    36 GST State Code – Everything You Need to Know About Telangana’s GST Code
    Tallysolutions
    Tally Solutions
    Updated on Apr 7, 2026
    30 second summary | The GST state code for Telangana is 36, and it plays a key role in GST registration, invoicing, and return filing by identifying the correct state jurisdiction. It appears in the first two digits of the GSTIN and ensures transactions are reported accurately. Using the correct state code helps avoid registration errors, reconciliation issues, and compliance risks. Common mistakes include selecting the wrong state during registration or entering incorrect GSTINs for parties. Maintaining accurate records and using tools like TallyPrime helps ensure smooth GST compliance, timely filings, and audit readiness.
    If your business operates in Telangana, 36 GST state code is one of those tiny details that quietly impact everything, be it GST registration, invoices or even return filing. Telangana’s GST state code is 36, and it’s used across GST systems to identify where your business is registered and taxed.
    Let’s break down why the 36 GST state code is the foundational GST marker for the state of Telangana.
    What is the 36 GST state code for Telangana?
    The GST state code for Telangana is 36. It is a unique, two-digit identifier assigned to the state under India’s GST system. You’ll see it most clearly in a business’s GSTIN (Goods and Services Tax Identification Number), where the first two digits represent the state code. That means any taxpayer registered in Telangana will typically have a GSTIN that starts with “36”.
    So, what does the 36 GST state code Telangana actually do in day-to-day compliance?
    • GST registration: During GST registration in Telangana, the state code helps the portal tag your application to the correct state jurisdiction and ensures your GSTIN is generated with the right prefix.
    • Invoicing & customer/vendor validation: When you enter your own GSTIN (or your buyer/supplier’s GSTIN), the “36” prefix helps confirm the party’s registration state.
    • Return filing & reporting: State codes are used across GST workflows (including e-waybill and reporting processes) to correctly identify the state tied to the GSTIN and route details under the right jurisdiction.
    How to use the 36 GST state code for GST registration in Telangana?
    For GST registration in Telangana, the key is selecting the correct State/UT as Telangana during registration. Once Telangana is chosen, the system generates a GSTIN where the first two digits reflect the state code (i.e., 36). That’s the simplest way to ensure correct 36 GST state code usage for GST registration for Telangana businesses.
    Here’s a step-by-step flow on the GST portal:
    Go to New Registration
    On the GST portal, navigate to Services, then Registration, and then click on “New Registration”.
    Select State/UT as Telangana
    In Part A, choose Telangana as your State/UT, then enter basic details (PAN, mobile, email) and complete OTP verification to generate the Temporary Reference Number.
    Fill business details carefully
    Complete the full application (business constitution, authorised signatory, principal place of business in Telangana, bank details, etc.) in Part B and upload supporting documents.
    Tip: Once registered, store your GSTIN correctly in your accounting system. Software like TallyPrime can help keep GST templates, invoices, and GST reports consistent, reducing avoidable compliance errors later.
    The importance of using the correct 36 GST state code in Telangana
    Here’s why the importance of the GST state code for Telangana is so high:
    Avoids registration mismatches
    If the wrong State/UT is selected during registration, the GSTIN generated will carry the wrong prefix (not “36”), which can create problems when linking business details to the correct state jurisdiction.
    Prevents GST filing issues and reconciliation gaps
    GST compliance depends heavily on correct identification of the taxpayer’s registration state. Errors in state identification can complicate invoice matching, reconciliation, and the way transactions reflect in GST reporting workflows.
    Reduces the risk of notices, delays, and corrections
    Incorrect details typically mean you may need amendments, clarifications, or corrections, which can delay processing and create compliance friction.
    Benefits of Correctly Using the 36 GST State Code for Telangana Businesses
    Common issues with the 36 GST state code and how to fix them
    Even when you know 36 GST State Code is for Telangana, real-world compliance can still bring up avoidable errors.
    1) Selecting the wrong State/UT during GST registration
    In the GST portal’s New Registration flow, the State/UT is chosen in Part A. If Telangana isn’t selected, the GSTIN generated won’t start with “36”, and you’re effectively registering in the wrong state.
    If you’re still at the “TRN/application in progress” stage, restart the registration and select Telangana correctly in Part A.
    If registration is already granted and you’ve accidentally registered under a different state, you’ll need to cancel the registration and opt for a fresh registration in the correct state.
