A consent letter is required for Goods and Services Tax (GST) registration when you use a shared or rented business address, and missing it can delay your application.
Running a business involves multiple documents, and the consent letter for GST is one that often creates confusion. It may seem minor, but it is a key part of the registration process. Without it, even a well-prepared GST application can face delays or rejection.
What is a consent letter for GST?
A consent letter for GST is a document that confirms you have permission to use a property as your principal place of business when you do not own it.
For example, you may run a home-based business or operate from a rented shop or office without a formal lease agreement. In such cases, GST authorities require proof that the property owner has allowed you to use the premises for business purposes.
A consent letter acts as a no-objection certificate (NOC) from the property owner, stating that they permit you to use the address for GST registration.
This document is required when the “nature of possession of premises” is selected as “consent”, indicating there is no formal rent or lease agreement in place. Without it, the application may be delayed or rejected due to insufficient address proof.
Why is a consent letter important?
A consent letter is required to confirm that your business operates from a valid, approved location.
It helps ensure:
- Your business operates from a verifiable address: Authorities can confirm the declared place of business under GST rules.
- The property owner has given permission: This provides clarity and reduces the risk of legal disputes.
- There is transparency in operations: A registered address allows for communication, verification and compliance checks.
In addition to meeting regulatory requirements, the consent letter protects both parties. The business can use the address for registration, and the property owner has formal acknowledgement of its use, which helps avoid future disputes.
Who can sign the consent letter?
The consent letter must be signed by a person who has legal authority over the property. An incorrect signatory can delay the registration process.
- Property owner: In most cases, the owner of the property signs the letter.
- Landlord: If the premises are rented, the landlord provides the consent.
- Authorised representative: If a company or organisation owns the property, an authorised signatory can sign on its behalf.
For jointly owned property, consent from one co-owner is generally accepted, though authorities may request additional confirmation if needed. If the property is owned by an entity, the authorised signatory may need to provide proof of authorisation.
Tip: Keep proof that the signatory owns or is authorised to represent the property, as it may be required during verification.
How to write a consent letter
There is no prescribed government format for a consent letter, but it should be clear and complete. Include the names of the property owner and business operator, the full address, a clear permission statement and contact details if required.
Sample Consent Letter
To Whomsoever It May Concern,
I, [Owner’s Name], owner of the property located at [Full Address], grant permission to [Business Owner’s Name] to operate their business from the above-mentioned premises.
I have no objection to the use of this address as the principal place of business for Goods and Services Tax (GST) registration, including official correspondence.
I am enclosing identity and ownership proof for verification.
This consent is provided as a no-objection certificate (NOC) for GST registration.
Signature:
Name of owner:
Date:
Place:
Key points for a good consent letter
Keep these points in mind while preparing the consent letter:
- Ensure names match the records in the Permanent Account Number (PAN)
- Provide the full address clearly without abbreviations
- Ensure the signature is clear and legible
- Use simple and professional language without unnecessary legal terms
Even small errors, such as spelling mistakes or mismatched addresses, can lead to delays, so review the document carefully before submission.
Supporting documents
A consent letter alone may not be sufficient. GST authorities usually require supporting documents to verify the property owner’s details.
Common documents include:
- Electricity bill in the owner’s name
- Property tax receipt
- Municipal khata copy
- Ownership documents
If the property is rented, a lease or rental agreement is also required.
These documents help confirm that the person providing consent owns the property or is authorised to allow its use.
How to upload the consent letter
Follow these steps to upload the consent letter on the GST portal:
- Log in: Access the GST portal using your credentials
- Go to registration: Navigate to Services → Registration → New Registration
- Fill application details: Enter your business and owner information
- Select possession type: Choose “consent” under “nature of possession of premises”
- Upload documents: Upload the consent letter along with supporting documents
File requirements:
- Format: PDF or JPEG
- Maximum size: 1 MB
Tip: Ensure the uploaded file is clear and readable. You can compress the file, but do not compromise on clarity.
What happens if you don’t submit it?
If the consent letter is not submitted, the application may be delayed or flagged for clarification.
The GST officer may issue a notice in Form GST REG-03 requesting additional documents or information. You must respond using Form GST REG-04 within the specified timeline.
Failure to respond or to provide the required documents can result in rejection of the GST registration application.
Proof of principal place of business
GST requires different address proofs based on the nature of your premises.
- Owned property: Ownership documents, property tax receipts and electricity bills.
- Rented property: Rental or lease agreement along with the owner’s proof.
- Other arrangements: Consent letter along with proof of property ownership.
Tips for Avoiding Common Mistakes
Many GST applications are delayed due to avoidable errors. Keep these points in mind to ensure a smooth submission:
- Verify that all names match the PAN records
- Ensure addresses are complete and consistent across documents
- Include all required supporting documents
- Check that the uploaded files meet the size and format limits
- Review the letter for spelling errors or missing details
Modifying your address later
If your business address changes, you can update it in your GST registration by following these steps:
- File application: Submit Form GST REG-14 within 15 days of the change.
- Verification: The GST officer reviews the application; it may be auto-approved or require verification.
- Respond if required: Reply to any notice in Form GST REG-03 within the specified timeline.
- Update completed: Once approved, your registration reflects the new address.
Note: If you move to a different state, you must cancel your existing registration and apply for a new one in that state.
Why this matters
A consent letter may seem like a minor document, but it plays a key role in the GST registration process.
It helps ensure:
- Your business operates from a verifiable location: Supporting compliance with GST requirements.
- The property owner has provided consent, reducing the risk of disputes.
- The registration process is clear, allowing authorities to verify details without delays.
Additional compliance points
Keep these compliance requirements in mind during GST registration:
- Verification method: Registration must be verified using a digital signature certificate (DSC) for companies and limited liability partnerships (LLPs), or an electronic verification code (EVC) for others.
- Aadhaar authentication: Completing Aadhaar authentication can speed up approval and reduce the likelihood of physical verification.
- Physical verification: If documents are insufficient or unclear, authorities may conduct verification of the business premises.
Final thoughts
A correctly prepared consent letter helps avoid delays in GST registration and supports a smoother approval process. Ensure details match your PAN records, attach valid ownership proof and upload clear documents within the required limits.
Respond promptly to any GST notices to prevent rejection and keep the process on track.
With TallyPrime, we help you manage registrations, maintain records and stay aligned with compliance requirements, so you can focus on running your business.
