Udyam registration is the official online process for registering a business as a Micro, Small and Medium Enterprise (MSME) in India. By completing Aadhaar and Permanent Account Number (PAN) verification on the government portal, businesses receive a digital Udyam Registration Certificate that helps unlock credit support, government schemes and compliance-related benefits.
What documents are required for Udyam registration?
Your draft is already aligned with Udyam’s self-declaration process. A slightly tighter version, without changing the meaning much:
What you need before starting:
- Aadhaar number of the business owner or authorised signatory
- PAN of the business or proprietor
- GSTIN, if applicable
- Basic business details, such as the business name, address, bank account details and business activity classification (NIC code)
- Turnover and investment details
Udyam registration is largely self-declaration-based, so in most cases, no documents need to be uploaded at the time of registration.
Step-by-step Udyam registration process (free online)
The process is fully digital and can usually be completed in a single session if the required details are ready.
- Step 1: Visit the official Udyam Registration portal
Go to the official Udyam Registration portal (udyamregistration.gov.in) and select the option for new entrepreneurs.
- Step 2: Enter Aadhaar details
Provide your Aadhaar number and verify it using the OTP sent to your registered mobile number.
- Step 3: Validate PAN and business details
Enter your PAN and organisation type. The system automatically fetches tax-related details, reducing manual errors.
- Step 4: Fill in enterprise information
Enter the business name, address, bank account details, NIC code and number of employees.
- Step 5: Enter investment and turnover details
Provide the financial details required for MSME classification.
- Step 6: Submit the form
After submission, the application is processed and the Udyam certificate is generated digitally.
How to download the Udyam registration certificate
Once approved, your certificate is available online and acts as official proof of MSME registration.
Steps to download:
- Visit the Udyam portal
- Click on “Print/Verify” then “Print Udyam Certificate”
- Enter your Udyam Registration Number (URN)
- Verify using OTP
- Download the certificate in PDF format
How to check Udyam registration status
If you have applied but have not yet received confirmation, you can check your status online.
- Go to the official Udyam portal.
- Select “Verify Udyam Registration Number” under the Print/Verify section.
- Enter your URN and complete the verification process.
This helps confirm whether your registration has been approved and also shows the details linked to your application.
A small alignment note: the official Verify Udyam Registration Number page generally uses the URN and captcha verification rather than OTP. If you want an OTP-based step, that usually applies when printing the certificate, not the basic status check.
UAM to Udyam migration (for existing businesses)
If your business was registered under the Udyog Aadhaar Memorandum (UAM), it must be migrated to Udyam Registration. Migration helps ensure continued access to MSME benefits and compliance with the updated registration framework.
Here’s how the migration process works:
- Visit the official Udyam portal.
- Select the option for businesses with existing UAM registration.
- Enter your UAM number and verify it through OTP.
- Update PAN, GST and other business details.
- Submit the application for conversion.
Summing up
In the end, Udyam registration is not just about getting a certificate. It is about keeping your business information accurate, organised and ready when it matters.
When turnover, investment and financial records are reviewed consistently, it becomes easier to classify your enterprise correctly, stay compliant and make timely business decisions with confidence. Over time, that consistency reduces dependence on assumptions and gives you better control over growth.
That is where structured systems make a real difference. Tools like TallyPrime help businesses maintain reliable records of turnover, investment and overall financial performance, making MSME classification, reporting and ongoing compliance far easier to manage.