    2) Wrong GSTIN/state code entered for a customer or vendor
    You might correctly have “36” for your own Telangana GSTIN, but accidentally store a party’s GSTIN with the wrong first two digits (wrong state). This can create mismatches in invoice reporting and reconciliation later.
    Validate the party GSTIN before invoicing. Correct the party GSTIN in your accounting/customer software as soon as you notice it, so future invoices carry the right GSTIN/state code combination.
    3) Invoice reported with the wrong GSTIN
    If a B2B invoice is uploaded/auto-populated with incorrect GSTIN details, it can affect return accuracy and the customer’s ability to match credits. Thankfully, the GST portal provides options to edit invoice details in Form GSTR-1.
    Where the correction requires amendment rather than simple editing (e.g., already filed periods), use the amendment functionality available in the return framework.
    4) Change of state jurisdiction
    Businesses shift offices or expand and assume they can amend their existing GST registration from another state to Telangana (or vice-versa). However, amendment cannot be used for change in place of business from one State to other; you typically need to cancel and apply afresh in the new state.
    How to ensure your business is compliant with Telangana’s GST state code
    When it comes to Telangana GST compliance, the real challenge is keeping your tax records accurate across hundreds (or thousands) of transactions, and ensuring GST filing in Telangana happens on time with the right data.
    Maintain “36” accuracy through clean, consistent records
    A lot of state-code errors happen because GSTINs, party masters, or addresses are stored inconsistently.
    With TallyPrime, you can centralise your masters (customers, suppliers, GSTINs, places of supply) and generate GST-ready reports based on your books. This way, the correct GST state code details flow through invoices and returns without repeated manual entry.
    TallyPrime also offers GST reconciliation features that help identify mismatches early and keep return data accurate and compliant.
    File returns on time with an easier workflow
    Late or missed filings create avoidable compliance stress. This is especially because GSTR-3B has clear due dates (generally the 20th of the next month for monthly filers, and 22nd/24th after the quarter for quarterly filers, as notified).
    TallyPrime can support timely filing by letting you prepare and file GSTR-1 and GSTR-3B on the portal with assisted filing steps.
    Build stronger audit readiness
    Compliance is about being able to explain your numbers later. TallyPrime’s Edit Log/Audit Trail records changes with date and time, which helps strengthen internal control and supports smoother audits if you ever need to justify revisions in your books.
    Conclusion
    Everything related to your business, from registration and GSTIN validation to invoicing and return filing, needs to stay aligned with Telangana’s jurisdiction from day one. And getting the 36 GST state code right across all stages is key for businesses based in Telangana.
    However, with growing transaction volume, GST-filing and compliance can become haphazard. This is where GST-ready accounting software, such as TallyPrime, make it easier for businesses. Now, you can keep your party masters clean, generate GST-compliant invoices, and keep yourself organised for seamless reporting and compliance, all with one single portal, on time, every time.
    Verify GSTIN details online
    cta banner image
    FAQs
    The GST code 36 is a unique 2-digit identifier that is assigned to the state of Telangana. This code forms the first two digits out of the 15-digit GSTIN code (Goods and Services Tax Identification Number) for all businesses based in Telangana.
    The state code is a mandatory part of a business's GST registration. GST code 36 dictates several key compliance aspects, primarily determining the correct tax jurisdiction and type of GST (CGST/SGST or IGST) to be charged on transactions.
    Proper use of the Telangana GST state code in invoices helps in ascertaining the correct type of tax applicability, whether under inter-state or intra-state. It also helps the buyer to claim the correct input tax credit and further helps in correct return filing and compliances as per state jurisdiction.
    No, only businesses established in Telangana can use the 36 GST state code. Businesses in other states must have their own unique GST state codes.
    If you have mistakenly used the wrong GST code on an invoice, you need to issue a new, corrected invoice with the proper GSTIN and state code.
    You can get a complete list of state codes from the official website of Goods and Services Tax. Many websites, including TallyPrime, update the official codes from time to time on their websites.
    You can check whether your GSTIN has been correctly assigned to Telangana as the state code 36 on the official GST portal. Access the website and click on "Search Taxpayer.” Then, click on “Search by GSTIN/UIN”, enter your 15-digit assigned GSTIN and hit “Search”. The portal will share the details of your business and the state jurisdiction.
    The usage of the correct "36" code in invoices and returns ensures accurate mapping of tax liabilities and ITC claims with a validation perspective. Incorrect or mismatched state codes will make buyers go through ITC delays or denials, mistakes in return filings and possible rejections, or even notices and penalties by GST authorities.
    Published on December 28, 2025
