    Avoid GST Errors with Accurate HSN Code Identification and Verification
    Tallysolutions
    Tally Solutions
    May 21, 2026
    30 second summary | Using the wrong Harmonised System of Nomenclature (HSN) code on a GST invoice can trigger demand notices, block input tax credit claims and attract penalties under the Central Goods and Services Tax (CGST) Act, 2017.
    An HSN code is a six-digit (or eight-digit) number that classifies a good or service for GST purposes and getting it wrong is not a minor clerical slip. The wrong HSN code can result in a mismatched tax rate, invalidate a buyer's input tax credit (ITC) claim and draw a scrutiny notice from the GST officer.
    Under Rule 46 of the CGST Rules, 2017, HSN codes are mandatory on tax invoices above specified turnover thresholds and incorrect disclosure is treated as a non-compliance under Section 125 of the CGST Act, 2017.
    What makes an HSN code entry wrong (and why it matters)
    An HSN code can be wrong in several ways and each carries a different risk:
    • Incorrect chapter or heading: The code belongs to a different category of goods entirely, for example, classifying a food product under a chemical chapter.
    • Outdated code: The HSN Schedule is updated periodically by the World Customs Organisation (WCO) and adopted by the Central Board of Indirect Taxes and Customs (CBIC).
    • Rate mismatch: Two HSN codes may look similar but carry different GST rates, for example, 0% versus 5%.
    The consequences range from a notice under Section 61 of the CGST Act, 2017 (scrutiny of returns) to demand and recovery under Section 73 or Section 74, with penalties up to 100% of the tax short-paid in cases of fraud. The buyer who claimed ITC on the wrong HSN may also have to reverse the credit with interest.
    What are the common HSN-related GST errors businesses make
    These are the errors that appear most frequently during GST audits and scrutiny:
    • Applying the same HSN to an entire product category when individual SKUs have different codes and rates, for example, grouping all 'footwear' under one code instead of separating by material and value.
    • Copying codes from a supplier's invoice without verifying that the classification is correct for your own supply.
    • Not updating codes after CBIC issues a new notification, leading to the use of a discontinued or restructured HSN.
    • Declaring nil or exempt supplies under an incorrect HSN can create discrepancies in GSTR-1 and attract queries.
    How to identify the correct HSN code
    Follow these steps in order to arrive at the correct code:
    1. Describe the goods or services precisely: Note the material, use, processing stage and any applicable thresholds.
    2. Check the CBIC HSN search tool: The portal at cbic-gst.gov.in provides an official HSN search where you can enter keywords or browse by chapter.
    3. Read the Section and Chapter Notes in the Customs Tariff Act, 1975 (which forms the basis of GST classification): These notes govern which goods fall under which heading and they override the plain meaning of the heading title.
    4. Check CBIC advance rulings and clarificatory circulars: If your product has been the subject of a GST Council decision or an Authority for Advance Rulings (AAR) order, that ruling is binding on the tax officer dealing with your case.
    5. GST rate verification: Verify the applicable GST rate under the corresponding schedule of the CGST Rate notification.
    HSN code verification checklist
    Use this checklist before applying any HSN code to an invoice:
    • Verify the HSN code against the latest HSN schedule notified by the Central Board of Indirect Taxes and Customs (CBIC), including recent notifications and corrigenda.
    • Match the applicable GST rate under the HSN with the rate charged on the invoice.
    • Review the relevant Section Notes, Chapter Notes and Exclusion Notes before finalising the classification.
    • Check recent AAR and High Court rulings for any reclassification of the product within the past 24 months.
    How to prevent HSN errors going forward
    Prevention is less costly than correction. These measures reduce classification risk:
    • Assign a specific team member or adviser responsibility for maintaining the product-to-HSN master list.
    • Review the HSN master list at the start of each financial year and after every GST Council meeting that recommends rate changes, against the latest CBIC notifications.
    • Do not rely on your supplier's HSN alone. Verify independently, especially when buying diverse goods across categories.
    • Keep the HSN search results, Chapter Notes referenced and any advance rulings consulted on file for at least six years.
    • Configure your accounting or billing software to flag any HSN code not present in the current master list before an invoice is saved.
    Conclusion
    HSN code errors are among the most avoidable GST compliance failures, yet they regularly show up in assessments and audits because businesses treat classification as a one-time setup rather than an ongoing responsibility. With advanced accounting software like TallyPrime, you avoid these errors and ensure error-free compliance. The software lets you configure and lock HSN codes against your item master so every invoice applies the correct classification and rate automatically, reducing the risk of human error at the point of billing.
    Verify GSTIN details online
    cta banner image
    Published on May 21, 2026
