    HSN Code for Battery, Inverter, UPS & Solar Panel: GST Rates for Power Equipment
    Tallysolutions
    Tally Solutions
    Updated on May 5, 2026
    30 second summary | Battery HSN codes in India mainly fall under 8506 (primary batteries) and 8507 (rechargeable batteries). As of late 2025, GST rates for batteries (including lead-acid and lithium-ion) were unified to 18%, while solar equipment or devices are generally taxed at 12% or 5%, depending on their type. Inverters and UPS systems are taxed at 18% (HSN 8504). The correct classification ensures compliance, accurate GST filing, and eligibility for input tax credit.
    Previously, non-lithium batteries were at 28%, but as of September 2025, all batteries under heading 8507, including lead-acid inverter batteries and lithium-ion, and HSN 8506 are taxed at 18%. Inverters & UPS, which are classified under "Static Converters" (HSN 8504), also carry a standard 18% GST rate, while solar equipment or devices attract a concessional rate of 5% or 12%, based on their type.
    Battery HSN code and GST rate
    The table below outlines the HSN classification for batteries under heading 8507, including key sub-categories based on battery type, such as lead-acid, lithium-ion and nickel-based accumulators, along with their applicable GST rates.
    Category
    HSN Code / Number
    Description
    GST Rate
    Batteries
    8507
    Electric accumulators, including separators, for storing electrical energy, such as lead-acid, lithium-ion and nickel-cadmium batteries. These batteries (commonly used for vehicles and inverters)
    18%
    Lead-acid batteries
    8507 10 00
    Used for starting piston engines (automotive)
    18%
    Other lead-acid accumulators
    8507 20 00
    Electric accumulators, including separators, whether or not rectangular (including square), other than lead-acid accumulators for starting piston engines. Usually used in Solar power systems, UPS, telecommunications and industrial electric vehicles.
    18%
    Nickel-cadmium accumulators
    8507 30 00
    Nickel-cadmium electric accumulators (batteries), including their separators, regardless of shape (rectangular or square)
    18%
    Nickel-metal hydride (NiMH) accumulators
    8507 50 00
    Nickel-metal hydride (NiMH) accumulators (rechargeable batteries), excluding spent batteries
    18%
    Lithium-ion batteries (accumulators)
    8507 60 00
    Lithium-ion accumulators (batteries), including those for electric vehicles, tools, and electronics. Commonly used in electric vehicles (EVs), laptops, mobile phones and power storage systems
    18%
    Other Electric Accumulators
    8507 80 00
    Other electric accumulators (excluding lead-acid, nickel-cadmium, nickel-iron, nickel-metal hydride and lithium-ion batteries), including separators, whether or not rectangular. Common applications: Rechargeable batteries for various electronic devices, E-rickshaw batteries.
    18%
    Inverter & UPS HSN code with GST rate
    Since inverters and UPS systems are designed for power conversion rather than energy storage, they are classified under HSN 8504 as static converters, separate from batteries (HSN 8507). The table below outlines the classification and sub-classification within HSN 8504, covering inverters, UPS systems and related power conversion equipment.
    Category
    HSN Code / Number
    Description
    GST Rate
    Electrical transformers, static converters and inductors
    8504
    Covers electrical transformers, static converters (e.g., rectifiers, inverters)and inductors. It applies to various power management devices, including voltage stabilisers, battery chargers and ballast for lamps, with many components categorised by their power-handling
    18%
    Static converters (including inverters, rectifiers and battery chargers)
    8504 40
    Common items include electric inverters, voltage stabilisers and AC/DC power adapters
    18%
    Electric inverters
    8504 40 10
    It applies to solar inverters, home inverters and UPS systems
    18%
    Other Static Converters
    8504 40 90
    Includes devices like rectifiers, inverters, and certain UPS units.
    18%
    Battery chargers
    8504 40 30
    Battery Chargers (static converters/rectifiers), which are commonly used for mobile, laptop and other battery charging devices
    18%
    Solar panel HSN code and GST rate
    Solar equipment is classified across multiple HSN codes based on the specific component, system, or end-use application, ranging from photovoltaic cells and modules to solar-powered appliances and complete power systems. GST rates vary accordingly, with concessional rates applied to most solar components to support renewable energy adoption.
