and cables
    • For measurement, copper products should be recorded using the relevant Unit Quantity Code (UQC), such as KGS, MTR, NOS, PCS or SET, depending on the item sold.
    • Clear product descriptions including type (e.g., “Refined Copper Tube for AC” or “Brass Pipe”) and usage (such as plumbing, industrial or electrical)
    If pipes and fittings are sold together, they should ideally be listed separately with their respective HSN codes (7411 and 7412). If sold as a bundled supply, GST may be determined based on the principal item or the highest applicable rate, depending on whether it qualifies as a composite or mixed supply.
    Conclusion
    Copper pipes and related products fall under Chapter 74, with most items attracting a standard GST rate of 18%. While the base material remains the same, classification changes based on whether the product is a pipe, fitting, scrap or electrical component, making accurate HSN selection essential for compliance.
    Correct classification and precise invoicing are not just compliance requirements; they directly impact tax accuracy, ITC claims and overall financial control. Businesses that maintain clarity in HSN usage and billing practices are better positioned to avoid errors and ensure smoother GST reporting.
    Using TallyPrime, businesses can simplify this process through accurate HSN mapping, automated GST calculations and structured invoicing, helping ensure consistent compliance and more efficient day-to-day operations.
    Verify GSTIN details online
    cta banner image
    FAQs
    Yes. Copper fittings, such as couplings, elbows or sleeves, made of copper alloys must be listed with the correct HSN code (e.g., 74122000, where applicable) on invoices. This applies to both online and offline sales under Chapter 74.
    Not automatically. GST depends on the nature of the supply and applicable notifications. Supplying to government projects does not by itself change the HSN code or GST rate.
    Yes, in certain cases. Under GST provisions, RCM may apply when copper scrap is purchased from an unregistered supplier. Applicability should be checked before each transaction.
    Imports are subject to IGST (generally 18%) plus customs duty, with ITC available on IGST paid. Exports are zero-rated, meaning no GST is charged and can be made under the LUT or with a refund of the tax paid.
    No, ideally, they should be billed separately with 7411 for pipes and 7412 for fittings. If bundled, GST will depend on whether it qualifies as a composite or mixed supply.
    Published on May 11, 2026