    Product
    HSN Code / Number
    Description
    GST Rate
    Diodes, transistors, photosensitive semiconductor devices
    8541
    Diodes, transistors, photosensitive semiconductor devices (including photovoltaic cells/solar panels), light-emitting diodes (LED) and mounted piezoelectric crystals. It is widely used for electronic components and solar energy equipment
    5% (for solar items)
    Solar panels (photovoltaic cells/modules)
    8541 40 11
    Covers solar cells, whether or not assembled in modules or made up into panels. Common applications include solar panels, photovoltaic modules, solar lighting systems, solar power generating systems
    5%
    Solar cells (assembled in modules or made up into panels)
    8541 40 12
    It specifically applies to photovoltaic cells connected together and/or framed to generate electricity, distinguishing them from unassembled cells. Most common use is in solar PV panels/modules
    5%
    Photovoltaic cells (assembled in modules or made up into panels)
    8541 43 00
    Commonly used in solar energy systems, solar panels and renewable energy equipment.
    5%
    Solar water heater
    8419 12
    Non-electric, solar-powered appliances used for heating water
    5%
    Solar inverter
    8504
    Solar inverters used for power conversion
    5%
    Solar lantern / solar lamp
    9405 50 40
    Solar lanterns or lamps are often classified specifically as non-electrical lamps and lighting fittings
    5%
    Solar power plant (composite supply)
    9954, 9983, 9987
    Combined supply of goods and construction/installation services (composite contracts involving construction)
    70% value taxed at 5% + 30% value taxed at 18%
    What common mistakes should you avoid in Battery HSN Classification
    Despite clear GST guidelines, businesses often make classification errors that can lead to incorrect tax application and compliance issues. Some of the most common mistakes include:
    • Treating inverters as batteries: Inverters fall under a different HSN code (8504), while batteries are classified under 8507. Mixing the two can result in incorrect GST rates.
    • Using generic HSN codes instead of specific 8-digit codes: Businesses sometimes use broad 4-digit codes, which may not accurately represent the product and can create issues in reporting and audits.
    • Applying the wrong GST rate (18% vs 28%): Different battery types attract different GST rates. Applying a uniform rate without checking the classification can lead to overpayment or penalties.
    • Misclassifying lithium batteries as lead-acid batteries: Since lithium-ion batteries generally attract a lower GST rate, incorrect classification can directly impact tax liability and compliance.
    Conclusion
    With the standardisation of battery GST rates at 18% and concessional rates for solar components, businesses now have clearer guidelines– but only if classifications are applied correctly. Even small errors, such as confusing batteries with static converters or using broad HSN codes, can lead to incorrect tax filings, penalties or missed input tax credit benefits.
    With TallyPrime, businesses dealing with batteries, inverters, UPS and solar-powered devices can automatically assign correct HSN codes, apply accurate GST rates, generate GST-ready invoices and e-way bills, while ensuring error-free compliance and reporting.
    Verify GSTIN details online
    cta banner image
    FAQs
    Under GST, renewable energy devices and their components do not receive any exemptions. Equipment falling under Chapters 84, 85, and 94 is generally taxed at a concessional rate of 12%.
    EV batteries (mostly lithium-ion) fall under the same HSN 8507 60 00 but may be subject to policy incentives or industry-specific benefits.
    They are taxed under the same HSN code, but GST may apply on the margin value under special valuation rules.
    Waste and scrap of cells and batteries are classified under HSN Code 8549, which covers electrical and electronic waste, including discarded primary cells and rechargeable batteries (accumulators). These are typically non-functional or used batteries sold for recycling or material recovery. The applicable GST rate on battery scrap is 18%, making it important for businesses dealing in recycling or disposal to use the correct classification for compliance and invoicing.
    In addition to complete solar systems, individual components used in the assembly of solar panels are taxed separately based on their classification. For example, EVA backsheets (HSN 3921), aluminium frames (HSN 7604) and solar PV ribbons (HSN 7409) are taxed at 18%.
    Published on May 5, 2026
